Question about Toshiba Televison & Video
TV Toshiba 29VH27DP colour television
The TV is bought in September, 2004
The indicator on the infra-red block does not shine and the TV is not included
At inclusion manually the switch noise inside is heard as though the relay frequently is included
I have disassembled the TV and have found out visually, that the power unit, now replacement of a power unit has broken down will lead to to normal work of the TV
Posted on May 29, 2008
My remote for tv wont work ,bought new one still wont work ,
It sounds that the infra-red sensor inside the TV is faulty. Contact any service technician. Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV
Jan 02, 2015 | Televison & Video
Red blinking light after colour wheel replacement on 62hm85 toshiba
You really need to look to see if the color wheel cables are connected or not.
Dec 15, 2012 | Toshiba Televison & Video
How do i put a code on my urc 11-1625 remote for the Toshiba T.V and could i also get the code for the Toshiba television ?
Set up codes for Toshiba TV are:
0159 0178 0109 0120 0181 0105 0049 0095 0170 0260 0358 0394 0924 0012 0095 0117 0141
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Jul 26, 2012 | Toshiba Televison & Video
Remote doesn't work
Check your remote batt first. if batt are new, check infra red light from remote using camera (selular cam etc). If infra red flashed on cam, that indicate remote is no problem. Call technician to check your tv.
Mar 24, 2011 | Sony Bravia KDL-26L5000 26 in. LCD HDTV
The color looks red and the picture is not clear. Just started this morning. We bought the tv in September of 2000. Do you know what the cost of this tv was new?
This problem is very common with rear projection TV's.
It is related to one or more of the colour guns being out of alignment or needing to be replaced. The only way to correct this issue is to have a technician come in and fix it or bring it into a repair center. I personally would suggest purchasing a new TV. The cost of getting them aligned is usually more then a basic LCD.
The original MSRP was 4100 I believe.
Hope this helps
Dustin
Feb 12, 2011 | Hitachi 53SDX01B 53" Rear Projection...
Blocks of Colour displaying
 This tv has severe problems in the image processor - you bought a dud. Try getting your money back.
Jun 26, 2010 | Samsung Televison & Video
SONY KV-20FS100 does not turn on
The standby light should be blinking a repeated count with a pause between counts. Can you post that here please? That will indicate the cicuit in which the problem was found that casued the shutdown. Armed with that info, I should be able to indicate the most probable defective parts and how to resolve the problem.
Thanks,
Dan
Feb 13, 2009 | Sony FD Trinitron WEGA KV-20FS120 20" TV
NEW REMOTE NOT WORKING
Greetings!
Chances are good that both the old remote and the new remote are OK. A TV repair facility or, in some cases, your local Radio Shack dealer may have an infra-red indicator that will show if the remotes are outputiing any infra-red light. This does not confirm that the data riding on the light carrier waves is good data, but in most cases if the remote is putting out light it is also puting out good data.
Since you have two factory original remotes with the same problem and one of them is brand new it is more likely the problem is in the TV itself. Impossible to say without inspection, but the first suspect would be the infra-red receiver. Although you did not spend a lot on the set oroginally it would still be worth the repair if your loacl servicer is a fair one.
Rob
Jan 02, 2008 | Polaroid TTM-2003 Combo
Sony KDF-55WF655 55" LCD Projection TV
I have the same TV and the same problem, I take out the block of colours red, green and blue (the blue colour is broken) and I went to the electronic supplies for ask the price  and they don't sell just the little blue mirror (blue pixel), they sell all block for $2,050.00 dollars. It's the price for a new one
Oct 09, 2007 | Sony Grand WEGA KDF-55WF655 36" Rear...
Televison & Video Logo
69 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
