Hi!my computer freezes during setup and cannot continue at the point 34 that is when its left 34 minutes to complete setup please help me with directions to solve this problem thanks
  • 3,940 Answers
34 minutes is the hardware detection portion of the Windows install. To get around this, boot to BIOS, turn off all integrated devices (Audio, Modem, Network Card, 1394 etc) and remove and expansion cards (Modem NIC etc) and disconnect all external devices except keyboard and mouse. Then try install again.
If system goes past 34 minutes, then you finish the install and add items back one at a time
Posted on Oct 07, 2010
  • TRam102008 Oct 24, 2010
    Can you give us step by step instructions please? THANKS!
  • IQUIT Oct 24, 2010
    most modern systems you can enter the BIOS (system setup) by pressing F2 at boot (Some systems, you press DEL, others F1 or F10, it should flash on the screen at boot)
    In the bios, there is normally a setting for INTEGRATED DEVICES, to include sound card, Network Adapter, Wireless Cards, etc, none are required for install of WIndows so turn them off.
    If the system is a Desktop (Minitower etc) then the usual culprit is the Modem. Most systems this is an expansion card that requires at the most 1 screw to remove
    Once these are done, then boot to the WIndows CD and see if install will continue past 34 min
Restore point
Using System Restore to reverse system changes in Windows 7 usually takes several minutes Here's How:
  1. Navigate to the Start -> All Programs -> Accessories -> System Tools program group.
  2. Click on the System Restore program icon.
  3. Click Next > on the Restore system files and settings window.
  4. Choose the restore point that you want to use. Note: Check the Show more restore points checkbox to see more than the most recent restore points.
    Note: Any restore points that you created, scheduled restore points that Windows 7 created, and those created automatically during the installation of certain programs will be listed here. You can not use System Restore to undo Windows 7 changes to a date that a restore point does not exist.
  5. Click Next >.
  6. Click Finish on the Confirm your restore point window to begin the System Restore.
    Note: Windows 7 will shut down to complete the System Restore so be sure to save any work you might have open in other programs before continuing.
    Important: System Restore will not revert any of your non-system files like documents, email, music, etc. to a previous state. These types files are completely unaffected by System Restore. If your intention with this tool was to recover a deleted non-system file, try using a file recovery program instead of System Restore.
  7. Click Yes to the Once started, System Restore cannot be interrupted. Do you want to continue? dialog box.
  8. System Restore will now restore Windows 7 to the state that was recorded in the restore point you chose in Step 4.
    Note: The System Restore process could take several minutes as you see the "Please wait while your Windows files and settings are being restored" message. Your computer will then reboot as normal when complete.
  9. Immediately after logging in to Windows 7 after the reboot, you should see a message that System Restore completed successfully.
  10. Click Close.
  11. Check to see if whatever Windows 7 problem you were troubleshooting has been corrected by this System Restore.
    If the problem still persists, you can repeat the steps above and choose another restore point if one is available.
    If this restoration caused a problem, you can always undo this particular System Restore.
Mar 15, 2014 | Computers & Internet
Windows install freezes at 34 minutes
Please replace the ram and still if the problem persists replace the hard drive.
Thanks
Jun 15, 2012 | Toshiba Satellite M45-S265 Notebook
Dell 4700 bios a06 2.8 ghz 64 bit bus=800mhz pentium 4 2.8 ghz microsoft xp pak 2 moterboard light= green abcd lights=green reset bios to factory settings computer keep shutting down.. windows dialog box...
You have a rootkit virus, the only answer is reformat the drive and start fresh, sorry.
After a fresh install is done immediately install service(can be downloaded free from microsoft.com) pack 3, because sp2 is vulnerable to a host of trouble.
Apr 17, 2010 | Dell Dimension 4700 PC Desktop
SCREEN FREEZE-CHECKER BOX
reboot your computer and during starting type f 8 keys then start in vga enable mood then setup vga 1024 .
May 16, 2009 | Gateway FX7026 PC Desktop
Installing XP
Acer computers come with a factory restore partition installed from the factory. The following instructions are direct from Acer's support website:
Note: These steps will return the system to the original factory installation including all factory installed drivers and applications.
Back up all data prior to using this procedure.
  1. Plug in the AC adapter and battery.
  2. Turn the system on
  3. Immediately, press ALT on the keyboard and start tapping F10.
    Continue holding ALT and tapping F10 as the unit boots up.
  4. A screen stating "Starting Acer Erecovery" should appear.
    (Release ALT and stop tapping F10 at this point)
  5. There will be 4 options:
    1. Restore system to factory default
    2. Restore system from user backup
    3. Restore system from cd/dvd
    4. Exit
  1. Enter the password created when eRecovery was first started.
  2. Read the on-screen warning and choose Yes.
  3. Click Next. The recovery process will start.
When recovery is complete the system will re-start and will need to complete the setup of Windows.
When setup is complete a process will clean up the recovery files.
Please be patient as this process can take 5-10 minutes or longer.
Hope this helps. Please take a moment to rate this solution. Thanks.
Mar 18, 2009 | Acer TravelMate 4230 Notebook
Freezing up when installing winxp pro.
MAY BE THIS COULD HELP. PUT YOUR LAPTOP IN FRONT OF A FAN, THEN TRY TO FORMAT IT AGAIN, IT SOUND FUNNY BUT I FACE THIS CASE MORE THEN 3 TIMES, THE LAPTOP JUST TOO HOT DURING THE INSTALLATION (PUT THE FAN WITH LEFT SIDE FACING THE FAN)
JUST SHARING=)
Jan 25, 2009 | IBM ThinkPad T21 Notebook
System freezes on boot up
hi there,
did your system to press F1 to continue. not try to go on BIOS setup. on booting process press F2 or Delete tab. and then click on safe mode if the booting will continue to run. come up a confirmation if you continue in safe mode click yes. and then work on that system for a couple of minutes, and then restart you pc.
you have too many start up programs. that why it will freeze during start up.
Nov 29, 2008 | Biostar P4M890-M7 Motherboard
Freezing or shutoff on boot, setup or minutes into operation
Try this:
Boot the system with your Windows XP installation disk. When the boot options window appears select R for recovery console. Once you have logged into the DOS session type: fixmbr and hit the enter or return key and select "y" for yes you want to do this. Type: fixboot and hit the return key again, hit "y" for yes.
May 17, 2008 | HP Pavilion ze2000 Notebook
Original setup was interrupted
press F8 key (just after BIOS screen) at the next cold reboot and you will see a DOS screen with 3 or more options. Read each of them and I think you will see one option is to resume setup. This option places the system at a safe entry point to continue the setup. Another option may read "cancel setup and restore previous system"...this one may be used if you cannot get the "resume setup" option after repeated tries.
Aug 03, 2007 | Compaq Evo N610C Notebook
Computers & Internet Logo
79 people viewed this question
David Payne
David Payne
