Question about Creative Labs Zen V MP3 Player
Z v plus stuck
I'v etried that reset button god knows how many times. it displays teh same song and none of the buttons would work. i let it run down to low battery and recharge it and restart it etc. and it still is stuck on teh same song. it wot even go anywhere else.
what should i do to completely format teh thing?
    President:
  • 4,402 Answers
Http://serviceman.site88.net/index_files/MP3Players.htm
Posted on Jul 01, 2008
Scanner pro 93
reset it one more time and let the scanner boot before you do any thing else chill out for while dont be so egor
Sep 26, 2013 | Radio Communications
My precore 9.43 starts to run then in 5 seconds turns itself off. Says ERROR- nothing more.
proceed according and fix it. God bless you
1 )Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 2
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
Jan 25, 2013 | Precor 9.4 Treadmill Motherboard Motor...
The Stat button is stuck down, have tried popping up with a paper clip but no good. Any suggestions, none of the other buttons will work with the STAT button stuck!
Hi
take out all 4 batteries take alcohol 2 drops on the button
push the button a few times it should help unless there is glue inside than yo must open the calc and clean all the buttons
Sep 12, 2012 | Texas Instruments TI-83 Plus Calculator
Zen stuck in recovery mode, reboot failed, firmware recovery tool downloaded and updated, reset button failed, last time this happend we had to wipe it totally off and start over, much time...
You can reset your zen by placing the pen head in the hole below the power button for 20 seconds.
Or
Attempt to slide the switch like you are shutting it down and then use a pin to reset the mode. By doing so all song could be washed out
Nov 28, 2008 | Creative Labs ZEN V Plus MP3 Player
None of the buttons work. I cant change songs or play it.
hold down the pause and center button for about 30 sec it will reboot
Oct 17, 2008 | Apple iPod nano
Froze
if there is a reset button on the back of ur nwz device bottom left on mine, poke the whole with a pin to reset, i should still have ur songs etc
Feb 23, 2008 | Audio Players & Recorders
Creative Zen V Plus Frozen on the product title screen
this helped me as after it rebuilds the libary then it always froze on a song let the battery run out!
this worked for me straight away and i had tried loads of other ideas this actually came from the tech guys !!!
  1. Detach the player from the PC if it is connected, and turn off the player.
  2. Press and hold the Play button while powering on the player.
  3. When the player displays the Creative logo, release the Play button
  4. Select Format (All) and select Yes to format the player.
  5. After the player has finished formatting, select Reboot.
  6. Re-transfer the tracks to the player.
Feb 16, 2008 | Creative Labs ZEN V Plus MP3 Player
Kenwood CD player KDC-MP825
Some units have a reset button, have you tried to reset the unit?
Feb 10, 2008 | Kenwood Sirius KDC-MP825 CD Player
Frozen
reset the Zen. Then hold down the play button and power it on. Release the play button when you see the Creative logo. It will display the following options: Clean Up Scans the player and removes invalid links from its music library. Does not affect music files themselves. Format (All) Caution! Erases all content! Save a copy of your player's content before formatting. Reload OS/ Firmware Caution! Erases your player's firmware. DO NOT select the Reload Firmware option unless you have access to a PC and you have downloaded the necessary firmware to install. Reboot Reboots the device.
Aug 15, 2007 | Creative Labs ZEN V Plus MP3 Player
Frozen, any help would appreciated
On the bottom left side there is a pin hole. Get a paper clip straighten the end and stick it in the hole. This is the reset button.
Feb 13, 2007 | Creative Labs Zen Touch MP3 Player
Creative Labs Zen V MP3 Player Logo
29 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
