Question about JVC Televison & Video
I have lost my remote for my digi box (JVJ TU DB1SK)and I get a no signal message on my TV. Is there a way to tune my TV without remote? Will I have to buy a JVC remotte or will a multi fntional one do the job?
    Guru:
  • 1,463 Answers
I have a Grundig TV P37-080GB or G.CG61-02GBM bought in UK. Using Auto Tuning I can find local TV channels but the audio to each of these channels does not work. I get a hissing sound as gets when not...
Hi.
If you are using the TV in UK, and you are using the internal digital tuner (aerial cable to TV), then the TV may be defective (faulty tuner or audio circuit). In that case call Grundig at the number listed on manual.
If TV is using an external digi box (eg. freeview), then check connection from box to TV, test using a different connection cable. Test using a DVD, if TV works on DVD replace the digi box.
If you are trying to use the TV outside UK, and you are using the internal digital tuner, then there may be a problem with signal. In that case purchase a tuner box and connect it to the TV.
Jul 14, 2010 | Televison & Video
We have bought a digi box for this tv but can not tune the tv
hello make sure the aerial is connected to the digi box then a lead from the digi box the the tv also connected a scart lead from the digi to the tv the go into the menu choose first time installion click ok the it should search
regards
shaun
Mar 27, 2010 | Televison & Video
How do i set up atv without inbuilt digital a seperate digital box and a video recorder?the tv digital tuner and video all have scart leads.Should the aerial cable go to the video or digital box?
Aerial to digi box first then video then tv (not strictly necessary)
Depending on what you want to do with the vcr and the digi minimum scart connection is
digi to video - video to tv
Nov 08, 2009 | Computers & Internet
LOst manual to setup Sagem ITD59g digi box.
press menu installation, then tap in 1,2,3,4 on remote for access code then choose user setting to take you to tuning menu
Mar 05, 2009 | Televison & Video
JVC TU-DB1SK : Unable to setup basic freeview
1050 1071 1199 1259 1280 1315
Press and hold TV until the LCD blinks then try each code and in between press standby, when the TV turns off that will be the right code. May work for you, if not post back
kind regards
Nov 29, 2008 | Televison & Video
Sky upstairs
Yes on the back of the box there is a RF2 output...
run a coaxil aerial cable from there to your required TV, you then need to tune the 2nd tv to the sky box.
You can also buy a 'Magic Eye' and a 'extra remote' this will allow you to change channels from the second destination with only 1 digi box.
Down point is that you have to watch the same channel on both tv's.
a second card and box and a dual LNB will allow you to watch seperate channels.
Jul 20, 2008 | Televison & Video
Tuning
I have a hikona 14" tv havew lost the tuning manual. Can you help!
Dec 22, 2007 | Philips Magnavox Learning Universal Remote
Can't tune stations from freeview box to DVDR3380/5
You can only record freeview channels through your box.
Assuming the digi-box has two scart sockets, connect as follows:
  • Scart 1 or TV scart of the digi-box to the TV.
  • Scart 2 or VCR/DVD scart of the digi-box to scart 1 of the DVDR3380.
The TV aerial should already be connected through the digi-box and DVDR3380 to the TV
To record from the digi-box, select AV1 / E1 / EXT1 on the DVDR3380
If you are doing timer recordings, you will also need to leave the freeview box on the channel you wish to record, or set the freeview box timer.
Dec 15, 2007 | Philips DVDR3380/05 DVD Recorder
Televison & Video Logo
112 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
