Question about Sharp Office Equipment & Supplies
Need a toner cartridge for Sharp AL-800 no one seems to have one
  • 1,110 Answers
I use these guys all the time.
http://www.precisionroller.com/search.php?q=al800+toner
Thank You for using Fixya. We are having a contest this month based on customer testimonials. If I have helped you with your free question today, please take a moment to leave a testimonial for me.
Thanks!
Posted on Oct 07, 2010
5 Suggested Answers
SOURCE: Manual for Sharp AL 800 digital copier
hi im jules_09.you need a new toner cartridge for the copier when the toner light comes on it indicate the cartridge is empty.buy a new cartridge there is a instruction on the packaging that will guide you to install it your self
Posted on Dec 02, 2007
  • 29 Answers
SOURCE: Sharp AL-1631 coper - toner problem
the problem in your machine is on the drum unit there is a arching on the mc unit.located in the upper portion of the drum unit.if you have an old drum unit try to install it again just for testing.and check if ther is a dumping toner again.
Posted on Nov 05, 2008
vmachlis
  • 7 Answers
SOURCE: toner error message on copy machine
Is "CH" steady or flashing? If it's steady, the door is not shut properly.
If it's flashing, the machine doesn't detect the presence of the toner cartridge (defective toner cartridge). Try another toner cartridge (an empty cartridge will do).
To get the blue handle to stay locked sometimes takes fiddling with it when the cartridge is in.
Posted on Dec 23, 2008
goalie39
  • 469 Answers
SOURCE: Sharp AL-800 light copies
Check the machine for a **** or dust glass above the drum.
Check and clean coronas, the wires and shells may be dirty reducing charge.
Run a few white copies, to check of the toner / carrier ratio is low.
Hope this is of some help.
Ed
Posted on May 11, 2009
Toner cartridge spreads toner all over inside
If the toner cartridge is dumping toner it is defective and needs to be replaced.
Dec 08, 2014 | Sharp AL-1631 Drum Unit - 18000 Pages...
My Sharp AL-800 copier only returns blank pages even after I replaced the toner cartridge with a new one.
toner is not the problem remove the photoreceptor and gently clean the inside very well expecialy the two charging unit.
Jul 30, 2010 | Sharp AL 800 Copier
Which toner cartridge do I need? Where can I buy one?
The Sharp AL1631 takes a Sharp AL 100TD cartridge (hi-yield), or a Sharp AL 110TD cartridge (standard yield). IBS still has them, there phone number is 800-8810226.
Mar 12, 2010 | Sharp AL 1631 Copier
Where is the ink carteridge located on the sharp al 800
The front operational panel drops down, exposing the toner cartridge and the drum cartridge. The toner is the uppermost one. for more see:
http://www.sharpusa.com/CustomerSupport/ProductDownloads/ProductFAQs.aspx?category=PrintersFaxMachines
Good Luck!
Jan 02, 2010 | Sharp AL 800 Copier
Sharp AL 800 won't copy bottom 2 inches across page. Replaced toner cart and still missing bottom 2 inches across page. What do I try next?
Pretty sure you need to replace the drum cartridge. When the drum blade goes bad or edges of the drum go bad it will cause this issue. You can stop a copy as it is passing thru and compare the edge as it is being transferred to the drum and what is on the paper to see what I am talking about.
I can be more specific if necessary
Thanks
TankMurdock
Apr 24, 2009 | Sharp AL 800 Copier
AL 800 falshes "L" - new toner cartridge inserted
Manual can be found here.
http://www.sharpusa.com/files/cop_man_soho_AL800.pdf
Apr 16, 2009 | Sharp AL 800 Copier
Toner error message on copy machine
Dec 07, 2008 | Sharp AL 800 Copier
Black line on side of copies
You should replace the drum and toner cartridge if you haven't in the 5 years, that should take care of the lines. The only problem is the cartridges can cost more then the machines is worth... Hope that helps
May 30, 2008 | Sharp AL 800 Copier
Sharp Al-800 Skewed Copies
one problem with this machine, a small pin comes out on the paper release handle in the back, which lets on side of the paper lift tray to come up higher than the other. might look in that area. good luck
May 15, 2008 | Sharp AL 800 Copier
Dec 01, 2007 | Sharp AL 800 Copier
37 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
