Question about Garden
I have a oleo mac hc 260 xp hedgecutter. Earlier this year I had to replace the ignition coil but since then the machine starts and runs ok but it doesn't seem to get up to full speed and the blades don't cut like they used to. They stop easily on even small branches. Have had it for 4 years - no problem before
  • 26 Answers
Since the machine runs, I'm assuming the carburator and the rest of the fuel system is in good order. So, the blades may need oiling. Give 'em a shot of WD-40 or something similiar. If that doesn't do it, be sure the blades are not bent or cracked or otherwise getting in each other's way. Last check: there should be a gear box--usually on the underside of such units--for the blades' driving mechanism. If there isn't a greasepoint or another type of lubrication point, open up the gearbox and see if the gears are still meshing correctly and are well lubricated.
Posted on Oct 07, 2010
Testimonial: "Thanks - the blades do move but only at 75% power so I don't think they're bent - I will check the gearbox."
Tahoe not getting fire to plugs, when I try to crank it there is an odor of gas and no start! Crank sensor,evap purge valve solenoid, fuel pump and knock sensors have all been replaced.
Things to check:
  1. Timing chain or timing belt (depending on which engine you have);
  2. Coil pack or ignition coil (depending on which engine and year);
  3. Rotor and distributor cap (if your Tahoe is an earlier model);
  4. ECU (especially if you jump-started the car before the issue began);
Jul 20, 2014 | Cars & Trucks
OLEO MAC TRACTOR WITH KAWASAKI 15HP ENGINE. Cuts out/stalls when ignition switch is turned to Normal, but OK when turned to Caution Reverse Cutting. Is there a difference in the switch positions?
this is nothing to do with what the other lot have said. i work at a lawnmower shop and to me it sounds lik ur neutral posistion sensor. it seems like it is registering it in reverse all the time, hence it only works when u put it to reverse cutting mode. if you want, i am not too far away from you. we are the other side of preston in burscough. give me a ring on 01704 894457.
Josh
May 18, 2011 | Garden
I have a wv microbus 2.3i 1998,it just went of while i'm at a speed of 120km/h since than it doesn't want to start.the coil is get current its not sparking,what might be the...
Dear Sir,
As you said coil is getting currant but not sparking further to spark plug , then check few things.
1 Check the connector is proper fitted on ignition coil.
2. No lose connection with pin of connector or pin should not be lose.
3. All pins are clean of connector and no rust is there.
4. Check High Tension cable (cablle black couler which run from ignition coil to spark plug) if found ok then try with new cable if it wont start.
5. It is problem with ignition coil replace it problem will solve.
Problem can solve at any step from 1 to 5 i did arrange all steps by easy to check and less expanses, final step will more expansive than earlier step.if any issue let me know. thanks
Yogesh
Nov 16, 2010 | 2005 Volkswagen Microbus
Fuel oil mix for a Poulan 14" saw ?
Oil Mix Ratio:
The following ratios have been recommended for the last 10-15 years.
Dolmar, Echo, Efco, Homelite, Husqvarna, Jonsered, Makita, Oleo-Mac, Red Max, Ryobi, Shindaiwa, Solo, Spear
Sep 02, 2010 | Garden
I require an oil pump and gear drive for OLEO-MAC 481
manual link below.
www.echo-usa.com/pdf/.../CS300340345es03_061405.pdf
parts suppliers www.echo-usa.com › Products -
www.jackssmallengines.com/chainsaw_parts_index.cfm -
http://www.repairmanual.com/outdoor_power_equipment
Mar 18, 2010 | Echo 30.1CC Chainsaw With a 14 In.bar and...
Tightening the chain tension on an Oleo-Mac 19E
http://catalogo-dynamac.emak.it/database/emak/manuali.nsf/doc/0F51266CAC228689C12571C3003AAAC8/$file/OM15%C3%B719E_4_B.pdf
Page 12 picture 2 shows how to tighten the chan .. fairly basic in that you loosten the bar with a spanner and slide it forward to tighten as necessary. Unfortunately the manual is not English, but the pictures should be clear enough
If this helps pls leave feedback, if not let me know and I'll try and help some more!
Jan 27, 2010 | Garden
Troy Bilt Lawn Tractor Will Not Start
check connections on the battery let me know thanks wade
Jul 04, 2009 | Garden
94 concorde
change crank sensor? if so replace control module (ignition module)
Jul 04, 2009 | 1994 Chrysler Concorde
I need a manual for aoleo mac 730s strimmer
Petrol oil mix 25:1 or 50:1 oleo macs own
Starting lock trottle half way (put On/off to start position and depress lever ) prime bulb x 5 choke back fully and pull chord till starts
plug rcj-7y
Apr 03, 2009 | Garden
Not getting petrol through to the carburetor, I
I have a parts manual you can have a copy, can you tell me what the gas mixture for the Oleo Mac 234f, 25:1 or 50:1
Apr 01, 2009 | Garden
Garden Logo
116 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
