Question about Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer
Our Bosch Nexxt 500 series washer slips to 56 minutes from 25 minutes without our help. It seems to happen mostly when we use a full load. What to do? We have had the machine for a few years and it happens regularly. A nuisance!
  • k_nichols366 Oct 07, 2010
    Thanks for the explanation of "fuzzy logic" - it really fits the problem. However, the rest of the response is much too technical for me. Unless I can turn off the "fuzzy logic" I have a feeling I just have to live with it! It is a nuisance, since most loads are not soiled at all and do not need the long cycles.
  • 11,896 Answers
The timer will need to be replaced. Daysappliance and partselect.com both have parts, manuals, diagrms, and more.
Posted on Oct 07, 2010
  • Bosch Master
  • 17,130 Answers
This machine has got a sensotronics technology that takes input of the temperature/load cycle and makes corrections to the machine. So These inputs can make corrections or alter the program that is causing the program to run offf slowly, sometimes this is also called as fuzzy logic , It helps to give a good energy efficiency-- as Bosch claims- but there are many complaints of the time relativity.
hence it is possible that there is an induced fault of an input to delay the timer or perhaps the program controller by itself is defective.
Now I would like you to test with different programs so as to observe the changes and come to a conclusion. YOur inferance must guide you to understand if this is a relative failure of a set delay on the machine.
Sometimes when more complications are brought in so as to enhance performance , we also bring in likelyhood of more problems.
Please check the sensors that are attached to the control board input check for failure or break.
The advice/tip given is with the belief that you are competent. You must attempt to do it yourself only if you are technically/logically able, especially when dealing with delicate devices, damaging while trying to open, Probing electrical/electronic circuits with high voltage or delicate components. Since the advice given by me is with the inputs provided and not based on a visual inspection, there can be further reviews required in some cases.
Error code E:01
Hi and welcome to Fixya, The E01 error for your bosch indicates a door lock problem has been detected at the control board. Insure the door is closed tight, turn your breaker off or unplug the washer for a couple of minutes and retry. Let me know what happens, ultimately it may be a faulty lock assembly, a loose wire harness etc. but we'll cross that bridge when we get there...if necessary. I'll watch for you to respond with the result's. Good luck. Macmarkus :)
Jun 07, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Noisy pump in bosch nexxt 500 washer
no its usually not that loud at all contact bosh direct to have them send you a new one or call them if its still warrantied
May 01, 2010 | Bosch Nexxt 500 WFMC3301 Front Load Washer
TURN OFF ALARM
Assuming you have allready checked the operators manual, check again on page 19 for "Accoustic Signal".  To deactivate the signal select a program press two of the option buttons and hold until a short signal is emitted.  There you have it.
Jun 16, 2009 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Gasget came off the washer and i can't get it back on
I have the perfect solution the placing of the Retaining Spring back on the Bosch Nexxt 500 Door Gasket. It only took me only 5 Minutes after fighting with it for hours and getting nowhere. What I did was purchase a set of 12 inch hemostats (long Clamping Pliers). The ends of the Hemostats I wrapped both of the jaws with Electrical tape to prevent the Spring on the retainer from sliding up the jaws of the hemostat. When the ends of the retainer are placed on the ends of the jaws and the hemostat opened the spring is stretched. I found that If you use your knee to hold the hemostat open while placing the retainer in the groove of the gasket you can slowly release the springs and set the retainer back into the gasket without the gasket pulling off the tabs.
Mar 01, 2009 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch Nexxt 500 Series Washer Will Not Add Water
during a normal wash cycle the washer stopped and gave an e;4 error code
Dec 21, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosch front loading washer nexxt 500 won't pump out water on the spin cycle
could be drain hose is not high enough. I had the same problem and when I raised the hose it worked fine.
Dec 04, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
Bosh washer won't dispense softener. cleaned the tray and tested it by filling with water and it drained completly out, so i know its not clogged. washed another load and softener still there at end of...
I had the same problem. the only thing that works for me is fulling the fabric softener compartment all the way to the top with water then it will syphon down! it adds it to the load at the start instead on the rinse cycle but its better then nothing!
Jul 28, 2008 | Bosch Washing Machines
Bosch 3.81 cu ft WFMC530 1UC Nexxt 500 Plus Series Washer Logo
54 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
