Question about Ryobi Garden
Replacing fuel line on trimmer model 775r - have have removed all the fuel lines and the bubble, but have forgotten the exact pattern to replacing the three fuel lines
    Problem Solver:
  • 5 Answers
Hi: I'm a new user to this forum. I recently had to repalse the 3 fuel lines on my ryobi model #775r. After researching the problem, I diagramed the flow of fuel in order to repace the fuel lines. If you require a copy of this diagram, send me an email . Regards, Tony
Posted on Mar 27, 2012
  • Ryobi Master
  • 1,169 Answers
Here is a basic fuel line plumbing diagram. Note: the carburetor model may not be the one you have but it should you a good idea of you need to do.
replacing fuel line on trimmer model 775r  - have - 6314437-vqyl0wumkkqskh4plnma1yru-4-0.png
Posted on Apr 07, 2015
  • 1,041 Answers
Here is a Link to one of my Tips:
www.fixya.com/support/r6078121-fuel_line_relacement_trimmer_weedeater
The third fuel line will be short and will go from the carburetor to the primer bulb.
Good Luck!
Jim
Posted on Oct 07, 2010
Why wont the gas go in the bubble of my stihl F5 85 weed wacker un less i block the return fuel line ?
Most likely has a leak in the system, I suggest replacing the bulb as well as the lines, replacements are usually fairly cheep.
May 29, 2014 | Poulan/Weed Eater No. Te475 952711797 17"...
Replacing fuel line on ryobi 775r trimmer. when i removed old line and filter, the plastic fitting with the filter protruded about 1/4'' out of tank and was held by plastic retainer ring, now i can get the...
First off, get a piece of fuel line longer than you need for the job. With the gas tank removed, wrapped in a towel and put in a vice to steady it I fed the gas line in from the outside of the tank to through the fuel hole (where the gas cap fits on). I carefully worked the fuel line onto the filter until it was all the way on (touching the bottom of the filter assembly). I then gently pulled on the line feeding it through the hole. Then with gentle pulling, twisting and nudging from inside and outside the tank I worked the fuel filter nipple through the hole on the bottom of the tank until it was flush and secure.. Once the filter and fuel line were secure in the hole on the bottom of the tank, I then worked the secure ring up the fuel line and worked it onto the filter stem until it was snug. I then fed the line through the appropiate holes in the engine, trimmed it to size and fitted it on the nipple on the engine.
Jul 03, 2010 | Ryobi Garden
Stalls when giving gas
This symptom is usually lack of fuel to the engine, if you see bubbles in the fuel line replace all of the lines and the fuel filter (inside the tank). If there are no bubbles in the fuel lines the carburetor needs to be cleaned out or replaced.
May 26, 2010 | Craftsman 25cc Gas Line Trimmer
Need a diagram that will show the tubing feeds on ryobi weed trim
If you need a fuel line diagram for ryobi 775r let me have your email address.
tony
Oct 13, 2009 | Garden
Fuel line routing on ryobi 775r
One line ( the one with the fuel filter in the end of it) comes out of the fuel tank and goes to the lower port on the carburator. The second line goes from the fuel tank to the bottom fitting on the primer bulb. The third section goes from the top port on the primer bulb to the top port on the carburator. Hope this helps and best wishes.
Sep 01, 2009 | Ryobi 15" Electric Factory Reconditioned...
MY RYOBI 31CC 775R WEEDEATER WON'T START I REPLACED THE SPARK PLUG AND STILL NOTHING I DON'T THINK ITS GETTING GAS HOW DO I FIX OR REPLACE GAS LINES.
spary a little startingfluid in carb to see if it start if it start rebuild carb.to change fuel line
only if there dryrotted if it go thourght the gastank in little hold cut new line on a angle and thread through hold.hope helps you.let me know ok
Jul 24, 2009 | Garden
Ryobi 775r gas trimmer stalling when tilted
You have a air leak between to tank and motor. Could be carb gasket. When using in tilted position you dont have gravity feeded carb anymore, causing air to be sucked into carb. Take off carb and spray with crb cleaner, then blow out with air gun. Replace gasket, make sure all new lines and bulb connections are connected securely.
Jul 17, 2009 | Garden
RUNS AND STALL WHEN YOU GIVE IT GAS
you are right on. try richer mixture.
May 22, 2009 | Ryobi Garden
Garden Logo
1,347 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
