Question about Samsung WE356A5W Washer/Dryer Laundry Pedestal
Can you reverse the door on the Sansung WF210 Washer? If so, how?
Lights flash
In the most front load washer this is very common problem and in these new washers such problems are due to malfunction on the door lock or control panel or control board ,you have to check them all one by one
Apr 24, 2014 | Hotpoint Aquarius WF210 Front Load Washer
If we have a new Samsung WF210 washer. the drain that we have to reach is approximately 7'-6" high (from floor). We have attached drain extension to the washer and have run it into the drain. Will...
Hi it will have a impact on your washer in time because the pump will block up causing you problems the recommended hight is 2ft 6 ins short term it will be ok
Aug 03, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Lights flashing and unable to start cycle. Helped once when turned off at mains but not now.
Hi it could be your door lock switch your machine on and wait for 6 seconds and try to open the door if you can thats your problem or may be that the door catch ic worn try and push the door shut with a bit more force
Jun 29, 2011 | Hotpoint Aquarius WF210 Front Load Washer
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Apr 21, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Ive pulled the door handle to hard when it was locked and now it wont open.is there anyway i can open it thanks
Make sure there is no water left in washer, and try door again.
If it still will not open,then remove top cover, and force door lock open from inside at the front.
You will possibly damage the door lock by doing this, but i am afraid there is no other way of doing it.
Jan 30, 2010 | Hotpoint Aquarius WF210 Front Load Washer
Very noisy when spinning
hi
it may be the belt making noise,,,check it,,,
thank u,,,//////please rate it
Jul 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Hotpoint wf210 filter location?
Hi!
Thanks for using FixYa. The filter is located under the panel of front door in the bottom of the machine. You need to pull the panel out and you will find the filter there. Before opening the filter prepare a bowl and a floor cloth to avoid flooding.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Door seal needs to be repleced
sorry not a answer as such. I found out the machine is still under guarantee. So I just called out the repair man.
Feb 12, 2009 | Hotpoint Aquarius WF210 Front Load Washer
Samsung WE356A5W Washer/Dryer Laundry Pedestal Logo
522 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
