Question about Mantis 4-Cycle Tiller
Hi ive had my mantis for 2 months been worked for about 10 hrs was fine when i left it las week now seems to be over heating and cutting out after 1 row also seems to be a lack of power.
  • 1,041 Answers
The first thing you should check is the air filter. It may be clogged with dirt.This would cause it to over-heat and shut off. If that is o.k., then go to this Link to a couple of my Tips:
www.fixya.com/support/r6081405-cleaning_small_engie_carburetor
Good Luck!
Jim
Posted on Oct 07, 2010
1995 Yamaha Waverunner III dies won't run
Check cylinder compressions, this ski will overheat if one side is low. Thus is step one, if ok and within 10% of each other, verify the exhaust isn't clogged with sand from "beaching" third verify the crank seals are not leaning the Mix causing an overheat. Obviously check the impeller housing to exhaust line isnt clogged, disconnecting the thermal sensor is asking for a top end rebuild which is about 500.00 they are designed to reduce revs and alternate spark to the cylinders once 200 degrees is reached.
Jul 31, 2012 | Water Sport
Dishwasher is not drying. At end of cycle, dishes are still wet and damp, as well as the inside. Buttons are all pushed. Also, it seems to wash for more than one cycle. Did a light wash and after 1-1/2...
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Aug 27, 2010 | Whirlpool MDBH969AWB Builtin Dishwasher
My irobot (Roomba)is only working for 10 mins then
It should take about 6 hrs to charge. I had the same problem and reset the charging circuit. 1) Charge it until the green light comes on. 2) Unplug and pull battery out. 3) hold down the power on button 15-30 seconds. 4.) Put the battery back in, plug in the charger (direct - not through the dock) and charge for 72 hrs. Then, run at Max clean until the "I'm dead" tune plays.
May 12, 2010 | iRobot 4150 Roomba Vacuum
Hi ive got a 1999 cr125..got this bike a couple weeks ago and it was running fine. i crashed it and it ran fine for the rest of the day but after i crashed it it doesnt want to start or run. it seems 2 run...
Sounds like its starving for fuel. When the engine stops, instantly turn the fuel valve (at the tank) off. Then ck if the carburetor has any fuel in the float bowl.
Nov 26, 2009 | 2002 Honda CR 125 R
Mantis tiller won't run
No it will be fine. You would be surprised how many 2 cycle tillers Ive worked on where people put strait gas in them. they dont run long enough with strait fuel in them to do any damage. I hope this was helpful.
Aug 07, 2009 | Mantis 2-Cycle Tiller
My air and heat controls do not work (no power)
I had the same problem check out this sight for a possible solution:
http://www.wjjeeps.com/blower_motor.htm
May 23, 2009 | 1999 Jeep Grand Cherokee
Asus p5p800 motherboard
seem power supply fault, because some times, it looks that power going on, it is not giving proper voltage to motherboard. check other power supply.
Oct 16, 2008 | ASUS P5P800-VM Motherboard
Mantis 4-Cycle Tiller Logo
79 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
