Question about Garden
My Caterpillar 205 excavator works very well from cold, but after working it for an hour or so it becomes sluggish and slow. Hydraulic oil appears to be hot but the cooler is working well and is clean. All oil levels are perfect and there only appear to be some very small seeps of oil from a few rams seals.
chiquititas
  • 1010 Answers
SOURCE: 2005 Peugeot 504 SW estate
The computers software got bad.
Posted on Jul 02, 2008
mighty thor
  • 51 Answers
SOURCE: water seeping out the bottom of my wine cooler
there should be a drain pan that you will periodically remove. Condensate (water) is a normal byproduct of all refrigeration devices. Also look for a drain fitting that you can run to a waste line.
Posted on Nov 25, 2008
SOURCE: My Ex200-2 excavator is slow in all functions and
Hello
My friend has a ex75 ur that had the same problems after some vines caught the limit switches on the digging boom. I spent hours trying to figure out what switch or combination of switches was causing the slow boom with no power. I found a bank of 4 solenoids that control the hyd. flow, after jumping them with a switched hot wire- problem solved!
Posted on Jun 23, 2009
  • 250 Answers
SOURCE: MOTOR CRANKS BUT WONT FIRE
what make is your engine.
Posted on Sep 19, 2009
  • 31 Answers
SOURCE: too much hydraulic oil in my ex 60
Hi
You must IMMEDIATELY PULL ANY EASILY ACCESSIBLE LINE AND VERY CAREFULLY ACTIVATE THE LEVER FOR SUCH AGAIN I CANNOT OVERSTATE CAREFULLY ,THERE WILL BE A CONSIDERABLE AMOUNT OF PRESSURE AND SHOOT THE LINE IN A BUCKET UNTIL LEVEL IS RIGHT. FAILURE TO DO SO CAN RESULT IN SEALS BLOWN ,ETC.
not that hard to do but again BE CAREFULL 3500 PLUS PRESSURE.
Posted on Dec 30, 2009
Testimonial: "why is there no drain for this"
17d excavator as it warms up I lose power in my hydrolics and they start to overi ride each other almost
this can be several things wrong , but id start by the basics , new fluid , new filter , check/clean strainers then move on to more serious things like directional control block , and pump/bypass vlv also depending on what type of spool locks you have on your directional control block vlv's , a internal leaking cylinder can do this as well
Feb 02, 2017 | Caterpillar E70B Excavator
How do I change the controls on a John Deere 200 excavator to Caterpillar controls?
talk with a hydraulic engineering shop to find the problems associated with changing the valve bodies over
Nov 06, 2015 | John Deere Garden
Why won't my excavator stop overheating?
Search Results
    Solving Hydraulic System Overheating Problems
    www.machinerylubrication.com/Read/680/hydraulic-overheating
    Overheating ranks No. 2 in the list of most common problems with hydraulic equipment. Unlike leaks, which rank No. 1, the causes of overheating and its ...
    Cat 320 overheating - Heavy Equipment Forums
    www.heavyequipmentforums.com/showthread.php?2828...overheating
    Mar 28, 2007 - 15 posts - ‎10 authors Anyone here have a problem with a Cat 320 overheating? ... that many heatingproblems in excavators are caused by hydraulic problems. 5T Excavator KX161-3 overheating
    Apr 22, 2013
    john deere 270D excavator over heat
    Aug 1, 2011
    cat 305CR overheating issue
    Jul 23, 2011
    cat 312 overheating
    Jul 31, 2008
    More results from www.heavyequipmentforums.com
Oct 14, 2015 | Cars & Trucks
I have hydraulic oil in my radiator, e70b
I am not familiar with that particular machine, but I believe it would more likely be diesel or motor oil, unless of course there is a water exchange hydraulic cooler. If there is, check that for a leak to the coolant. If not, I would check compression on each cylinder, and/or look for signs of a blown head gasket. Other possibilities are probably more serious than even that. I hope this is helpful.
Mar 25, 2014 | Caterpillar E70B Excavator
Caterpiler 320c chin excavator
You can Online Wholesale caterpillar 320c ads from category Caterpillar excavators for sale coming from China. It may occure problem so you need to consult with neer repair store.
Jan 12, 2014 | Cars & Trucks
Swing so slow
Check Turn Table Oil Level. Rebuild if necessary.
Jan 27, 2013 | Caterpillar E70B Excavator
Leaking hydraulic oil around the turntable
The seal units at the turn table are worn or there are grooves worn around the sealing ring.. It is common for this area that is subject to such movement in the worst possible conditions of dust and other contaminents
Jan 16, 2013 | Caterpillar E70B Excavator
330 excavator with a c9 cat engine, heavy SMOKE
Why did you do all of the engine work? Due to the same problem? Have you ran an ET on it to check for codes ?
Feb 25, 2010 | 2006 Lamborghini Diablo
Garden Logo
101 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
