Question about Sony Video Cameras
Tape cartridge doesn't go back into carmera.
I have a Sony DCR PC1000E video camerma. Recently I have problems getting tapes in and out. I finally got a tape out tonight, but can't get the cartridge to go in again. Need fixing urgently, as I need to leave the country soon. Am in Brisbane for a few more days, where can I get help?
  • 10,594 Answers
Brisbane in Australia? if yes, see following link of Sony Australia.
http://www.sony.com.au/support/service/index.jsp?categoryId=21640
Posted on May 29, 2008
I have a tape in my Sony dcr-trv 350. It will not eject out for me. Door will open but tape will not come out. I can still record on my tape. How can I get this tape out? I don't want to loose what I have...
the camera has been dropped
or pressed by a heavy object or person
open the door
put down on the tape
move back and forth with significant pressure
caring not to destroy the eject lock mechanism
do it several times
I had the same problem with my sony
Nov 03, 2009 | Sony Handycam DCR-TRV350 Digital Camcorder
Sony DCR-TRV460 not playing back, blue screen
Follow this procedure to troubleshoot if a blue screen is displayed when attempting to playback video from the camcorder.
  1. Stop the tape.
  2. Ensure the tape has been rewound to the beginning of the video recording.
  3. Play the tape.
  4. If the issue is not resolved, stop the tape and remove it from the camcorder.
  5. Clean the video heads of the camcorder using a dry head cleaning cassette.IMPORTANT: Follow the instructions for use provided with the head cleaning cassette. It may be necessary to use the head cleaning cassette more than once per session.
  6. Reinsert the tape into the camcorder.
  7. Play the tape.
  8. If the issue is not resolved, stop the tape and remove it from the camcorder.
  9. Insert a different tape with video footage into the camcorder.
  10. Ensure the tape has been rewound to the beginning of the video recording.
  11. Play the tape.
NOTES:
  • If a blue screen is still displayed, then the camcorder may require service .
  • If the tape plays back correctly, then the first tape may be faulty or there is a problem with the video recording.
Aug 13, 2009 | Sony Handycam DCR-TRV460 Digital Camcorder
Video and audio play back is choppy
OK, yes, it probably does relate to a tape tracking problem, but does knowing that help you out at the moment, I had this same problem and I scanned for solutions and somewhere I seen this remedy and it worked, remove the battery and take your open palm and give it a sharp rap at the bottom rear corner, a good solid one but not enough to damage the cam. Hope it works for you.
Jun 21, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
The tape ejector is stuck up with the door closed and the tape is stuck in it and I cant get it to move down or open. What is the problem ? When I try too I get a beeping and blinking with C:32:21 on it....
Hello... The way I can get a tape unjammed on my Sony camera2.gif is to remove the battery, plug the camera into the AC charger that is plugged into the wall outlet. Then power the camera on, wait a few seconds. Then unplug the charger from the outlet, wait a few more seconds (camera still in "on" position) and then plug it back in. I have used this method at least 3 times to get the camera to release the tape and finally eject. However, the tape is usually pulled out or stretched and I use a small flat head screwdriver to wind the tape back in, but expect that portion of the video to be ruined and I don't recommend using the tape in the camera again even if you manually wind it forward past the problem area.
Hope this helps!
Apr 02, 2009 | Sony Handycam DCR-TRV310 Digital Camcorder
Problems viewing Hi8 tapes
Seems video head of your handy-cam is dirty or clogged. Use good quality video head cleaning tape to clean video head.
Oct 21, 2008 | Sony Handycam DCR-TRV280 Digital Camcorder
Camera will not insert tape. Mechanism works OK without tape. Sony dcr-hc42
A C31:40 error indicates that the drum (the spinning video head) is either not spinning or is not supplying a signal to the main computer to tell the computer it is spinning. It could be a bad drum or a loose connection. It will likely take a qualified technician to verify the diagnosis.
Oct 20, 2008 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony DCR-HC40E Tape Holder Mechanism load failure
Your camera needs Mechanism replacement.
Software CD is available on charge basis.
Apr 30, 2008 | Sony Handycam DCR-HC40E Mini DV Digital...
Sony dcr-trv120 playback
the problem is with the video head. either it's dirty or broken. if cleaning tape is not solving the problem then i fear you have to get the head changed. an expensive repair.
Jan 18, 2008 | Video Cameras
Camera will not accept mini-dv tape anymore
Hello dear sir;
I have SONY handy cam(model 42E) that finger touch keys doesn’t work .what do I do now.
Please help me and send a procedure to repairing.
I am Iranian mechanical engineer.
Oct 24, 2007 | Sony Handycam DCR-HC42 Mini DV Digital...
Video Cameras Logo
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
