Question about Apple iPod touch
My daughters' itouch won't get internet. i manually entered all ip's, dns etc. nothing. even tried unplugging router etc and restarting. nothing. she already tried resyncing with her laptop. what next? thanks.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Apple Master
  • 1,099 Answers
The ipod touch connects to the internet wirelessly. To do this go to settings and the first item under the settings is denoted as Wi-Fi, click on this and then switch on the wifi. Once it is switched on click on the name of your wireless network and then insert your password and you should be able to browse the internet. Hope this helps.
Posted on Oct 07, 2010
  • surfdive Oct 07, 2010
    sorry for not stating the obvious. i tried that first. the network and password are correct, but i only get a "unable to join the network" message
  • Jim Thomson Oct 07, 2010
    I thought that might be the case the article athttp://support.apple.com/kb/ts1398 under additional information should be able to help you.
    Regards
Had to get a new router now my roku says my network is not shown
Sir,
The quick fix: make sure your router's DNS settings are properly set to an External IP address. If DNS1 or DNS2 show up as internal IPs such as: 192.168.1.x, then your Roku won't connect to the Internet.
Here is the detailed fix:
  • Login to your router. (typically this is done through an internal ip address like 192.168.1.100). You enter this IP address directly into your web browser same as you would a website. **NOTE some people actually enter web addresses into Google, and then navigate that way. This won't work. Enter the IP address directly into the browser's Location or Navigation bar at the top. This will take you to your router's login screen. *NOTE sometimes the router's default password is "password". But it's possible that your password was changed during installation. If you don't have your router's password, contact your Internet provider.
  • Once logged into your router, navigate to its DNS settings. My guess is that if your Roku isn't working, it's because rather than an external IP address being used for your DNS, the router is set to use an internal IP address. (Your computer is able to overcome this because it has built-in DNS settings, but the Roku looks to the router for this information.)
  • Replace the internal DNS address with a public DNS address. What worked for us was using Google's public DNS. So set DNS1 to 8.8.8.8 and DNS2 to 8.8.4.4 .
  • Save your settings.
  • Run the Roku setup again. If you still aren't able to connect to the Internet, then bounce (unplug) the router. Leave it unplugged for 15 seconds. Then power it back up. Try again with the Roku. If that doesn't work, bounce the Roku. Leave it unplugged for 15 seconds, plug the power back in. The 15-second rule with computers and hardware is surprisingly effective.
  • If you've set the DNS properly, your Roku should now (finally) connect to the Internet. When this happens, it will complete its setup process and you should be good to go.
In case You Still having Belkin Basic Wireless Router Issue Then Visit
How to Fix Roku that Wont Connect to the Internet
Or Follow Us For online Belkin Wireless Support On: Belkin Support
Feb 28, 2014 | Belkin Basic Wireless Router
Itouch says connected to router but not to internet
I had exactly the same problem with a brand new 3rd gen iTouch. It showed it was connected to the network but wouldn't access anything (invalid argument etc). I tried everything but no joy. Eventually I fixed it by changing the router's encryption from WEP to WPA2-PSK. Fixed it like magic. Where there had been no router or DNA data before, they were suddenly filled in. The key was different but was still on the bottom of the router. I had to re-enter the key on my wireless laptop2_bing.gif but that was a small price.
You can get into the router set-up page through your web browser. I found a guide on You Tube.
Jul 12, 2009 | Belkin F5D7230-4 Kit (F5D7230V4SNPDQ)
Itouch Connection To Home Broadband
Hi, for DNS use the following information:
Primary DNS 4.2.2.2
Sec DNS 4.2.2.1
Password prompted by Itouch is the WEP password. Make sure tht you restart the itouch and then try to connect to it.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jul 04, 2009 | NetGear DG834G Router
Intermitant signal
on your computer goto start - run - type services.msc and press enter.goto wireless zero configuration and enable it. now goto start - run type msconfig and press enter then goto startup and uncheck your netgear adapter.press apply and OK or close. restart your computer.goto start - control panel - network connection then right click wireless network connection and view available wireless networks.select your network and connect.once it`s connected goto start - run - .cmd - enter..type ipconfig..you`ll get ip address,subnet mask,default gateway.copy it. now right click wireless network connection again and click on properties and double click on internet protocol(TCP/IP).type in the IP address,subnet mask,default gateway.in DNS server address type the default gateway in primary DNS and in secondary 4.2.2.2. your connection won`t drop after this.
this will fix your problem...
Jun 11, 2009 | Arris SURFboard SBG900 Wireless Router...
My Xbox 360 ADapter Cannot Aquire a IP Address from my Modem
can u please tell me which router it is? in most of the router there is a feature call DMZ. u need to enable the DMZ in the router & then u need to provide the static ip to Xbox 360 like 192.168.1.5 etc in the default getway u need to type the router IP address & on DNS u need to try three different settings 1st on primary DNS type the router ip address like 192.168.1.1, if it didn't work try with univeral DNS try on primary DNS as 4.2.2.2 & on secondary 4.2.2.1, if this didn't work either call ur ISP and ask for the DNS server address of ur ISP and try with that.
Jan 23, 2009 | Microsoft Wireless Network Adapter Xbox...
Itouch internet connection problem
You might need to get a new version of safari for your itouch.
Oct 19, 2008 | Apple iPod touch
I cannot communicate with primary dns server 172.29.71.1 is there a way i can reset it automaticaly or manually
You cam try doing a power cycle. Turn off the modem, router (if you have one) and your computer. after 1 minute turn on modem first then router and computer. If you still can't communicate or ping the DNS it could be a firewall that is blocking it.
Oct 08, 2008 | Computers & Internet
Dns error when connecting how do I fix this
Unstable connection. if you have wireless connection that could be a problem depending on your environment. Try turning off your firewall too by calling your internet server(Comcast,DSL,etc.)
Jul 31, 2008 | Sony Playstation 3 (PS3) Console
this just happened to me,
do this, because you are swiching between fiwi,
you go setting, and then turn fiwi off
and then shut the power, and then restart, turn fiwi on
you touch will work perfectly!!
GL
May 03, 2008 | Apple iPod touch
Itouch 16gb, Cannot get an internet connection
Hit "Forget this Network", go to Settings > General > Reset > Reset Network. Worked for me.
Feb 04, 2008 | Apple iPod touch
Apple iPod touch Logo
108 people viewed this question
Top Apple Audio Players & Recorders Experts
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
