Question about Hotpoint Dishwashers
Very slow water fill. A "No Heat" wash takes about 2 hours and a light wash at 65 deg C. takes about 4 hours. Checked the filter on the water supply and it was clear. Apart from the slow feature the machine performs OK
  • yoncassius Oct 07, 2010
    Dishwasher has only a cold feed with a head of 20 feet via a half inch diameter copper tube. It looks as though there is a partial obstruction somewhere in this filling/measuring system. Is it possible to remove this plastic device (a panel about 28 inches high, 12 inches wide and 1 inch thick located on the left side of the washer) which has a multitude of water channels in it, with holding sections which are filled and emptied in sequence to provide the requisite volumes of water, for each stage of the program, to each location in the machine? There are at least three thick walled plastic tubes, with an O/D of about half an inch, connected to this panel, as well as some smaller plastic pipes. I can only presume there is a solenoid valve buried under the dishwasher which opens when the machine is switched on allowing the filling process to begin. Hence my reason for asking if this plastic panel can be removed and if so, how?
  • Hotpoint Master
  • 19,396 Answers
Hi.
Ensure that the inlet hose at the back of the machine is not kinked or blocked, and ensure that there is enough water pressure.
Parts to be tested are inlet valve and overfill switch.
If those parts are OK, then it is probably a faulty timer board. Before declaring the timer board culprit check the door switch in case it is cutting intermittently, and check the thermostat (I know cold cycle is good).If all those are OK, replace the timer board.
If the valve is dual, then it can be tested swapping the contacts for hot and cold inlet and noticing if that makes any difference. If the swapped contact valve does not fill at all, then the hot valve is gone. If it goes regularly (slightly underfilling), then the cold is gone. If the valve is dual you replace the part alltogether.
Full test on valve is done reading Ohms at both solenoid contacts, and reading volts while cycling.
The overfill switch is usually a float sensor driven switch. This is tested jumping contacts and running a controlled cycle.
Door switch is also tested jumping contacts.
Some machine have an overfill device located under the bottom panel (eg. the aquastop). In that case disconnect power, remove water completely and empty the overfill device.
If all the above is OK, then go for the control board. Before replacing control board test also thermostat and pump. Thermostat is tested jumping contacts. Pump is tested energizing. This parts are probably not involved, but since there is no tech to test timer board by reading voltage out, better testing everything before eventually replacing timer.
Always disconnect power before performing any maintenance. Limit testing to operation that can be done with power off.If you need to call a technician, use the number listed in the user manual.
See here how to locate parts and diagrams : Where do I find parts and diagrams?
Regards.
Ginko.
Posted on Oct 07, 2010
  • 1 more comment
  • Ginko
    Ginko Oct 07, 2010
    Hi.
    Can you give me the model of the dishwasher?
    Thanks.
  • Ginko
    Ginko Oct 07, 2010
    Hi .
    I am going offline and I did not get a replay about model.
    That thing you are talking about is probably, the smart fill system, that is an overfill switch controlling inlet. If that is what you have, there is no solenoid in there, just a switch. The part is tested jumping it. For safety reasons test is better done by a trained tech. I am not sure if we are on the same, here a pic:
  • Ginko
    Ginko Oct 07, 2010
    By the way, if this model has a fill funnel, then that is the problem. In that case slow filling may be caused by blockage in the fill funnel.
    The fill funnel can be open
I have a 13 year old indesit front loader washing machine and the water intake is extremely slow. The water pressure is fine and so it is definitely the washing machne. Can you tell us where to look? There...
2 things- water and I suspect a possible heating problem!
Water
If you have checked that the hot and cold water taps are turned on fully and the hoses are not kinked or squashed at the back, it is worth while checking both the hot and cold water inlet filters. Turn the taps off and remove both hoses at the washer end. Inside each inlet port there is normally a little filter which should just slide out. Clean if necessary and replace each one and the hoses. If after turning the taps back on there is no improvement, the problem is symptomatic of a malfunctioning hot or cold water control valve. Sorry but it needs a service call ;-0(
Heating
It is possible that the heater is taking longer than it should to heat the water to the correct temperature. This could be that the element is coated in calcium. I suggest you run the contents of a couple of sachets of proprietary limescale removing powder/fluid through it. The most efficient way is to put the contents in an empty washer and pour a kettle of hot water into the drum then leave overnight. In the morning run just a spin; the water mix will then go through the drain filter and drain motor impeller blades, doing absolutely NO harm whatsoever, in fact some good!
You could also consider repeating the action ;-0)
If these have assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
Jun 27, 2011 | Indesit W 123 Front Load Washer
Washer will not fill up with hot or cold water
i would say its your water inlet valve have it tested or better stil replace it..
Jul 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
Ariston LS 2020 taking more than two hours to go through cycle.
Ariston and on and on...lol
The water temp thermostat is to blame or the water is not heating.Basically what happens is the washer fills with cold water and starts to wash and heat at the same time.Once the water reaches a certain temperature it moves onto the next stage of the wash program.If the water is not heating or the thermostat is not working the programmer wont get the signal to move on.Hope this helps.
Apr 26, 2010 | Ariston Technologies Dishwashers
I have a Lennox elite series furnace. The vents are just blow out cold air, not heat. The theromstat is now working strange. I set the digital theromstat at 75 deg. and then place the thermostat on hold....
You did great! Yes you have a heating system error not a thermostat issue. The 2 blinking lights is an indication something is wrong. Now what you need to do is to remove one of the panels on the heating system and look for a wiring diagram pasted on the reverse. On this diagram there will be a diagnostic chart explaining where to start looking for an issue based on 2 blinks. Because each model is different, a 2 blink error code could indicate a bad pressure switch, plugged air filter or any other thing.
Mar 21, 2010 | Heating & Cooling
Hobart dish machine low wash temp
make sure all the curtains are there ,also check for any baffles missing from mach. should be 2 1 on incoming side 1 on outgoing, also ck hood vents had problem before with vents wide open sucking heat right out of warewasher
Jan 09, 2010 | Dishwashers
Whirlpool Dishwasher GU3600XTSB 3 - 4 hours to complete washing
Wash time is determined by the cycle you select, the incoming water temperature and the installation location. The new machines will heat the water to a predetermined temperature and it takes roughly 1 minute for each degree of rise, If the incoming water is at 120 deg and the wash cycle wants 165 than it will take 45 minutes just for that one cycle to complete, Factor in an outside wall with poor insulation or lower water temperature and it could take even longer. Eric
Dec 30, 2009 | Whirlpool GU3600XTS Dishwasher
Very slow to fill up with cold water-
The mechanical internals of both the hot and cold water inlet valves include a rubber (or similar material) diaphram. After a period of time the diaphram deteriorates and punctures or tears. When this happens the water inlet valve ceases to function correctly and the water just dribbles in and may take hours to fill the machine.
The cure is to replace the water valve that is displaying this problem. The presumtion is that you are already sure there is no filter blockage at filters that may be in the hose ends at the supply tap end and / or at the machine end.and that the plastic pull out filters that are in the water inlet valve (accessible after disconnecting the hoses) are also clean.
Jan 11, 2009 | Fisher and Paykel (IWL12)
My dishwasher has been running for 4 hours!
The long cycle is caused by the heater not heating the water or not having enough water in it to heat. It is normally a slow fill valve in the unit. The best way to check is to start a cycle and let it fill to see how much water is in it. If you add a little water to it and it pumps better you will know you have a water supply problem.
Apr 23, 2008 | Bosch 24 in. SGV53E03 Built-In Dishwasher
Dishwashers Logo
59 people viewed this question
Top Hotpoint Dishwashers Experts
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
