Question about Vacuums
Need a new motor ronning modle #fb 8419 m12 - Vacuums
Schematic m12 circuit board
Also looking wiring schematic M12 Milwaukee charger
Sep 27, 2016 | Milwaukee tools Milwaukee Electric Tool -...
My Bissell 61c5-g started making a loud noise, vibrates bad, what can I check? I adjusted the height and it isn't connected there.
Most likely a bad belt. Contact Consumer Care at 1-800-237-7691 to order parts (detailed instructions comes in the package. To open the Belt area access panel you will need a flat medium sized screwdriver. There are two slots on the right hand side of the unit. Push the screwdriver into the lower slot and press the holding tab to lift the panel. The top tab should slide out easier but if it doesn't use the same process as the lower one. Examine the belts by rotating them all the way around (there may be two belts in your unit). I'd recommend if one belt is bad to replace both belts and keep the used one as a spare. Good luck. Hope that helped.
Oct 30, 2015 | Bissell Vacuums
Vacuume cleaner modle #N03052M When i plug it in
What type of unit is it...Epic, Renaissance, Guardian,etc?
Oct 09, 2013 | Electrolux Vacuums
How do i fit new carbon brushers to dyson dc14
It will be a pointless exercise Ron. By the time the brushes on a YDK DC14 motor have gone, so has the armature. You need to replace the motor. You can get a new motor here: Dyson DC14 new motor.
Also, be sure you change the filters; one of which is washable.
Nov 12, 2010 | Dyson DC14 All floors Bagless Upright...
I have a cannister vacume, Fuller Brush red model # FB-DCC when I turn it on it will shut itself off in about 30 seconds this will happen several times then it will not turn on. I do not have the owners...
First, the word is "VACUUM." Second, it's obvoius that your motor is overheating. When's the last time you CLEANED THE FILTERS, per the operating instructions?
Nov 07, 2010 | Fuller Brush Vacuums
I can't suck up the water
Please check that the round black rubber gasket is under the corner of the dirty water tank. it connects the tank to the motor vacuum source. it could have fallen off the plastic tube, and be laying under the plastic hood.
Nov 11, 2009 | Vacuums
Which new model replaces this model #11622612200
Ron, Kenmore assigns model numbers pretty much sequentially as they receive new inventory. There is no cross reference anywhere in the industry for their product except in their catalog. If you want to compare features you must do it that way to find a similar vac. If you are very luck you may find an experience Sales rep at Sears.
If this is a Kenmore canister , as they age the hose and wheels and wand connections break down. For a better designed or improved vac, look at a professional vac shop and look at all the spots which broke down on your old one. If there are feateures you like make note of them too and you should find similar features on a pro brand or at Sears.
One more thing, don't buy a new vac based on amperage. Amperage is consumption of power NOT output but its a big deal to advertise that way. it's only a numbers game. A 12 AMP vac motor with its suction fans removed is still a 12 amp motor, it just has no suction. Anyone who tries to sell you a vac based on amperage does not know there business. Best of luck. For a lighter easier running vac,better design look at Sebo , Miele, etc, as well. The Europeans are far ahead in design and filtration and durability
Oct 27, 2009 | Kenmore Vacuums
Water and clearen not coming out.
If the modle is an old modle the heater could be blocked,or if it a new modle try taking of the of the handle and ad a small shim to the bottom of the handle plunger to make it a little bit longer ,the plunger might not be reaching the valve,
also unscrew the clear cap which which is on top of the red spinner to see if the white filter under the spinner is clean and free from debris.
when you put the cap back on make sure its not to thigt and the spinner move freely, if the suction is poor make sure the red lint filter in the clean water tank is clean
Oct 20, 2007 | Bissell 1698 PowerSteamer ProHeat Upright...
Vacuums Logo
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
