Question about White Sewing Speedylock 1600 Mechanical Sewing Machine
Blade or cutter
Where can I find the blade of my apeedlock? coz it's broken.
  • White Sewing Master
  • 1,388 Answers
Well, bits of it will probably be directly below the rest of it !!
Kidding aside, you will be best served by a White dealer.....in Australia, they are under the Huskvarna umbrella, so it may depend where you live. Have you tried to contact White HQ and ask them who your nearest stockist would be ?
Posted on May 29, 2008
Rabbit HX 720 Vinyl cutter plotter cutting blade will not lower to cut
Since this is a sewing machine category, it is unlikely there will be a good answer.
Aug 31, 2017 | Sewing Machines
I have a Juki TL-98Q The thread cutter and the needle up down button don't work. How can I fix them?
Has a piece of broken needle or chunk of thread jammed into the blades and are not letting them move? If there was a big time thread jam it can actually break one of your blades and you will have to go to a repair man and have the blade replaced.
Jan 09, 2016 | Juki TL-98Q
How to clean wiper sensor on enterprise
Cutter blade needs replacement. Sensor is likely fine and is not located in the bobbin case area.
Sensor is telling you there is a cutter error. More than likely need a new cutter. Easy enough.
Cheers,
Kelly
San Diego, CA
May 09, 2014 | Baby Lock Sewing Machines
Changed cutting blade now blade will not stay stable in position to cut
did you get the cutter release knob back in the right place or position?
is the horseshaped bracket damaged in any way?
Mar 07, 2012 | White Sewing Superlock 1934D Mechanical...
I was cleaning my bobbin case and the cutter and blade came off. Can you send me a picture so I can put it back together?
I don't think I have a picture but let me see if I can describe it to you.
The metal cutter has a black plastic piece. The blade fits in the black plastic with the longest point on top. The black plastic piece slides back onto the metal cutter, riding on the ridge. Fit the metal cutter back on the unit, being sure to align the "stubs" in the holes of the black pieces attached to the cog wheel. Make sure the "stub" of the black plastic piece with the blade fits in the parallel groove so that only the metal piece moves out and brings the thread to the blade when the cutter is activiated.
If you are still unable to fix, make a comment back and I'll go take pictures of my machine's cutter system.
Good luck.
Sep 03, 2009 | Husqvarna Viking 1
Elna 704 serger sews well but cutter won't cut. replaced cutter -- same problem
Make sure that the blades are being held firmly together. I have seen the knob used to lower the moving blade come loose and releases much of the pressure intended to hold the blades together.  If so, the set screws on knob have come loose.
Sep 03, 2009 | Sewing Machines
Cutters on Elna 744 serger won't cut
is there lint or thread caught between blades preventing them from meeting?
scott
Jul 26, 2009 | Brother 929D Mechanical Sewing Machine
Husqvarna Sapphire - thread cutter not working
Does the metal arm come out to grab the threads to cut it? Is there a blade in the metal arm that cuts the tread? I think a standard utility knife cutter blade is the same size (just like the one that cuts the bobbin thread when you put in a new bobbin). What happens when you activate the cutter is the arm comes out, grabs the threads, brings them to the blade which cuts the threads, the velcro by the cutter holds the bobbin thread in place for the next stitch. Otherwise the thread may end up on top and the top thread would not be able to pick it up for the next stitch.
Good luck.
Jun 27, 2009 | Husqvarna Viking 1
My simplicity serger SW432 wont cut
There are 2 blades, a fixed cutter and a moving cutter. The moving cutter should move approx 1/8" at it's lowest point past the fixed cutter. There should also be some pressure between the cutters
Mar 18, 2009 | Simplicity Serge Pro SW432 Mechanical...
White Sewing Speedylock 1600 Mechanical Sewing Machine Logo
51 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
tsalagi152
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
