Question about Fisher and Paykel DD24DCTX6 Dishwasher
Hi, We have 1.5 year old Fisher and Paykel DD24DCTX6 Dishwasher. Recently the bottom draw will not complete a regular (115 min) wash cycle. It gets down to 48 mins and stays running at that spot. Eventually (after a couple of hours) it will stop and produce and F 4 error code. I have tried resetting it by turning the power off to the unit. When it does error out, there is water left in the bottom of the draw and we have to run it in Rinse cycle to get rid of it. Any suggestions would be great. Thank you, Jeff Pray
  • 883 Answers
SOURCE: Brand new dishwasher not working
try this test: add water (one gallon each try) by hand fill and try the cycle again. Continue until light goes out. If light never goes out, then faulty water level switch or wiring. If light goes out, then water inlet valve is stopping too early, but need more info to determine why. Try this test: open door and find the door switch. Then activate the switch and turn on machine to watch water come in. It should not just "dribble" in; try to determine if water pressure is sufficient coming in.
Posted on Jun 19, 2007
  • 351 Answers
SOURCE: How to reset my fisher and paykel dishwasher
you have to remove the bottom drawer and remove the water from the base.theres two push in tabs on the bottom sides dd603 or if its a dd602/601 theres plugs that pull out remove them and the front panel the drawer will lift out far enough to get access.but you may find its leaking.hope this helps.
Posted on Mar 20, 2008
Master_Tech
  • 770 Answers
SOURCE: fisher paykel
Check your email
Posted on Jul 09, 2008
RescueTech
  • 145 Answers
SOURCE: Fisher Paykel 2 drawer dishwasher
When it sticks like this, does it continue to wash or does it stop?
Posted on Dec 11, 2008
SOURCE: dishwasher error
The error was a flood fault, water was not draining from either of the drawere, I removed the bottom drawer, dried drip pan and used hairdryer to dry fault sensor, the dishwasher then reset itself and works fine.
Posted on Jan 01, 2009
Doesn't complete cycle. Gets stuck at 26 mins.
quite likely the control board has begun to fail . only fix will be to get it replaced
May 14, 2016 | Fisher and Paykel 23 in. DD603H SS...
DD603 top draw cycle getting stuck on 73min??????
Normally if you started the rinse cycle with water already in the base of the dishwasher it will immediately go into circulating the water through the wash arms. Do you hear the wash arms running when the washer is stuck at 11mins? Also when the washer is stuck at 73 mins are the wash arms running all the time or do you hear the pump operate at some stage?
If you have the dishwasher manual available make sure the water pressure setting is at HI or LO depending on your rated mains water pressure.
Apr 30, 2013 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel washing machine
Without being smart...buy a new machine. It sounds as though the timer is dying...therefore slowing down...therefore extending cycle times. If that's the case, a new timer will cost about half the cost of a new machine.
May 06, 2012 | Fisher and Paykel Washing Machines
.After running my dishwasher on eco/fast cycle,
If the dishwasher is completing the wash cycle without any problem then the suds can occur either because you not using correct detergent. This model does not tolerate the tablets. You have to use the powder.
Water remaining in the bottom of drawer is linked to drain hose either blocked or not looped high enough under the kitchen sink.
I would suggest check this document for correct installation.
Nov 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel dishwasher noisy fan
Have you got your dishwasher on an extended drying cycle?
Normally it works for about 10 minutes after the wash cycle is complete - not hours.
Jan 21, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
With a DD603 d/washer , the F1 sign flicks once the w/cycle ends
F1 is a fault that occours when a waterleak is detected if oyou rmeoveth elower drawe there shoudl be a trouble shooting guide taped to teh back wall inside,very helpful
Jan 25, 2009 | Fisher and Paykel 23 in. DD-603 Built-in...
How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Jun 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Fisher and Paykel DD24DCTX6 Dishwasher Logo
62 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Owen Barnes
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
