Question about Dell Computers & Internet
When I push the powerbutton my PC doesn't start. This while I've connected the powercable etc. The powerled on the motherboard is glowing. What could be the problem?
  • 37 Answers
This could possibly be due to the wiring of the button itself. If you consider yourself to be even remotely tech sauvy, try this.
  1. Remove the side panels. This should be fairly simple to do.
  2. Locate 2 wires connected to the button. These will probably be thin red and black wires.
  3. GENTLY check to make sure if they are both connected to the button.
  4. If not, you will have to soder it back on.
Hope this helped! Tell me how it worked out!
Posted on Oct 07, 2010
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard?
If you have knowledge of computer hardware and also have a tool for open the computer cabinet, look at the 9 pin on motherboard one is shot out of ten pin, in the pin panel there is market some word to connect the panel Like Pw bt -Power button, Rst-Reset, Pwr-Led-Display Led, HDD-Hard disk Led, and SPK-Speaker Button. Inser all cable acordingly which is allready marking with coat sign
Sep 23, 2014 | Acer Aspire 7720 Notebook
How do i connect the front panel (Powerbutton etc.) with my acer m7721 motherboard (FP1 Pins)? Thanks!
Look onto motherboard there is marked as a name of pw btn--power button and plug in front pannel pwr cable pin here
I have a 4500 John Deer tractor that typically won't start in cold temperatures (i.e. 39 or below) otherwise it starts promptly. I've pushed the key in to heat the glow plug a minute or more.
The 4500 John Deere tractor sounds like the glow plugs are not working. Checked voltage at the glow plugs to make sure that there is 12 DC volts.(Might have to remove main wire from the glow plugs to check!) If no voltage at glow plugs there maybe a bad fuse,relay or wire connection in the glow plug circuit. If there is 12 DC volts at the glow plugs, it is possible that the glow plugs need to be replaced.
Jan 01, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Hi guys, I have big problems with my computer. It won't start. When I press the powerbutton the white light turns on for a second or two, then it turns black and nothing happends. When I connect the...
Considering the change in time and date,I would suggest you replace the CMOS battery.This battery helps in memory storage of your PC.
Have you tried the charger on another PC maybe?Try it,and if it fails replace it.
Remove the hard disk and re-fix it again.
Hope this helps.Thanks!
Oct 31, 2011 | HEWLETT-PACKARD Hewlett Packard HP Probook...
My intel d865gsa mother doesn't get on when i press powerbutton. When i press powerbutton, the green lights gets on as long as i press powerbuttom, cpu fan rotates at low speed but when i short the...
Go to to eBay and search for "Computer 20 / 24 Pin PSU ATX SATA HDD PC Power Supply Tester". costs less than $10 USD, It will verify the PS unit is good, then you can determine if there is a problem with the motherboard. Bad PS is most likely the source of start problems for PC motherboards.
Aug 22, 2011 | Intel D865GVHZ Motherboard
There is no toggle/powerbutton on the face of the tower
If this is atx power it should be just push to on button look for something that can be depress. On motherboard connection follow motherboard manual. It should be on a header. Together with the reset, power led light, hd LED and the power itself.
Apr 18, 2009 | Computers & Internet
My Acer RC500 don't start up anymore.
Check the motherboard for obvious bulging capacitors. If you don't see any you still might have bad caps. Additionally you may have a faulty power supply.
Mar 27, 2009 | Acer Aspire RC500 PC Desktop
Powerbutton connection wires were disconnected from motherboard
Look in the manual there is a diagram and pin connections for each wire.
Feb 06, 2009 | E-Machines D2046 PC Desktop
Problem with panel one
The manual is here http://www.pcchips.com.tw/PCCWebSite/Downloads/DownloadFile.aspx?catid=1&driverid=1182&areaid=3&LanID=0 it should have a picture telling you where to plug them in.
Aug 25, 2008 | PC Chips MB PCCHIPS P25G V3.0 P4M800CE 478...
Panel 1 settings
Hello ocea, Here is a link to the manual: ftp://ftp.biostar-usa.com/manuals/M7VKF/M7VKFmanual.pdf Here is a picture of the front panel settings:
Oct 14, 2006 | Biostar M7VKF Motherboard
Computers & Internet Logo
37 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
