Question about Dell E171FPb 17" TFT LCD Flat Panel Monitor
Starting up the computer the screen is white.
I cleaned the dust out of the computer and now when I start it up the screen is just white.
  • 458 Answers
Did you take the video card out and clean the slot before you put it back in? What did you clean it with? The can of dust stuff will ruin a computer, because it just blows the dust to other parts of the computer. Use a vacuum cleaner or a dry vac instead.
Posted on May 29, 2008
Hi my computer have problem in starting. few days
Disconnect the power from the diskette-drive, from the disk-drive, and from the CD/DVD devices. Then, try to start your computer.
If it still fails, then try a different power-supply.
Dec 08, 2009 | Asrock K7VT4A-Pro Motherboard
How to clean electronic equipment
<li>Unplug any cables or power cords from the electronic equipment before working on them. Remove any component cables leading to other devices.<br /> </li> <li> 2 Wipe down the electronic equipment with a soft damp cloth starting at the top of the device and working downwards. Wipe away any accumulated dust, lint or dander.<br /> </li> <li> 3 Use a small amount of isopropyl alcohol on a soft cloth to remove fingerprints from any CDs or DVDs. Work from the center of the media outwards. Do not rub too hard or in a circular motion.<br /> </li> <li> 4 Clean a LCD television or <a href="">computer</a> monitor screen by wiping a damp cloth gently across the screen once all power is disconnected. Wipe down the ventilation area to remove any dust. Clean the base with the same cloth.<br /> </li> <li> 5 Open a computer case by removing the screws that hold the side in place. Blow dust and debris from the interior with a can of compressed air. Start at the power supply and blow through the rear ventilation fan. Continue to dust the motherboard, component slots and case.<br /> </li> <li> 6 Insert a compact disc cleaning disc into CD and DVD players to better clean up these electronic devices from the inside. This cleans the interior lenses, removing dust accumulation that can lead to early device failure.<br /> </li> <li> 7 Rub down an MP3 player with a soft cloth and a small amount of ammonia-free glass cleaner. Use a cotton swab to get into crevices and hard to reach areas that trap debris.<br /></li>
on Dec 16, 2010 | Audio Players & Recorders
MS-7250 (v 1.4) completes Win 7 install, but hangs up at the "Starting Windows" screen after reboot. All systems passed upgrade advisor. NOthing connected to mobo, only vga monitor, keyboard, mouse. No...
See if you can enter SAFE MODE. After turning on the power watch the screen and when you first see Starting Windows press the F8 key several times until you see a menu, select Save Mode. If the computer boots to save mode, it's probably just a driver problem.
Nov 09, 2009 | MSI K9N Platinum Motherboard
My Acer keeps freezing then turns into black screen
lag of system resources u may b running a high performace game
May 31, 2009 | Acer Aspire 5600 Series 5610-2013 Notebook
White screen
I have a gameshark as well and this happened to me a few times try blowing a fan into it and into your game this worked for me it was just a ton of dust.
May 17, 2009 | GameShark SP for Game Boy Advance
Computer won't start
remove the ram and blow air and clean it in case dust might be formed
fix it and clean the system once and check all socket fittings once and turn it on
Mar 15, 2009 | Computers & Internet
We have a Toshiba multimedia projector. Model #TDP-S8. Use app. 3 hours weekly for church services. Three weeks ago, started with changing color. White looked lavendar/gray, etc. Now it consistently has a...
it needs a good service .all that needs to be done is open the top cover, the main board , clean all the dust possible.there is a glass dlp , clean it with a soft cloth ( like the one used to clean specks).on refiiting the main board make sure to firmly press the 100 pin black connector on the dlp board engine.this is the cause of the vertical flashy line
once repacked start the should work fine!!!!
Jan 10, 2009 | Office Equipment & Supplies
Monitor will not start
So, when the monitor is on, connected to the wall (not to the computer), there's absolutely no signal? no message on the screen? no colors moving? Have you tried with another power cable? You can try this test. Use the computer's cable to test if the problem is the monitor's cable.
Nov 19, 2008 | Dell XPS™ 600 PC Desktop
Looks like dust spots behind screen
I had the same problem and had a tech check it out.
It turned out to be dust on lens and mirror.
cleaned them and good as new.
Ihope this works for you.
Dec 29, 2007 | Sony Grand WEGA KDF-50WE655 50" Rear...
When switching TV on screen turns white and after 30 seconds switches off
This likely has a 10 ohm resistor on the CRT board that is open.  This feeds 200v to the cathodes of the CRT.
Oct 24, 2007 | Televison & Video
Dell E171FPb 17" TFT LCD Flat Panel Monitor Logo
126 people viewed this question
Alun Cox
