Question about Aastra Telecom 9116 Corded Phone
How do i set up my voicemail in this phone - Aastra Telecom 9116 Corded Phone
How do I retrieve voicemails? I have not set up voicemail yet.
If you haven't set up your voicemail yet, then there s no voicemail to retrieve. The mailbox will not accept calls until you set the mailbox up.
Dec 18, 2015 | Lands Phones
How do I set up voicemail
Usually, all you have to do is call your cell phone number and then you will be prompted to set up your voicemail out-going message, etc
If you are unsure, the best thing to do is, on a secondary phone that is not your cell phone that you want to set up the voicemail, call your cellular service customer support number. This number might be on your cellular bill. They can help walk you through setting it up step by step since each type of phone and phone service is different.
Tutorials by Cellular Service:
AT&T Wireless Visual Basic Voicemail
http://www.att.com/esupport/article.html#!/wireless/KM1009152
Sprint Wireless Basic Voicemail
http://support.sprint.com/support/article/Set-up-and-access-voicemail-on-my-Sprint-Phone-Connect/case-gz982789-20111213-115609#!/
T-Mobile Wireless Basic Voicemail
https://support.t-mobile.com/docs/DOC-1171
Verizon Wireless Visual Basic Voicemail
http://www.verizonwireless.com/support/knowledge-base-14613/
in the US, the major cellular companies are:
AT&T Wireless Customer Support: 1-800-331-0500
Sprint Wireless Customer Support: 1-888-211-4727
T-Mobile Wireless Customer Support: 1-877-453-1304
Verizon Wireless Customer Support: 1-800-922-0204
Dec 03, 2015 | Samsung Cell Phones
Forgot unlock code voicemail kyocera jax
Go to this link...
http://www.virginmobileusa.com/resources/phones/prepaid/manual/kyocera-aw-jax.pdf
DOWNLOAD THE MANUAL FOR FUTURE REFERENCE!! LOL
Scroll down to page #39 to where it says Use Voicemail and follow the instructions!! As per the service tech I spoke to on the phone to find this link, following these instructions will automatically erase your old voicemail unlock code as well as any as yet unheard messages.
Just in case anyone still has difficulty in finding the instructions.....
Set Up your VoicemailBefore your phone can receive voicemail messages, you must set up a 4-10 digit passcode and record a personal voicemail greeting.When you have set up your voicemail, all unanswered calls to your phone are automatically transferred to voicemail, even if your phone is in use or turned off.1. Press and hold the 1 key.2. Follow the system prompts to create a password and record a greeting.
Check your Voicemail
When you receive a voicemail message, a
notification with a voicemail message icon
appears at the top of your screen.
• At the voicemail notification, select Call to call
your voicemail number and follow the system
prompts to retrieve the message.
Select Ignore to clear the notification without
checking messages. The notification icon
remains on top of the screen until you listen to
the message
• When only the voicemail message icon
appears on top of the screen, select
Voicemailand follow the system prompts
Best of luck!!
Susan
Jan 27, 2012 | Kyocera Jax Cell Phone
How do I set up voice mail on an iphone
Adding Voicemail for the First Time
  1. Tap the "Phone" button on your iPhone.
  2. Select "Voicemail." The iPhone will prompt you to create a password for accessing your voicemail, then will allow you to record your first greeting.
  3. Click "Save" to set your recording to your voicemail greeting
Recording a New Greeting
  3. Choose "Greeting > Custom."
  4. Select "Record" and begin recording your voicemail greeting.
  5. Hit "Save" to set your recording to your new voicemail greeting
Dec 06, 2011 | Apple iPhone Smartphone
Can receive and answer calls but greeting announcement is silent.how do I turn on greeting.
Please tell me the model of your phone.However,you can do this with the use of your phone profile i.e from the phone click on it the screw down to the profile then click on it screw to setting or turn setting from there you will be able to get to greeting setting or turn from this step you will be able to activate the turn again .
Good luck.
Thanks for using fixya.
Sep 06, 2011 | Cell Phones
How do i set up my voicemail...manual not explaining ...please list steps ....
Once you call your voicemail service, you'll be taken thru step by step instructions to set up your voicemail.
To call your voicemail service
1. From the Home screen, tap Phone.
2. Touch and hold down 1.
If this does not work, you need to set up your voicemail number. Your subscription includes an answering service, callers can leave a voicemail message when you cannot answer a call. Usually, the voicemail number is saved on the SIM card. If not, contact your service provider to get your voicemail number. You can then enter the number manually.
To enter your voicemail number
  1. From the Home screen, tap .
  2. Find and tap Settings > Call settings > Voicemail settings.
  3. Enter your voicemail number.
  4. Tap OK.
Hope this helps. If so, please rate the solution.
-regards,
M
Mar 05, 2011 | Sony Ericsson XPERIA X10 Cell Phone
How to set up voicemail
If you have an active voicemail... but have never activated it:
The default password is 0 0 0 0 (four - zero's)
The voicemail will talk you right through setting up voicemail, after the set up you can press 8 anytime you are in the voicemail to make changes to your account.
Feb 11, 2009 | NorStar Nortel Aastra B0240402 Phone Ash...
I'm trying to set my voicemail..but how?
After you place your sim card in the phone press and hold the 1 button and it will call your voicemail and allow you to set it up. Or if that doesnt work call your phone number from you phone and then you will be able to set it up.
Jan 24, 2009 | LG Vu CU920 Cellular Phone
Cant set voicemail up
Call customer service something odd is happening you don't need to re-set up voicemail moving your SIM from one phone to another. If the phone is one not from your carrier it might not be programmed for your carrier's number when you press and hold 1 to dial voicemail
Jan 03, 2009 | LG Shine KE970 Cellular Phone
At%t 944 4 line intercom voicemail set up?
There is no included voicemail with that phone. You could order voicemail through the phone company, and I beleive it will turn on the "Voice Mail" light.
Nov 20, 2008 | AT&T 944 Four Line Intercom Phone
Aastra Telecom 9116 Corded Phone Logo
167 people viewed this question
Top Aastra Telecom Lands Phones Experts
Illimar Saatvali
Illimar Saatvali
Jose Ma DM.
Jose Ma DM.
Michel Laprise Sr
Are you an Aastra Telecom Lands Phone Expert? Answer questions, earn points and help others
