Question about Kitchen and Much More 22 in. Countertop Dishwasher Free-standing Dishwasher
I have a SA chinese counter top dishwasher Mod:0102-CDN-DW5E. I need the inner door plastic cover. Where can I buy this in the USA/cost? If not where/cost?
    New Friend:
My dishwasher will not empty the water and I get an E2 error. Do I need a new pump? Where do I get It? 0102-CDN-DW5E
Posted on Oct 18, 2015
Jet arms will not turn
check if its dead then the power coming into the unit is bad or the fuse inside on the control board has blown.
check the power at the dishwasher and if all is well then open the door, remove all the screws from around the edge, raise the inside panel, swap the fuse thats on the control board
If the control panel is not lit at all and the dishwasher doesn't function either then you will have to check the fuse. The fuse is on the control board. It is a white flat plastic fuse that is on the front of the control board.Remove the screws from the inner door. There should be about eight or so screws that need to be removed from the door we it is opened.
After those screws a removed you can pull off the inner and outer door to expose the control board in the top portion of the door. It is usually in a black plastic cover that protects the board. You will need to depress the clips on the black plastic cover on either side to release the cover. Once the cover is off you will see the control board and fuse attached to the control board.
If you have a meter you can check the fuse with continuity. First unplug or turn the circuit to the machine off. Then take the wires off the fuse and put the leads from the meter onto the terminals of the fuse. And then set your meter to ohms or continuity. You should read 0 ohms or a tone with continuity. If the fuse is good and has continuity then you need to replace the main control board.If the fuse is bad you will have to change it.
Jun 26, 2014 | Whirlpool DU930 Built-in Dishwasher
The door on my machine won't shut?
Hello
You will need to adjust the dishwasher door latch to fix the door if it will not close. The door latch can come out of alignment from use. Adjusting the latch assembly is a straight forward process on most models of dishwashers. First, remove the securing fasteners for the inner door panel. It is a good idea not to remove the inner door panel completely, just enough that you can access the door latch assembly.
Turn the dishwasher circuit breaker off inside your home electrical panel. Open and close the door and watch where the strike plate makes contact with the door. The strike plate is usually on the front top center of the dishwasher. If the strike plate is out of alignment, it will hit the inside of the door.
Pull the dishwasher out of the counter enough that you can access the strike plate securing Torx screw. You may need to open your dishwasher door and remove the two screws that secure the dishwasher mounting bracket to the bottom of the counter with a Phillips-head screwdriver to pull the dishwasher away from the counter.
Loosen the Torx screw that secures the strike plate to the washer tub with a Torx driver. Adjust the strike plate so the plate will engage the door latch. Retighten the Torx screw and push the dishwasher back under the counter. Secure the brackets to the counter if your dishwasher uses retaining brackets.
Adjust Door Latch
Open the dishwasher door and remove the Torx screws securing the inner door panel to the outer door panel with a Torx driver. The retaining screws are usually around the side edge and top edge of the dishwasher door.
Lift the inner door panel enough that you can loosen the two securing bolts on the door latch with a wrench. You only need to loosen the bolts, not remove them.
Carefully raise the dishwasher door to align the door latch with the strike plate. Hold the door latch with your finger tips when you align the latch. Lower the door and tighten the door latch securing bolts.
Install the inner door panel retaining screws and tighten all screws with the Torx driver. Close the dishwasher door and turn on the circuit breaker.
Sep 12, 2011 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwasher is beeping every 20 seconds, but not turning on.
There is most likely a problem with one of the door switches. Right where the door latches to the tub there is a small white plunger in the opening of the door which gets pushed down to trip two switches within the door. Disconnect power to the dishwasher and take out the phillips head screws holding the inner and outer door panels together. Check out the plastic cover over the door switches to make sure it has not warped due to heat. The cover is held on by four plastic tabs. The white plunger has a spring on the bottom of it, so watch out for it so you won't lose it. The flat side of the white plunger faces the dishwasher's tub.
Feb 05, 2011 | GE 24 in. Profile PDW7880G Built-in...
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Dishwasher Model LSV66 - door will not open
There is probably something broken with the latch mechanism as it is mostly made of plastic.
Safety first, ensure mains is off to dishwasher!
Your best chance of opening - Method one - first you need to understand how the latch works. In LSV66, the latch is right at the top, centre above the door handle and the ariston logo; you cant see any of these unless you have it opened - so try to imagine the mechanism as I describe; the door side is a tongue while on the dishwasher side it is a D-shape loop - at locked position, the tongue is inserted into the loop from below. So to pick it, use a coat hanger wire, bend it into L-shape. The problem is you need to slide this between the door and presumedly your worktop and slide it to the middle, learn where the latch is initially - the hard part is you need to slide the L-shape tip as close as possible the the door side, the tip should come in from sideway sp that you are trying to slide the tip arm of the L-shape underneath the d-loop and to unhook it is to flick the d-loop with upward turn and NOT downward since it loops over the tongue from top. Method two - assume you are confused about method one or simply cant slide the L-shape between the tongue and d-loop, the next best way is to pry the latch open, here you run a small risk of breaking the d-loop but you can easily buy a replacement spare - to pry open the door, use a sturdy tool if you dont have a suitable size crow bar - a robust screwdriver could do. You need to pry it close to the latch to get good fulcrum power, so approach middle above the logo between door and worktop - you are likely to scratch the top edge of the door but again this part is concealable when the door is shut so wont be too cosmetically bad.
Once opened, unscrew the top panel from inner door, you will find the latch mechanism which I assume something is broken - replace this by buying a spare - usually cost around £20.
Good luck.
Dec 29, 2010 | Ariston Technologies Dishwashers
Er...error code
FREE FIX!! Before you do anything else try this....
Blinking display with "ER S" on this model is a "keypad error" NOT a control board error. It occurrs when a button on the keypad is "stuck" for more than a minute most likely from being corroded - which can happen when the steam accumulates on the underside of the counter and drops down onto keypad (an apparent design flaw which frigidaire will do nothing about) - all the techs I've talked to recommend replaceing the entire plastic keypad assembly (oem part cost $125 at my local store). But they sell just the switch that is glued into the assembly for 16$ at www.repairclinic.com and it is a thin plastic film with electronic circuits running through it. Before you buy it though, turn power off at breaker, then try gently prying the keypad switch cover (the strip with the buttons on it) off of the top of the door panel (It is stuck down with a double sided clear tacky strip - I did it with a thin butter knife) and cleaning off any corrosion on underside of strip and on switch. Gently replace the keypad cover strip and press down around the edges gently. Then turning power back on to machine and see if that fixes it - worked for me - FREE!!! Worth trying before you call out a tech
Mar 22, 2010 | Frigidaire PLD4555RFC Dishwasher
I just fixed a me super but the frame counter doesn t reset when the 36st is reached or when I attempt to open the camera. HOW DO I RESET IT without openning it?
By opening, do you mean the back cover or the top cover?
after rewinding the film opening the back door will reset the counter. if it does not reset, try firing the shutter with the back door opened a few times. this counter is mostly plastic.
with the back door opened try taping the top cover over the counter to free the counter gear.
if it still wont reset the top cover will have to be removed and the counter repaired.
there are no new parts available for this model Pentax so a good used counter could be expensive.
if you take the top cover off, usually the pointer plate on the right side of the counter is rubbing on the counter preventing it from resetting.
Oct 15, 2009 | Pentax ME Super 35mm SLR Camera
Trying to replace the KHMS155LSS3 handle...
To replace the plastic handle on the KitchenAid KHMS155LSS-3 you pry open the door cover from the inside to release the upper tangs (~10). I used razor blades wedged between the tang point to hold them disengaged. Pull the front cover off the door starting from the handle end. Once the top edge is free, the bottom can be remover. See Pitcures.
Repeat the door cover removes with the handle attached from the front after you lift the tangs._828.jpg_829.jpg_830.jpg_831.jpg
Jul 26, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Amana Dishwasher Mod. ADB1500AWQ, Door won't open.
HI,
Please check whether the plastic pins are broken.
I removed the inner door panel and found the handle broken. It has integrally molded plastic pins that provide a pivot for the handle to push against the release assembly. These were broken off. Also noticed that there were some small fingers molded on the back of the switch panel that were snapped off. I'm not sure what these are for and I can't see how they are needed for the latch operation. My hunch is that they aid in positioning the handle during factory assembly. I'm NOT going to buy a new switch panel to replace these!
I don't know why the handle broke but it did so in stages. I think one pin broke, and then everything else broke because of added misalignment and stress. The good news: a new handle only costs about $10 and I'll have it in a couple of days. Thanks
Apr 24, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Getting to the control panel
The outer user interface / touchpad stays in place. it can be removed only after removing the electronic machine relay board. The relay board is accessed from the inside of the door. You need to separate the inner door panel from the outer door panel. After removing the screws from around the inside of the door, the inner panel should lift up and away from the outer panel. The plastic cover should just clip on. you may need to use a flat screwdriver to release one or more of the clips. After that you'll be able to see any screws or clips holding the relay board in place.
Mar 12, 2008 | Bosch 24 in. SHU43 Built-in Dishwasher
Kitchen and Much More 22 in. Countertop Dishwasher Free-standing Dishwasher Logo
199 people viewed this question
Top Kitchen and Much More Dishwashers Experts
Are you a Kitchen and Much More Dishwasher Expert? Answer questions, earn points and help others
