Question about Kitchen Ranges
The ice maker on the GE model refrigerator GSS25WSTA SS overfills the internal ice storage and has to be emptied twice daily regardless of how many times the ice is fed through the front. Is there an adjustment that can be made to correct this?
SolutionGuy
  • 331 Answers
SOURCE: GE 25 side by side refrigerator ice maker problem
Assuming the temp inside the freezer is at around 0 or -2 degrees, it should dump ice every ~50 minutes or so. Again, depending on temp's, an Ice Bin should fill within 24 to 48 hours. If your freezer temp is running at around 10 degrees, everything will obviously still be frozen (below 32), but the ice maker will take longer to freeze the water than it would if it were at 0 degrees. Open both doors and place the palm of your hand on the partition between the freezer and Fresh Food compartments... (where the door gaskets seat when they're closed). The temp of the partition should be about 5 or 10 degrees warmer than body temp., If it's hotter than that, you found the problem. Either the condenser coils are dirty and need a good cleaning OR your condenser fan motor (the fan in back, near the floor in the compressor area) is failed or about to fail.
Posted on Jul 29, 2007
  • 161 Answers
SOURCE: GE model TFX22R ice maker problem
First clean out the condensor coils. If you have pets it should be done at least 3 times a year. The other possible problem is if the gasket in either the fridge or freezer is worn out or has a gap it will not cool properly. Check that the fan underneath the unit by the condensor coils is running when the compressor is . Some smaller refrigerators have only condensor coils on the back and no fan. These units should have room for air flow on top and sides not built in flush with cabinets. Buy a thermometer for both the fridge and freezer compartments. You run the risk of food poisoning if the fridge temp can not be kept below 40 degrees. Freezer temp should be able to keep at least 0 - 5 degrees. (Ice cream is a very good indication of proper temp. It is the first thing that melts. Ice maker is a close 2nd.)
If these things don't work call for repair. Don't risk losing all your food!
Posted on Jul 03, 2008
  • 358 Answers
SOURCE: the ice maker on our GE refrigerator does not make ice
1 -Ice maker arm must be down(on position)2-Make sure the water supply line is connected to the fridge3Check if the ice maker is plugged in4The freezer must be working fine for the ice maker to produce ice. After the ice maker stars and calls for water and doesn't get any , the water valve is bad.And if everything above is ok the ice maker needs to be replaced.
Posted on Apr 26, 2009
  • 15 Answers
SOURCE: Ice Maker Overfills With Water
Ice maker has adjustment on right side of power head. If ice maker is inside on upper left, you can remove white cover from it and the adjusting screw in on right. Turning counter-clockwise will decrease fill by 1/2 to 3/4 of ounce. Sounds like a small amount, but ice make only uses 4 ounces per fill. If this does not fix, try replacing fill valve. If ice maker ice bin is in the freezer door, you have to remove cover to ice maker in the top of freezer. Ice maker is screwed into top of freezer and need to be removed to take off cover to adjuster screw. same procedure for reducing water flow time as above.
Posted on Jul 24, 2009
SOURCE: GE refrigerator ice maker model can9 stopped
The schematic to my CAN9 is cast into the front cover.
Posted on Apr 04, 2010
My Whirpool Ice Maker Model GI15NDXTS won't stop making ice
check bin thermistor connection or replace it is inside the bin on the right side
Aug 04, 2012 | Whirlpool Gold Series GI15NDXT 15"...
Model TFX25PR ; Does the ice cube maker require any lubrication ?
The type ice makers made for your model and other models require no lubrication and are one of the most used parts of your refrigerator especially if there is a large family and lots of ice used daily. They never seem to stop working while the average refrigerator last 15 to 20 years the average life of an ice maker is only 5 years. Even ice makers that have replaceable parts the repair parts are more expensive in most cases than complete replacement. Below is an example of an average ice maker that Whirlpool and Maytag uses that have the Teflon coating in the ice slots. Your model is for GE,=> Model WR30X10093 Ice Maker and has electronic controls and no replaceable parts. Thanks, Sea Breeze
Jun 05, 2011 | GE Profile 25.6 Cu. Ft. Side-by-Side...
GE MONOGRAM ZFS826DRC SS ice maker not working
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Mar 06, 2011 | GE Monogram ZISS480DRSS Stainless Steel
OUR MODEL #PSS27SGRC SS.REFRIGERATOR DOESN'T PRODUCE ICE. WHAT CAN WE DO?
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Oct 29, 2010 | GE Refrigerators
I have a side by side model number ED20TK and
start over on ice. if it over fills change valve
Feb 07, 2010 | Refrigerators
I have model 3XART720F02 ART706 TYPE 2055A The water ice distribution area needs cleaning. Can this area be dismanteled
Prepare the Ice Maker For Cleaning
Step1Lift the power located above the ice maker storage tray.
Step2Unplug the refrigerator.
Step3Allow the refrigerator and to defrost. This will melt any large blocks of ice that have accumulated in the ice maker
Clean the Ice Machine
Step1Remove the ice machine storage tray.
Step2Dump any water in the ice machine storage tray.
Step3Wash the ice machine storage tray using warm, soapy water. Rinse and allow to dry completely.
Step4Sanitize the lines of the ice maker. Consult your manufacturer's
directions for steps to do this, because it's not available on all models.
Reassemble the Ice Maker
Step1Replace the ice machine storage tray.
Step2Plug the refrigerator into the outlet to restore power.
Step3Lower the internal power bar located just above the ice machine storage tray. This allows the ice machine to make new ice.
How to Clean an Ice Maker
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Aug 21, 2009 | Whirlpool Refrigerators
GE Profile Fridge Model No. PSC25MSWA SS not making ice
Check to see if there is any obstruction (object of any kind) in the ice cube mold area. If nothing found, you will have to replace the icemaker, as individual repair parts are not available.
Aug 04, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Refrigerator not making alot of ice cubes
a bad valve will make them stick togather and sometimes hollow but the ge is well known for the back board being bad
Mar 18, 2009 | Refrigerators
GE Side-By-Side Refrigerator Model GSS 23QSTA SS
Apparently the digital read out sensor is bad. 45°F is to high for safe food storage. The fact that the milk spoils is another factor which speaks on its own that there is a temperature control problem. There is no "defroster fan". There are two fans in the unit. One is the air circulation fan located inside the freezer compartment and the other is the condenser fan for cooling the refrigeration system. If you had called for service in the first year it would be covered by warranty with the exception of the service call charge. After the first year ends electrical and control problems are not covered. If the evaporator fan in the freezer is noisy there is something wrong with it. It could be the source of your whole problem.
Mar 27, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ge top freezer refrigerator ice maker problems
most likely bad icemaker but could be a leveling issue or overfilling which both would be very noticable
Jan 04, 2008 | GE Â 17.9 Cu. Ft. Top-Freezer...
Kitchen Ranges Logo
65 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
