Question about Refrigerators
Water Leaks from front door
Water leaks from front dispension unit....
  • Anonymous Jul 21, 2008
    i have the same problem. I noticed it last week. Water accumulates inside the refrigerator at the bottom under the plastic drawer. I checked the evaporator tray in the back and it was bone dry.
  • Vahe Nov 12, 2008
    I have the same problem. My U-line Bar Fridge/Ice maker has been leaking water since day one. We called several people, they all said to defrost the unit and it will be corrected. Well, it was corrected foe a couple of weeks and then it started leaking again. Ice builds up under the ice tray and leaks down and out under the lower tray. I just had another comany take a look at this problem. They charged me $85 to tell me that I need an evaporator pan heater kit and it's about $350. As far as I know this is a defect that U-Line needs to take care of. What do you suggest?
My tenants informed me that water was showing up on the floor in front of the refrigerator. I checked the back where the evaporator tray is and it was dry. When i looked inside the refrigerator I notices water pooled inside, under the plastic bottom drawer. Anybody have any idea what i should do? thanks.
Posted on Jul 21, 2008
jumptrout51
  • 3361 Answers
SOURCE: GE Profile Arctica PS123NGMD. Leaks
The defrost drain line in the freezer is stopped up.
You will have to remove all food and turn the refrigerator off for 24 hours to let the drain line defrost.
Posted on Jul 17, 2011
ginko
  • 19396 Answers
SOURCE: GE Profile Arctica PSI23NGMD. Leaks
Hi.
Access the dispenser mounted on freezer door. You will need to remove the outer trim (pt.91 in diagram) by prying it out gently. The panel has clips on top and bottom. Start from the bottom edge. Behind the trim remove the control board and housing to access the dispenser . Disconnect board connector and then release screws holding the housing. If the access is not enough to find the leak you will need to take the door apart completely. Inn that case there are 30 screws hidden behind the door seal to remove. Try fixing the problem from dispenser access.
Here door diagram, click on the picture to enlarge:
Here also a video: Here all parts and diagrams for this model.
Regards.
Ginko
Posted on Jul 19, 2011
  • 3422 Answers
SOURCE: water dispenser leaking
Water can leak from these areas:
The bottom front of the refrigerator or freezer door
The back of the refrigerator
The inside ceiling of the refrigerator
The inside back wall of the refrigerator
Underneath the front of the refrigerator
The bottom front of the refrigerator or freezer door Self-defrosting refrigerators usually dispose of the water generated during the defrost cycle via a tube or channel that directs the water to a pan at the bottom of the refrigerator. From the pan, the water normally evaporates. (See a more detailed explanation of this in the How Things Work section of our website).
If the tube or channel is clogged or obstructed, the water backs up and leaks into the inside of the refrigerator compartment. Then the water builds up at the bottom, inside of the refrigerator. When the water has built up for a time it may spill out of the front of the door opening. To fix this problem, clear the drain tube or channel and allow the defrost water to flow down to the drain pan.
In some refrigerators, the defrost water is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain--usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Another cause may be the following. The refrigerator may have doorframe heaters to evaporate any condensation on the cabinet frame. If your refrigerator is equipped with a switch inside that says “energy saver” or something similar, while running in that mode the door heaters are disabled. Turn the switch to the opposite setting and wait 24 hours. If the condensation disappears the problem is solved.
The back of the refrigerator Water coming from the back of the refrigerator usually comes from either the ice maker water valve or line (if there is an ice maker), or from the defrost drain pan.
Here's what to do:
  • If the water is coming from the ice maker water valve, check to make sure the water tubes are attached properly and are fastened tightly.
  • If the water seems to be coming from any part of the valve itself, replace the valve.
  • If the water appears to be coming from the defrost drain pan, inspect for holes or cracks, and replace the pan if necessary.
The inside ceiling of the refrigerator Water accumulating on the ceiling of the refrigerator is usually caused by a clogged drain in the freezer section beneath the evaporator. The clogged drain will cause water from the self defrost cycle to leak into the divider between the freezer and refrigerator. This water may then freeze and cause condensation build-up on the refrigerator ceiling. The solution to this problem begins with unclogging the drain. It may also be necessary to remove the entire freezer/refrigerator divider to thoroughly dry the insulation in the divider. Occasionally the insulation needs to be replaced to prevent a recurrence of the problem. This can be a big job – you may want to hire a qualified appliance repair technician.
The inside back wall of the refrigerator In some refrigerators, the water from the defrost cycle is intentionally directed down the back wall of the refrigerator, where it then flows to the bottom of the refrigerator compartment and out to a small drain - usually located beneath one of the drawers at the bottom of the refrigerator. If the drain becomes clogged or blocked, the water may back up. To fix this problem, clear the obstruction.
Underneath the front of the refrigerator If the refrigerator is equipped with a water dispenser on the freezer door, check if the water line to the dispenser is leaking. Also, check the drip pan to be sure it isn’t out of place, broken or cracked.
Goodluck..
Posted on Jun 06, 2008
SOURCE: ''GE tfx28ppcb fridge has water puddle usually on right side
I had the same problem, I found that the plastic tubing feeding the water despendor and icemaker was run right along the comperssor, over tiem the from exposure to the heat the tubing had become brittle and cracked.  the black tube shiled had to slid up to expose the cracked tube. A  new tub installed and splice to existing dispensor feed line fixed probelm.
Posted on Apr 06, 2009
milten1
  • 1304 Answers
SOURCE: My whirpool sise by side rrfrigerator leaks d\from
there should be two small holes on each side of the dispensor cover
push a small nail in to those holes and pull forward
it will snap back in when your donr
Posted on Oct 07, 2009
Side by side whirlpool refrigerator leaking water puddle in front on floor no loose connections and no signs of water from any part of refrigerator
Hello;
My name is Peter. I am a retired field service refrigeration technician.
There are several areas where you may have a leak.
Let's check it out:
You are going to have to pull the unit out so you can inspect what is going on.
Turn the leveling screws counter clock wise to raise them. Pull the unit out so you may get behind it.
25576703-vzgcvxho43azc0x10cxafhpi-5-0.jpg 1.) Observe the plastic tubing going to the water dispenser.
The plastic tubing after time get dry rot. Have someone push the water dispenser and observe the tubing for leaks. But before this put a paper towel under the bottom hinge of the freezer door.
So, if you observe water coming from the tubing that is your problem.
Or if the paper towel in the front is wet, then you have a major problem. There is a leak in the door tubing which is only repairable by replacing the door, which is several hundred dollars plus service - $600.00. You can disconnect the contacts on the larger tubing valve and not use the water dispenser.
Ok, no leaks. Then you have a drain pain leak. Un-plug the unit. Remove the lower bottom cover in the back. Just several screws. Inspect the drain pan. Is there a water line from the pan to the front of your unit.? Repair the drain pan with duct tape and a silicone adhesive.
Inspect the bottom of your freezer. If there is ice then you have a different problem.
Keep me informed. Glen Burnie, MD., Email goodwinpeg@aol.com, Phone: 414-306-1362.
Mar 15, 2015 | Whirlpool Refrigerators
Hsm25gftsa
This problem is common and can be difficult to solve, first of all you have a air leak and because of this, your dispenser leaks. Check every connection for the water system, starting from the back of the unit at the valve. Disconnect the water to the tank first, put the water valve in a bucket and hit the dispenser switch to see if the valve leaks after dispensing water, if it does, replace valve, if not continue in to refer section behind crispers. (this is behind the veggie bins can you see any water at the bottom? If so, repair the leak and continue forward. Check under freezer door at the connection to assure not leaks of water. Again this is a process and after all of this is done or check, one of these solutions should solve your issue. I know not a simple answer but this will correct the issue when everything is checked.
Good Luck
Oct 29, 2013 | Hotpoint (HSM25IFTSA) Side by Side...
GE side by side leaks water from underneath when you use the water from front door
you need to remove the toe kick panel grille below the front doors on the refrigerator behind this grille there is a connector and it can come loose,also possibly the water valve in the lower rear behind the back panel can leak,have a helper press the door paddle for water and check all these areas for leaks,if it leaks from the door stem where the water line goes up the door to the dispenser,then you will need to pull new hose up to the dispenser from the collar mentioned at first,some refrigerators can not have new hose installed due to the door has been foamed internally at the factory and cant be dis-assembled,then you would need a new door with the hose installed
Apr 08, 2013 | GE (PSS26MSRSS) Side by Side Refrigerator
Water leak on floor under refrigerator
The line going into the dispenser is a 5/16 line. You'll have to remove the front of the dispenser on the door to get access to the line to unclip it. Once you have that done you can pull the line out from the bottom. At this point there are a variety of different unions, compression fittings, etc. to splice the line. After that you just feed the line back through the bottom of the door, clip it back in place, put the dispenser back together and your done.
Jun 15, 2012 | GE Refrigerators
Have a side-by-side GE model #TPX24PPDABB that leaks water from the dispensing tube in the front door. Any suggestions would be appreciated!!
Hi ,if the door flap of the ice unit is not broken ,then the valve of the
water is bad and its open all the time (even a little bit) but if your
ice door flab is not seal then the ice melt and that is way you get water leak...
I hope you find this Very Helpful and best regards!
Jan 03, 2010 | GE Refrigerators
GE whre5260e1ww zh133346g top load washer is leaking small amount from the bottom of the machine during wash cycle? I took the back of the machine off and the pump and motor assembly had broken off from...
Hello there:
Here is a few tips that might help you out
Hope that they are very helpful for you
Best regards Mike
Washing machine is leaking Washing machine leaks are very common. There are many places a washing machine can leak from although most leaks come from the same few places. The most common cause for a leaking washing machine is the door seal. Door seals often get holes in them and water leaks down the inside of the washing machine which then runs out under the front. Water leaking down the front of the washing machine from the door can be caused by a worn door seal (the flange part that the door glass presses against when closed) or something trapped between the door seal and the door glass which breaks the seal. If the door seal doesn't look worn, or it's too young to be worn, then try cleaning the door seal's flange and the door glass on the inside of the door. Bits of cotton, un dissolved washing machine detergent etc can cause a leak.
Soap dispenser leaks
The next most common cause of a leaking washing machine is the soap dispenser. Leaking water from a soap dispenser is often caused by a blockage, or water pressure that is simply too high. Despite seeing many leaking soap dispensers, I've never seen a soap drawer with a seal, they just rely on water not getting to the front which is not really good enough. Some Hoover soap dispensers in particular, are renowned for leaking, and over the years Hoover have had to introduce modified soap dispensers twice.
Some washing machines, can flood water out of the soap dispenser when a hose gets blocked (usually with un dissolved soap powder) Indesit, and Candy, as well as some of the later Hoover washing machines suffered from this design flaw. The hose where the water is flushed down, was right at the front of the soap dispenser on these washing machines and the hose wasn't wide enough. Un dissolved powder from a tablet or lumps of detergent through poor hot water pressure can block this hose solid. (Note: water flooding out of the front of a washing machine's soap dispenser can also be an indication of overfilling or a partial pump blockage if it does it when spinning)
Finally, black gunge in the top of the soap dispenser can cause water to spray towards the front and leak. Take out the soap dispenser drawer and look at the roof of the soap dispenser. If it's covered in black gunge, blocking some of the water holes, it could be causing problems. In extreme cases I've had to replace the dispenser.
Tips for finding a leak on a washing machine
  • If you have a leaking washing machine, and you can't see where it's coming from, shove some newspaper underneath the washing machine. The slightest drop will give a clue where the water is leaking from. Pull the sheet out regularly to check for water leaks.
  • Water can run round things and drip onto other parts. Be careful with your diagnosis, as water dripping from a hose at the bottom could actually be leaking from somewhere else higher up.
  • Leaks usually leave marks, so it's possible to see something is leaking even without witnessing it. The soap suds that come out with the leaking water leave white trails. Rust is a good indicator of a water leak too. However, if you have had a previous leak cured, the "evidence" of a leak may still be present so be sure you don't blame a part that was repaired in the past.
  • If the washing machine leaks only at the end of the wash, when water is being pumped out. Make sure water isn't backing up and cascading over the top of a blocked drain pipe in the plumbing.
  • WARNING: Don't get electrocuted trying to witness a leak. It's dangerous running the washing machine with the top or back off.
Nov 13, 2009 | GE WDSR2080D Top Load Washer
Something leaking from dispenser frame
You can remove the frame around the dispenser by pulling it gently and then you access to the screws that hold the dispenser in place. Could be a spillage behind the frame. Good Luck.
Nov 01, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerators Logo
259 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
