Question about Ricoh Aficio AP3800C Laser Printer
Use scanner copies print not solid
When i use copier, print not solid...print to solve this problm
  • Ricoh Master
  • 691 Answers
Clean the optical path. Remove glass and use very fine quality micro fiber cloth with no cleaning agents to wipe mirrors and glass. reassemble and test. If no better then maybe focus is off!
Posted on Sep 14, 2008
I have toshiba estudio211 copier machine copy coming ....but painal show tols icon red err i give you one pic plz solve my problme.godbless u sir....
I have toshiba estudio211 copier machine copy coming ....but painal show tols icon red err i give you one pic plz solve my problme.godbless u sir.... Sir Please Help Mi
Oct 13, 2015 | Toshiba Office Equipment & Supplies
When making copies, only a part of the document prints; the rest is solid black.
Solid black in a copy typically means that the scanner is partially blocked. Open the top, where you'd place a sheet to be copied, and examine the small strip that runs down the side (left, most likely). See if it's clear, or if something is covering part of it.
Most copiers don't use the full size scanning plate for copies, but use a strip that scans the paper as it moves across it. If something blocks part of it, you get the black area.
Apr 12, 2015 | HP Officejet Pro L7780 All-In-One InkJet...
Solid black line when scanning or copying from KODAK ESP-3
Get a damp soft cloth and clean the scanner glass. If that doesn't resolve the issue there is a chance the scanning unit itself is damaged.
Let me know.
Cheers, Chris
Jun 21, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
Print a part of paper
I will recommend to do a negative post copy. Then check whether solid black or not. If not solid or blur, then the developer material might be dirty or not enough where u need to replace. If only certain area, such as top or bottom part not solid or blur, it might be caused by the roll guide also where u need to replace it.
To replace developer is very simple, take out the waste toner box, unplug the connector on the developer unit, loose one screw, and u can take out the unit. On the unit, take out the 2 screws, and u can open the cover.
May 25, 2009 | Toshiba e-Studio 350 Copier
Copying with 4" solid black vertical stripe
what about if you print from computer or do an internal print like a self test? if print looks good on those, you most likely have a scanner problem, which is the mechanism under the glass.
Jan 12, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Blurry bottom 2 inches of copy from IR 1600
Take a Normal,reduction and an enlarged copy(at any ratio) of a Newspaper in different size papers. Then check whether the blurred position is at the same position or not.If it is at the same position, check scanner for its free movement, there may be an obstacle which will not allow the scanner to move freely resulting in blurred copy. or else let me know.
Dec 27, 2008 | Canon ImageRunner 1600 Copier
KONICA 7020 - Blank copy
I have never heard of a developer moving backwards!!!!!!!!!!!!!!!!???
the motor that runs it, the .... there is too much involved to mention. A developper moving backwards will spill so much toner in the machine anyway.
If you get a copy and then it goes blank, that tells me you have a problem with the SEPERATION UNIT, it may be shorting out causing the paper to rise against the drum giving you blank copies.
A blurr copy tells me there is a problem with the Scanner/Optics area. maybe the rails that the scanner run on are too dry or has a problem, the optics(mirrors) may be misaligned.
Not sure what you mean by (hanging) ??
Jul 31, 2008 | Office Equipment & Supplies
The copy function prints a solid black page?
Do you see the light going all the way across? The printer may be having power issues. You should make sure it is plugged into the wall and not into a surge protector or a power strip.
If the light is not coming on then there is an issue with the scanner bulb and if the printer is plugged into the wall then you should call hp and see if you can have it replaced.
Jan 21, 2008 | HP Photosmart C4280 Aio Printer
Ricoh Aficio AP3800C Laser Printer Logo
70 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
