Question about Car Audio & Video
Jvc kd-hdr50 wiring diagram - Car Audio & Video
iadame
  • 676 Answers
SOURCE: I need a color coded
iadame_35.jpgThis should help you out.
Posted on Sep 16, 2011
SOURCE: wiring diagram for JVC KD-G200
Here ya go
http://resources.jvc.com/Resources/00/00/95/GET0182-002A.pdf
Posted on Sep 13, 2008
bigTROY502
  • 129 Answers
SOURCE: INSTALLING CAR STEREO IN CAR
Metra part numbers Kit 99-4500 harness 70-1858 ant adapter 40gm10
Posted on Aug 13, 2009
  • 31 Answers
SOURCE: need wiring diagram for kd-shx700
Hi There, if you click on the link you'll find a wiring diagram...
http://resources.jvc.com/Resources/00/00/95/LVT1158-002A.pdf
Rich...
Posted on Aug 16, 2009
josetejas
  • 300 Answers
SOURCE: need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Posted on Jan 25, 2010
My JVC KD-HDR50 no longer reads my iPhone it flashes reading for a minute then says cannot read Its not the update cause I can plug in my old iPod 3rd gen and it does the same thing?
Are you using the same cable? If so, try using a different cable. They tend to break the tiny wires at the point where they connect to the end adapter.
Nov 14, 2014 | Car Audio & Video
Replacement faceplate for a jvc kdhdr50
Are there other faceplates that are compatible with my jvc kd-hdr50 because someone stole mine and i cant find anywere that sells just faceplates
Jun 27, 2012 | JVC KD-HDR50 Car CD/ MP3 Player
I dont have the wireing plug for the back of my jvc cd recevier model no. kd-hdr50 where can i get one or where can i get a picture of what wires are what on the pins in the back. thank you. jerry
Hi, you can download the manual here. The wiring is in the back of the manual. Please let me know if you have any questions.
http://a248.e.akamai.net/pix.crutchfield.com/Manuals/105/105KDAHD59.PDF
May 19, 2011 | JVC Car Audio & Video
I have a JVC KD-HDR50 in das cd/usb reciever in my car. I press the SRC button and it goes from am to fm to cd to aux in to sirius. Now the sirius option won't come up, what do I do?
try resetting your deck. the reset switch should either be an unmarked indentation about the size of a pencil tip on your face, or behind a small hole on the subpanel behind your face.
Feb 01, 2011 | JVC Sirius KD-LHX500 CD Player
My JVC KD-HDR50 was working perfectly up to a couple days ago. While driving it spontaneously powered down and back up again. None of my setting were changed. Later on, it powers down again and this...
did you hard-wire the radio(wired direct to your factory wiring) or use an integration harness to your vehicle? My first thought would be the wiring. Check mainly the yellow, red and black connections. if those are intact, next look at the harnesses, Be sure they are nestled together correctly, and all the wires are secure on both ends. If they are loose on the harness side, some hot glue should help to keep the wire in place. If the nestling of the harnesses is bad. then I would say just go get a new harness for $20 and re-wire it. You may end up with more problems down the road if you keep the same one and it's faulty.
If the wiring is all intact then my assumption would me the internal radio amplifier. They can spontaneously go bad at times, and cause an on then off again effect once it cools down. Sometimes off for extended periods of times as well. if that's the case. Just go for a new unit.
Jan 06, 2011 | JVC KD-HDR50 Car CD/ MP3 Player
Aug 13, 2009 | JVC Car Audio & Video
Car Audio & Video Logo
237 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
