Your console displays the following error message in multiple languages on your television screen or monitor? E74. System Error. Contact Xbox Customer Support. This is caused by a hardware failure. 1. Turn off the console 2. Turn on the console 3. Verify that your getting this error message If you do get this error message you will need to submit a Console Repair Request at: http://www.xbox.com/support/contact I'm sorry to hear this happend, and I am sorry there is nothing else I can tell you, this happend to me and i got my xbox 360 shipped out in 1-day and back in 3-days. Please don't forget to rate, Thanks!
If you get the Xbox 360 1 red light message, it means that the problem is either with the DVD drive, or with the hard drive.
Fortunately, the Xbox 360 1 red light message is not something that you should worry about. In order to identify which of the two drives the Xbox 360 1 red light messages is referring to, just look the code number that the screen displays. DVD drive errors are identified with the codes E64, E65 and E66, whereas hard drive errors are identified with codes E67, E69 and E79.
Once you identify which error the Xbox 360 1 red light message is pointing to, fixing it is really easy. The guide available at Fix-xbox360.info will tell you what to do in each case, as well as what to do in case you get any of the other Xbox 360 lights messages. Check it out.
