Question about Transcend T.sonic 610 MP3 Player
Power On Issue!!!
I tried the volume + button option... Dint help....
  • 8,596 Answers
You may want to call Transcend and find out if there is a button other than volume + that will force the player into Recovery Mode. Also, keep this in mind:
T.sonic cannot operate after it was formatted in Windows
Formatting T.sonic using the “Quick Format” or “Full Format” option in Windows destroys the
default format of the T.sonic. To retrieve the default format, you must link to
http://www.transcendusa.com/ and download the firmware updates for the T.sonic.
Transcend’s Tsonic Mp3 players:
http://www.transcendusa.com/Support/DLCenter/index.asp
Posted on May 30, 2008
When I try doing a hard reset. I can not get it to boot beyond the green Android guy. It shuts off or will not get me to the choice menu. Any suggestions?
On an android tablet of mine I have to hold the power and the volume (-) button down at the same time and keep holding them for about fifteen to twenty seconds until finally a menu with green text comes up. To select the text option I want, I have to scroll with the volume (+) button and when I'm on the right option I have to activate it using one short push of the power button.
The option I choose to do a hard reset is *wipe data/factory reset*. On my tablet, when I choose and activate this option it takes me to another screen with about six lines of *no no no* text and one line of the reset option. I have to scroll to the reset option using the volume(+) option and again use a short push of the power button to activate it. Then, it does it's thing and turns off. I then give it about ten seconds and then I hold the power button down for five or so seconds and it then it reboots to factory fresh condition. It takes a couple of minutes to get it done I guess because it's reloading all the apps, etc.
Mar 28, 2015 | Kocaso M1050
How do I turn on my rca tablet I tried everything I put on the charger , I keep my hand on the power botton it still wont turn on please help me
You need to do a factory reset, follow these instructions:
Step 1. With your tablet turned off, press and hold the volume up (+) button. While holding the volume up (+) button, press the tablet's power button until you see the RCA logo with Nipper and Chipper on the screen. After a few seconds, the screen will change and you will see the Android bot on his back with a caution symbol above him.
Step 2. Now you are going to press and hold the tablet's power button, and without releasing the power button press down on the volume up (+) button. You should then see the screen below.
Step 3. Use the tablet's volume up (+) and down (+) keys to navigate to and select the "wipe data/factory reset" option. To select this option, press the power button.
Step 4. The tablet is going to ask you to confirm your selection. Use the tablet's volume up (+) and down (-) keys to navigate to and select "Yes - delete all user data." Once again, use the power button to select this option.
Step 5. At the bottom of the next screen, you will see "Data wipe complete." Press the power button to restart the system.
Dec 31, 2014 | RCA 7" Dual Tablet Travel Dvd Cd Jpeg...
I have no volume no sound Would a Hard Reset fix this problem?
A hard reset is worth a try but it is unlikely to fix the problem, it sounds like a hardware issue.
Here are instructions for a hard reset
Make sure the tablet is OFF.
Press and hold the Volume Up and Power buttons at the same time.
When the Android starts to flash, release the buttons.
Then try to press different hardware buttons until you are given a list of options.
Note: If Volume Up and Power doesn't work, try Volume Down and Power.
Dec 25, 2014 | Craig CMP741d Tablet
How can i switch on back my lenova k1 android tablet that wont turn on?
Hello Ruth
If you tried the reset and it didnt work then most likely it wont come back to working again. Does it give any sign that it trys to power on?
Chadman
Nov 22, 2014 | Lenovo IdeaPad K1 10.1 inch Tablet NVIDIA...
I have a Craig 7 inch touch screen tablet it comes on but doesn't load
Dear Craig User,
I understand your delima with this tab, however unfortunately this product doesn't carry a very good market reputation.
For the kind of issue you are facing, I would recommend a reset (Hard reset) for which you may follow the following procedure.
Post your update, let us know if it helped.
Regards,
Sid
Nov 12, 2014 | Tablets & eReaders
How might I fix or remove freezing/hanging issue with both factory installed and playstore apps and wigets on an unlocked motorola mb855 running android 2.5 without use of a computer and free?
here
You can try to restore the Motorola Photon 4G MB855 like this:
  1. Enter into your phone settings by pressing the Menu button.
  2. Choose Settings and then select Privacy.
  3. Now select Factory Data Reset and then choose Erase Internal Storage.
  4. Lastly, select Reset Phone.
motorola-photon-4g-mb855-hard-reset-300x279.jpgFor those that are unable to use the Android system, mainly because the phone refuses to boot normally, you can try to restore the MB855 using the recovery menu. Here's how it's done:
  1. Turn off your phone and then press and hold the Volume Down Button.
  2. While holding the Volume Down button pressed, tap on the Power Button and the Fastboot menu of the Android system should appear on the screen. This is the point where you should release all buttons.
  3. Use the Volume Down key to navigate through options and when you see "Android Recovery", chose it by pressing the Volume Up button.
  4. Once the triangle sign appears, press both the Volume Up and Down keys, at the same time.
  5. In the newly appeared menu, navigate using the Volume buttons to Wipe Data / Factory Reset, and select this option by pressing on Power.
  6. Confirm your option by selecting Yes, once again with the Power button.
  7. Wait for the process to complete and reboot the phone.
gooluck...
Jun 21, 2014 | Cell Phones
How do i reset my samsung galaxy 3 if it wont come on?
1. If your Samsung Galaxy S II is frozen, Shut the POWER OFF, take the battery out and put it back again.
2. Hold the Volume Down button
3. Briefly Press and release the Power button
4. A menu will then appears that let you allows for Fastbook, Recovery, Clear Storage, and Simlock
5. Select Clear Storage by pressing the Volume Down button
6. Quickly Press and release the Power button
7. Select Volume Up for YES and Volume Down for NO
If the above procedures doesn't work. try this another method:
1. Turn the POWER OFF, pull the battery out and put it back again.
2. Simultaneously press the Volume Up, Home and Power button
3. If the Samsung Symbol appears, release the Power button
4. A Boot Menu will then show, Use the volume up/down to choose and home to select.
May 30, 2014 | Samsung Galaxy S GTI9000 Smartphone
Micromax a90
Hi, try these. press power and volume down button for 10 sec. Then try to power up it by briefly pressing power button. if fails, press power and volume up, be carefull , when the screen comes live - not to select any other option but only normal boot. To select a option press volume up button, it will power off, then power on again by pressing power button. it may fail by keep trying and in between keep charging ..
Thanks
Jan 16, 2014 | Android Cell Phones
Reset tablet
Hello,In order to hard reset your tablet, the steps given below must be followed:
  • Ensure that the tablet is powered off.
  • Press the Power and the Volume Up button together till the device displays the start-up logo.
  • Once the logo is displayed, release the buttons and wait till the device enters the Android system recovery mode.
  • On the displayed screen, use Volume Down button to go to the wipe data/factory reset option (Volume Up and Volume Down buttons are used to highlight the displayed options on the Android system recovery screen).
  • Once the option is highlighted, press the Power button to select the option. (Pressing the Power button in Android system recovery mode selects the highlighted option.)
  • On the next screen, press the Volume Down button multiple times till the Yes -- delete all user data option is highlighted.
  • Press the Power button to hard reset the Samsung tablet device while clearing the dalvik cache along with the process.
Hope this helps..
Jan 12, 2014 | Computers & Internet
I am using a new siemens desk telephone. I dont know the model number & they dint give me the manual. I just could not reduce the ring tone volume. Any help on this is highly appreciated. I am...
Just look at the bottom of the phone, you will find ringer tone volume marked with low & high. Put it to low. For the manual, see the bottom-side of the phone to locate the model number & search the Siemens website for the manual.
sonunny
Jun 30, 2011 | Cell Phones
Transcend T.sonic 610 MP3 Player Logo
56 people viewed this question
Top Transcend Audio Players & Recorders Experts
Gyula Lacz
aliasger yq
Are you a Transcend Audio Player and Recorder Expert? Answer questions, earn points and help others
