Question about Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV
Our tv has developed a yellowish vertical oval in the center of the screen. I saw another post that shows it's probably the optics engine. Is this the same issue?
  • 10,594 Answers
Yes, its optics block problem that will be replaced to resolve picture issue.
Posted on Oct 07, 2010
Hitachi model 60v500a.the middle of the screen is a little yello
If you Google "60v500a light engine" you will learn a few things about this set which was first sold in 2003.
There are some class action lawsuits out there for several Hitachi models made at about the same time.
Most of the time these sets develop a discolored area fairly large in the middle of the screen---a lot of them had a large red or pink oval area but other colors are possible.
This set uses a LAMP for the light source and it directs the light into the optical light engine--at the top of the engine is a 3 inch lens that the picture comes out of and is directed into the mirror which puts it on the screen.
Lots of these sets develop a "burn" inside the engine from the heat--there are a series of lens and baffles inside---even slight separation inside will change the color in some area of the picture.
I am sorry to give you bad news but I have replaced a lot of these engines under extended and when they were new mfg. warranty.
The part is no longer available from Hitachi new--the only way to get one is to remove the one in the set and have it sent out for "rebuild" and the last time I saw one the engine was over 600 dollars at the wholesale level not counting the fact that it is major labor to replace.
Find someone in your area familiar with Hitachi and this model and you will see what I am talking about.
Even though this is not good news, I think it is what your problem is.
If this helps you, rate this solution as I do this here for FREE.
SD TECH
Nov 14, 2009 | Hitachi 60V500 60" Rear Projection...
I have a problem with my kdf-e50a10 sony wega. When i watch TV i see a yellowish vertical line right in the middle of my tv is like 10 inches wide, all the way from the top to the bottom of the screen. Any...
Optical block failure. There was an inherent problem with the optical blocks for this TV and Sony has yet to issue an extended warranty for this model. The only way to fix it is to replace the whole optical block. This is very costly ($1000+) and time consuming (need to take whole TV apart).
There is a pending class action lawsuit for this exact problem. Link to the lawsuit website: http://www.sonya20tvclassaction.com/main/home.sfx
Oct 07, 2009 | Televison & Video
Hello! I have a problem with my kdf-e50a10 sony wega. When i watch TV i see a yellowish vertical line right in the middle of my tv is like 10 inches wide, all the way from the top to the bottom of the...
This is caused by a failure of the optical block of your TV. The only way to fix the issue is to replace the whole optical block which is very expensive ($1000+) and time consuming (need to take whole TV apart to replace the part).
The optical block in your model had inherent issues and there is currently a class action lawsuit pending against Sony for this issue. Up to date information reguarding the lawsuit can be found here: http://www.sonya20tvclassaction.com/main/home.sfx
Oct 07, 2009 | Sony KDF-E50A10 50 in. LCD HDTV
Yellow/green tint moving toward the center of the screen
Bad news the blue uv cut filter is discoloring its in the optical engine.
You are one of the many sony tvs that have this problem.
GOOD NEWS - sony will pay for yours
http://esupport.sony.com/US/perl/news-item.pl?news_id=115&mdl=KDFE42A10
Thanks
scott
May 08, 2009 | Sony KDF-E42A10 42 in. LCD Television
Yellow hue circle in middle of screen. after leaving tv on all night
spherical or oval shaped light starting in the center of your picture is an indication of an led backlit tv.. probably a hitachi. solution, replace light engine..ps no garuntees not with led backlit sets.. was bad idea to begin with. when the leds start going they start at the center and branch out.
Apr 13, 2009 | Hitachi 50V715 50" Rear Projection...
Yellowish tint on JVC Rear projection TV
I found out it was a bad light engine. The repair cost is $1,700. I'm glad it's still under warranty.
Apr 10, 2008 | Televison & Video
Vertical line down the center of screen
A WD62827 is a V30+ chassis and is a DLP format projection screen Tv, not a flat screen, am I missing something?? For the symptoms you're describing with a WD62827 remove and reseat the DVI cable between the chassis and optical engine. If removing and reseating the DVI cable does not resolve the issue you may need to replace the Optical Engine part # 938P019020
BTW the current software version for this unit is 7.04.1F if you have anything less you might think about updating the software also..
Hope this helps!
Bill
Nov 29, 2007 | Mitsubishi WD-62827 62" Television
DLP TV: Left half normal, vertical 6" band center is gray, right half almost black. What's wrong?
No. The optical engine is OK. You need an adjustment in the light tunel. Call a tech to do it.
Nov 06, 2007 | Samsung DLP HL-P4663W 46" Rear Projection...
A line on the screen
Is the line perfectly strait? Is it seem to be yellowish in color? If it seems yellowish then the light engine is the problem is the blue panel is defective. Sony covers the light engine for two years. The labor you will probably pay for but, not bad concidering the part is 1000.00 or more.
Feb 01, 2007 | Sony KDS-R50XBR1 50" HDTV
Sony Grand WEGA KDF-42WE655 42" Rear Projection HDTV Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
