Question about Sentry Fireproof Safe
Our Sentry Fireproof Safe #A5848 2.0 will not open. We replaced the batteries. But it didn't fix the issue. The number keyboard is lit up but the box above it, that registers the ***** when you enter the code doesn't register anything when you try to enter it, nor do the #;s beep, like they usually do when you enter them. Also, the key doesn't open it either. We have Cash Customers All Day Long, Please Call Me ASAP if possible 847 223-2722 Dianne Cain Waste Management-Countryside Landfill Grayslake, Illinois Thanks
WirelessGreg
  • 14 Answers
SOURCE: Have a Sentry V260 safe.
You can do a Key override
If your electronic lock fails or you do not have any codes
available, you may use a key override to access this unit.
1. Remove the battery cover, disconnect and remove the
battery holder.
2. Insert the skeleton key (second set of keys provided)
into the key hole inside the opening for the battery.
3. Turn the key to the right.
4. Turn the four-bitted key to the right.
5. Open the door.
You can download the user manual here:
http://www.sentrysafe.com/pdfs/OwnersManuals/172967.pdf
Posted on Dec 29, 2008
SOURCE: Sentry Safe (DSW3607 Model) Won't Open
I finally ignored the poorly-written instructions for programming a personal code and simply entered the factory code first and then pressed the prog/enter code button.  The safe opened.  The instructions tell you to push the prog/enter code first and then enter the factory code or personal code to open the safe.  Wrong!  Do it my way should this problem happen to you.
Posted on Mar 23, 2009
  • 80 Answers
SOURCE: No keys to my sentry 1100 fireproof box.
you can.
the instructions are located link above.
mj
Posted on Sep 07, 2009
Testimonial: "Thank you very much!"
SOURCE: I have a Sentry Fireproof Safe (KS2100). Need to
You are supposed to apply downward pressure on the lid when you try to open it. See if that solves your problem.
Posted on Aug 12, 2010
SOURCE: Sentry Fireproof Safe #1100 Lost Key
no if you turn your lock box around so your key is facing away from you and place your right hand on the side top and your left hand on the box and push the lid to the right a good inch and a half and lift the box will open no problem key or no key. this is a very poorly made safe
Posted on Oct 03, 2010
i forgot my code and cant find my keys to open my sandleford safe n 15115 how can i open it
Jan 04, 2014 | Sentry Fireproof Safe
How do you open a sentry 1250 combination safe? I have the number
Locksmiths agree If your safe doesn't have a key, skip Step 3.
Turn the dial to zero.
Insert your sentry safe key and turn it until the plunger pops out.
Turn the dial to the left (counterclockwise) three times to the first number of the combination (pass the first number of your combination two times, stopping on it the third time).
Turn the dial to the right (clockwise) two times to the second number of the combination (pass your second number once, stopping on it the second time).
Turn the dial to the left to the last number (stop the first time on your last number).
Pull the handle down; cracking the Fireproof Sentry Safe open.
Jun 06, 2010 | Sentry Fireproof Safe
How do you replace batteries of a Sentry S0607?
How to install electronic fireproof sentry safe batteries
slide open the battery cover located just below the keypad.
Insert a paper clip or pen point into the small hole in the cover. Push in while sliding cover to the right. Disconnect and remove the battery holder. Insert the 4-batteries as indicated.
reconnect the connector and put back the battery holder. Slide the cover back in place.
New advanced electronic lock safe battery replacement instructions
May 05, 2010 | Sentry Fireproof Safe
The Sentry V260 safe will not open. Replace batteries?
Locksmiths agree on how to install sentry safe batteries
reconnect the connector and put back the battery holder. Slide the cover back in place. How do I insert the batteries on my advanced electronic lock safe? On the newer model Fireproof Sentry Safes my locksmith recommended me To install batteries,
turn the electronic lock case to the right and remove. Insert four new batteries as indicated, replace the electronic lock case and turn to the left to reassemble.
Mar 11, 2010 | Sentry Fireproof Safe
I lost the combination to my sentry safe serial numbers 4895857 had it for 10 year geting kida old can you help
Sentry Safe lost combination. First, find your Sentry Safe's Serial Number. The Serial Number is printed on the small label on the right side of safe, on paper tag near bottom hinge, below the cover plate or you can look behind the handle with a mirror. Just note your model # and the serial #.
Sentry Safes express combination research is fast with a next day Service. The email is sent the next business day with the sentry safe combination and opening instructions. Although there is a service charge it's still cheaper then locksmith drilling a Sentry Fireproof Safe open.
Jan 29, 2010 | Sentry Fireproof Safe
Change battery of sentry safe
To install sentry fireproof safe battery
reconnect the connector and put back the sentry safe battery holder. Slide the cover back in place.
Dec 01, 2009 | Sentry Fireproof Safe
Sentry safe S3877 have key and know combination but battery dead
Use paperclip to push in pin size hole below keyboard and then slide panel to right. Battery box is right there. Replace batteries and then was already to accept code.
Apr 08, 2009 | Sentry Fireproof Safe
CAN NOT OPEN MY SAFE, MISPLACED INFO, LOCKED CODE NUMBER IN SAFE. ELECTRONIC FIRE SAFE NUMBERS ON OUTSIDE OF SAFE OA3817 BA69609
To retrieve your lost sentry fireproof safe combination. First, find your safe's Model and Serial Number. The Serial Number is printed on the small label on the right side of safe (on paper tag near hinge) or under handle. As this information is confidential a valid credit card and email is needed to verify a customers name and address
sentry safe combination archives searches. Do come with a service charge although it's definitely cheaper then buying a new home electronic sentry fireproof safe.
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements
May 01, 2008 | Sentry Fireproof Safe
I lost the cobination for the safe and i cant open it
A
good locksmith should be able to help you with the dialing programming instructions and lost Sentry Safe Key Replacements.
Apr 01, 2008 | Sentry Fireproof Safe
Sentry Fireproof Safe Logo
518 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
