Question about Dell E172FP 17" LCD Flat Panel Monitor
Screen flashes on for 1-2 seconds, then goes black. Power light shows green. A back-up CRT monitor works fine on same computer. Breaker problem? Any way to "reset".
  • 11,361 Answers
Follow Louie advices and you can also lookthrough my failed DELL monitors so you will know what you are dealing with.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
Failed TV and Monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Replacement board: http://www.lcdrepair.us
Please post back what you find.
Posted on Oct 08, 2010
  • 732 Answers
Pinestch, Hi, 12fixlouie here. Good going. At least you were smart enough to prove pc not at fault! If E172 had a nice, crisp, bright, colorful display before the "black screen of death" appeared on your old cold cathode fluorescent lamp, back-lit lcd monitor, you may just want to pay a visit to YOUTUBE!!! Watch some DIY lcd monitor repair video clips to see if you can attempt an internal investigation/repair of the CCFL inverter circuit or the main switch-mode-power-supply. Probable cause of "BSOD" symptom is failed electrolytic filter capacitors and/or a "thermally fractured" solder connection of a component to the circuit board. You and only you will be the one to decide what to do about E172 unit. If repair is option you choose, then here is cost berakdown. 1. DIY is $20 or less + your time! 2. Contract out repair for $35 to $65 plus parts. Do some reading in the FIXYA PROFILES of "budmrtn" "buddymc" "12fixlouie" and all the other CCFL monitor tech's here at fixya. Do some reading and surfing. This problem is not new one. Many thousands of inverters fail each year!!! Just remember to let us know what you will do with additional comment to this response after you do your research. 12fixlouie
Posted on Oct 07, 2010
    President:
  • 1,146 Answers
Your monitor most likely has a problem on the high voltage inverter circuit board, internally located in the monitor. They are prone to having capacitors that fail, and that causes the problem you are experiencing.. Often it is beyond economical repair, as a new monitor is a better investment.
Monitor flashes on then off power light stays on whats wrong?? shows screen for about 3 seconds then goes black
Some 22" Viewsonics will have worn out bulging capacitors in the power supply that causes this symptom.
Monitor Mike
Apr 14, 2010 | ViewSonic 22" FLAT SCREEN CRT BLACK...
Monitor goes blank less than a second after turning on.
Sounds like either there is a bad connection from the computer to the monitor, or the monitor has a faulty power regulator, causing the monitor to overheat prematurely, and shut off.
Feb 21, 2008 | Proview PL926WBi 19" LCD Monitor
Dell E172FPb monitor black screen green flashing power button
We have a dis-assebly and repair guide posted on our web site at:
www.ccl-la.com/monitor_repair.htm
The problem is usually the driver transistors, our guide shows where they are and what to replace to get your monitor back running again.
I hope this helps, If so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Jul 30, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Blank screen, flashing green light
Internal power supply is hurting. It is a non linear supply and they switcher transisters are not working
Jul 27, 2009 | Dell E152FP 15" Flat Panel LCD Monitor
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
do you have an aftermarket video card. In the bios you have to tell the computer if it is looking for a agp/onboard or PCI video card. Either that or the video driver or settings are wrong Try safe mode to check
Jun 25, 2008 | Dell Dimension 2400 PC Desktop
Beautiful screen, lasts about for a few minutes, goes black. Power button still green. If I turn it off, and then back on, it works again for a while. Any ideas?
May 11, 2008 | Mag Innovision LT982s 19" Flat Panel LCD...
I start my computer and turn it on, and everything looks fine for about 1/4 of a second and then it goes black while leaving the power light green. I can only see the screen again after turning it off and on, but that's only for another 1/4 second. What's up?
I got my rosewill flatscreen as a hand me down from my father. I've had it for several years now. Was working fine until a month ago. When I turn the computer on the screen goes black after 1/4 of a saecond. I have to turn it off and on anywhere from 10 to 20 times before it stays on. I have checked all plugs to the computer and outlets. I have absolutely no idea whats causing this.
Dec 28, 2007 | Rosewill R700J 17" Flat Panel LCD Monitor
Monitor flashes on and off!
Sounds like you have a bad connection from your monitor to your computer. First check and make sure the connection between them is tight. Does your computer boot up and run though? If your computer is not booting up the monitor will default back to the flashing green power light
Nov 29, 2007 | Dell E173FP 17" LCD Monitor
MONITER LIGHT IS GREEN BUT ONLY SHOWS A NORMAL SCREEN FOR 1/2 SECOND THEN TURNS BLACK
HI. I had the same problem with mine. It would flash the screen on for a split second and then turn black, the whole time the power light remained green. Upon opening up the case, I pulled the combo power supply board/inverter board out for inspection. I noticed one of the capacitors had a bulge on top indicating it was bad. It was the the 680uf 25v capacitor. I desoldered it, and soldered in the new one. After hooking everything back up, bingo!! Monitor now works perfectly. I couldn't find an exact match to the capacitance locally, but I had a 1000uf 35v cap in my utility box. It worked fine as a replacement. You can usually go within 30 percent of tolerance and be alright. Just don't go under on capacitance or voltage. I hope this helps.
Nov 25, 2007 | LG Flatron L1710M 17" LCD Monitor
Dell E172FP 17" LCD Flat Panel Monitor Logo
148 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
