Question about IBM Computers & Internet
I am getting a message that reads something like "Realtime Clock Error # ?" And then the machine will not operate even so much as to loak the OS.
    President:
  • 1,149 Answers
Hi:
usually this error is caused by your CMOS battery being dead.
You can verify that by getting into your BIOS and checking the date and time on your laptop.
If they are wrong, then usually that is the cause. Replacing that battery varies by model, but usually, if you go in, set the time, and save it,and the laptop is still powered up, the time will stay accurate, enough to load an OS, and once you unplug it, will need reset again.
Posted on Oct 07, 2010
Hey guys, I have a interesting question for you... Every time I open any program of any sort (except for internet explorer) it doesn't even open, just gives me this "encountered an error blah blah...
what are facing is a problem caused by a virus that either destroys files that support .exe applications to run or it replaces which makes your machine unstable. my first solution to you is to repair your operating system using the operating system cd. secondly, if that doesn't work please try installing a second os on your system and then you do a dual booting. u then delete the folder of the previous os. if that does not work u backup ur files and then you format ur system with a new os
Jul 28, 2011 | Dell Latitude D531 PC Notebook
I have an olde Dell sx260 w/bad HDD. I have the Product Key but no disc. I thought I could dowwnload XP SP3 and burn it to CD. The one microsoft site I saw, said the file was less than a GB for a...
Yes, XP has large patch packages since they started bundling along preview product revisions, free security stuff, .net runtimes, codecs, extra drivers, etc. You'd have to be burning it to USB flash or DVD+Rs then, wouldn't you? Either one will do!
Moreover, why wouldn't you pick a current OS that can run on that hardware, like Ubuntu 10, or Fedora 15, a bsd, or a realtime OS, or even Haiku? It rather depends on the actual specs you have in that machine and what you want or can expect to do.
Jun 05, 2011 | Computers & Internet
Hard disk drive not opening
Best is not to partition your Hard Drive to more then 4 partitions. If you are going to install more than 2 Operating Systems(OS) on your hard drive,be sure to set your partition to "active" for the intended OS before formating. If you set to more to 4 partition, most probably your OS will not be able to read the partitions and that are the reasons you are getting the errors.
Jul 30, 2010 | Microsoft Windows XP Professional SP2
NSIS Error & missing graphics
Read the tutorial from "nsis.sourceforge.net" - "Why do I get NSIS Error" @ http://nsis.sourceforge.net/Why_do_I_get_NSIS_Error
Hope it helps.
Jul 24, 2010 | Microsoft Windows XP Home Edition
I'm getting the error message LE which says motor overload. I've read some comments on line that people have drained the water unplugged the machine for a couple of hours and the error message went away...
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thanks
Jul 14, 2010 | LG WM-1832C Front Load Washer
Stock quotes in Excel
Kindly check if this is of any help to you.
support.microsoft.com/kb/274787
Regards,
soul_srch007
Nov 25, 2009 | Apple Mac OS X 10.4 Tiger for Mac
I bought the Kodak ESP3 because I love the features. I can not get the installation disk to start. I get a message error (the 32bit operating system required is above Window XP Sp2 The 64 bit operating...
Need pc and os specifics. Does you pc/os meet mimimum specs ( listed below) ?
If so, try the web installation at www.kodak.com/go/software
  • MICROSOFT VISTA or WINDOWS XP-Home (SP2 or above)
  • CPU: Celeron
  • Clock speed: 1.2 GHz
  • Memory: 512 MB
  • Hard disk: 200 MB free
  • CD-ROM
Apr 08, 2009 | Kodak EASYSHARE 5300 All-In-One InkJet...
Hi, I get an error message when I try to connect and install a Maxtor 500 GB external hard drive to my computer. The message reads "the device cannot start (Code 10). Can you assist?
What is the error message you get?
What OS are you using?
Depends on your hard drive, some computer commonly ask for a driver when you plug something in it. might as well try reading the manual of your external hard drive, if it doesn't require a driver, then the problem "might" be in your operating system and/or in your computer.
Sep 26, 2008 | Computers & Internet
Un loak my nokia n73
hello there....well its quite simple...there is nothing wrong with your phone ...its your SIM... if it is asking for a PUK (Personal Unblocking Key) code...call your subscriber and ask them for PUK code,entering this code will reset your sim
if u keep entering wrong your sim will be damaged so call them
If the error message is saying sim damaged call them and ask for a "sim replacement" you will get a new sim while you will retain the same number ,however you will lose the phone numbers and other data stored in sim,this can be free but it depends on the company and how 'customer friendly they are
Hope this help
Cheers
Jul 31, 2008 | Nokia N73 Cellular Phone
Error message
Details please. Computer Type Operating System etc. Try booting from your OS CD, and see if you can get to a recovery console or DOS prompt and read the drive.
Jan 01, 2007 | Seagate Barracuda 7200.7 80 GB Hard Drive
Computers & Internet Logo
35 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
