Question about Apple iPhone Smartphone
Java plug in cd
Hi thanks a milllion, do u perhaps have a java plug in cd downlaodble or so cause in rsa the technology is hard to come by
  • 56 Answers
There is no java plugin cd instead go to java.com and den download plugins in ur pc
enjoy
Posted on Jun 01, 2008
Jsp fullform
JAVA SERVER PAGE (JSP) is a Server-side technology. JAVA serverpages are an extension to the JAVA servlet technology that was developed bySun. JSP's have dynamic scripting capability that works in tandem with HTMLcode, separating the page logic from the static elements. The actual design anddisplay of the page to help make the HTML more functional...
thanks & regards Anas K A
Jun 28, 2011 | Computers & Internet
Usb RSA securID when plug into the usb port, windows 7 says "finding drivers and then errors out with "Unable to find smart card driver"
This pop up only occurs with older versions of the RSA software. Customers should download the latest version of RSA Authentication Client from RSA.com. bres can obtain the SD800 smart card driver -- which is Windows 7 certified -- directly from RSA, but it is not available through Windows Update.
The SecurID "token" from RSA, the security division of EMC, is a two-factor strong authentication mechanism (something you know, plus something you hold). In tandem with a RSA authentication server, a SecurID is used to ID trusted users for firewalls and other restricted networked applications. (It is not itself a firewall.)
RSA's SD800 is a hybrid hand-held authenticator. The SD800 displays a series of one-time passwords, which change every 60 seconds, on a small LCD, but it also has a USB plug that allows it to directly connect to an accessible USB port to offer the full functionality of a smartcard. These include an automated SecurID exchange, cert-based authentication, an array of classic PKI crypto functions, and supplementary key and credential storage.
These are complex services, and they require a sophisticated setup.
The SD800 is intended for Enterprise rather than consumer use. Since the driver must be properly configured by an Enterprise to work in its environment, the SD800 is designed to be installed manually or pushed out by an Enterprise using SMS (along with its complementary GPOs, group policy objects).
The quick solution here is for an Enterprise admin to go back to the vendor, RSA, for the right stuff.
_Vin
Jan 12, 2011 | RSA Security RSA SecurID Appliance...
Machine will not show graphics after working properly for 15 minutes.
This course uses  (Java applets  (Suns' Java technology)  In older version of Microsoft internet Browser the Microsoft Virtual  is already installed in your machine.   In newer version of windows installation, the Java  is  not install automatically.  In most cases, now you must install the Java separately into your machine  http://java.com/en/index.jsp  (download free Java software)
DursulQuran is also available in "Printed version", in theory does not require a computer and the course may be follow independently by using a booklet.   In addition,  the sound of each lessons have been recorded that may be run from stand alone CD player as well the audio cassettes.   The course material may be downloaded freely from this site.   The printed material are prepared in Acrobat Pdf. format and easily printable on 8.5 x 11 paper.  the sound clips are in MP3 format that can be burned into a audio CD (and latter transfer into an audio cassette) as well as run in your hard disk.
Obtain Printed version click here
Dec 02, 2010 | GPX Audio Players & Recorders
RSA IMPLEMENTATION
http://rapidshare.com/files/291829771/rsa.tar.gz.html
A simple RSA implementation I wrote in an hour couple years ago :). Comments are in polish but all identifiers are in english. The code is fairly simple so it should be self explanatory. Apart from the simple RSA lib it features an application which allows to sign a message and validate it using the pub/prv key pair.
Jan 22, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Implementation web based auto dialers in java
It sounds like you might be able to use for JTAPI forwhat you're trying to do.
Sep 30, 2008 | Computers & Internet
Vista and j initiator
Hello
The first link is for server campitablity from Oracle for the correct version of jinitiator, and the second in for a Java plug in that some are using and is said to work better. If you can't get the jinitiator to work, try the Java and see if it will work for what you need.
http://www.oracle.com/technology/software/products/developer/htdocs/jinit.htm
https://apps.uillinois.edu/support/jpi/
Thanks
Regards
Jun 24, 2008 | Computers & Internet
Java (TM) Plug-in fatal error
To view this page curectly intall java virtual machine pc destop of window xp operative system.
Mar 16, 2008 | Dell Microsoft Windows XP Home Edition
Can't acces some websites
This sounds more like a problem with your computer's operating system rather than the broadband router. Since the purpose of the broadband router is to provide IP connectivity to the Internet, it is functioning properly if you get to the front pages of the web sites. Now, typically the front pages of the web sites are simplistic when it comes to design and functionality. The more advanced features come in once you log on and get to when things are personalized for individual users. Web sites offer these features through several technologies, such as Java and Flash. Perhaps one of these programs on your computer has become corrupted. Go to Add/Remove programs and try un-installing all versions of Sun Java (or just Java) and Macromedia Flash (or Adobe Flash or just Flash). Then go to their web sites, download and install the latest versions. Java: http://www.java.com Flash: http://www.adobe.com/products/flashplayer/ Restart your computer after installing both. You may also want to check the security settings in your web browser. If the settings are to high, they may be preventing these technologies from running and properly displaying content in your web browser.
Oct 02, 2006 | NetGear DG834G Router
Apple iPhone Smartphone Logo
41 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
