Question about Imperial IFS40 Deep Fryer
Recovery time i have ifs40 deep fryers i use for potatoes at local events. They run on propane the problem i have is the recovery time it starts off cooking potatoes fast but an hour or two into the event the cooking time takes alot longer like it never recovers fast enough to keep cooking continously. i have been told that i can "tweak the fryer" to boost the temperature. what can i do to resolve my issue. Thanks spiral king..
    Scholar:
  • 68 Answers
If the unit starts off fine, and then loses some of it's heat, I would suspect that your regulator is freezing up. This can be caused be a bad tank or regulator. You'll have to swap it out to test it.
If the gas supply is good (reg and tank), you need to inspect the heat exchange tubes. Look where the flame shoots through the fryer. Use a flashlight. Look for LARGE amounts of black soot. If it is sooty, blow it out with compressed air. Once you get it cleaned out, you need to add more air to your mix. There should be a disk at the base of the burner.
If you have access to a manometer and orifice drills, you could adjust the flame to it's maximum. But as I said, I expect you have a regulator problem.
Posted on May 29, 2008
Bits left in pan and paddle when cooking chips
If you use fresh potatoes, try a different variety as some are a lot firmer than others.
For frozen chips, start cooking as soon as they are removed from the freezer and don't let them sit.
Jun 13, 2013 | Tefal ActiFry Deep Fryer
I am trying to switch a natural gas deep fryer to propane and cannot fimd the correct part
Hi there.
You can visit http://www.imperialrange.com , you can verify there the correct parts list for the model of your fryer for the conversion from natural to propane and you will be able to search there the nearest authorized parts and service provider in your area.
You will be needing burner orifice for propane, pilot orifice for propane (if available, if not, the whole pilot assembly), Gas valve spring for propane (if available, if not, the whole gas valve for propane).
Regards.
Aug 03, 2011 | Imperial IFS40 Deep Fryer
WE HAVE A NUMBER OF LPG IMPERIAL IFS40 FRYERS WITH A VERY LARGE FLAME ESSESIVE FOR THE UNIT FLAMES BURNS AND EXTENDS AT THE BACK OF THE FRYER INTO THE FLUE . WE HAVE CHECKED THE CORRECT INJECTOR , CORRECT...
check the burner orifice and gas valve spring kit if it is suited for propane use.remove carbon build up inside the fire tubes.check also if the gas pressure is correct.
Mar 11, 2011 | Imperial IFS40 Deep Fryer
HOW LONG TO COOK FRESH FRIES
Hi, W/D here.
Cooking time can vary, due to the moisture content of the potatoes that are being cooked. A good rule of thumb is to cook them until they begin to float, then to your preference of golden brown.
Hope this is what you need.
Best regards, --W/D--
Feb 09, 2011 | GE 168997 Deep Fryer
Imperial propane fryer won't stay lit.
check the high limit it tripping out
May 22, 2009 | Imperial IFS40 Deep Fryer
My imperial IFS-40 is burning the door
Is this fryer propane?It sounds like the baffles in the tank are clogged.If you remove a burner shine a light in the baffle,if you see alot of soot use a shop vac and clean it out.Let me know.
Apr 23, 2009 | Imperial IFS40 Deep Fryer
Want to change natural gas to propane
You need to change the regulator,gas valve and burner orfices and possibly the pilot.If you have a commercial fryer go to 3wire.com and you will find the part's you need.Any questions?
Apr 07, 2009 | Imperial IFS40 Deep Fryer
GAS VALVE TIMING OUT
I had a simular problem. The gas company disassembled the pilot light and cleaned it. The fryer works perfect now.
Hope this helps!
Ken
Oct 08, 2008 | Imperial IFS40 Deep Fryer
Imperial IFS40 Deep Fryer Logo
223 people viewed this question
Top Imperial Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Dan Webster
Dan Webster
Paul Carew
Are you an Imperial Kitchen Appliances - Other Expert? Answer questions, earn points and help others
