Mitsubishi DLP W62627 displays lotsof yellow and blue...color is not right, although picture seems ok do I need to replace lamp or is it more ??
    Problem Solver:
  • 11 Answers
Try to reseat the DVI cable between the chassis and optical engine. If this doesn't fix the problem, you will have to replace the optical engine. The lamp is not causing this problem. A new optical engine can be pricey. You would have to get it from Mitsubishi. $450 + $300 core charge. You do get the core charge back when you send in the bad optical engine.
Optical Engine Part Number:
938P017020
Posted on Oct 07, 2010
Replaced lamp on my Mitsubishi 82 in dlp. after 15 minutes pic started to flicker losing color. was advised to also change lamp ballast, did that but still flickers with new lamp. put old lamp back in tv...
When you put the old lamp back in did the picture look OK? If so why did you replace to begin with? Yes, there are some poorly manufactured lamps out there, where did you obtain the replacement? Was it true OEM?
Dec 04, 2014 | Mitsubishi Wd-82837 82" Inch 3d Full Hd...
YELLOW SCREEN
How old is the lamp? the lamp may be failing and or the optical block may be damaged.
Jul 13, 2008 | Mitsubishi VS-45609 TV
How can I stop the colorful spotting in the display of my NEC NP410 Projector?
Its the dlp/dmd chip going and soon will look like the star screen saver on windows 98. it will need replacing. they start with one or two dead pixels then it spreads. ref only->https://www.replaceyourlamp.co.uk/projector-lamps/nec/np-u250x/dmd-chip-1076-6439b/dlp-dmd-chip-1024x768-pixels-model-b.html
Mar 02, 2018 | NEC NP410 3LCD Projector
I turn on my Mitsubishi WD-73833 TV and it turns itself off
Lessing of brightness on a DLP set is a sign of imminent bulb failure.
A new bulb is in order.
Nov 23, 2013 | Mitsubishi WD-73833 73" HDTV
I have a Mitsubishi WD65738. The picture stopped working and still had sound. I replaced the lamp and cartridge and now it doesn't turn on and i just get a flashing yellow light. What can I do?
If you replace the lamp you need and got sound no picture is your color wheel. Make sure the cover wherew the lamp goes is close completly other wise it would not work.
Thank you
Nov 22, 2013 | Mitsubishi WD-65738 Medallion 65 3D DLP...
I have a 2 year old Mitsubishi WD-73732 - 1080p 73" Medallion Series DLP HDTV - WD73732. I am getting blotches of color when there are large areas of blue color. Looks like irregular moving stains...
It will cost you probably in the area of $700.00 to replace the Light Engine. I don't think it would be a good idea to repair it. DLP sets have been out of production a few years now due to high failure rates of the light engines for all makes and models and the consumer cost for the lamp.
Nov 10, 2010 | Mitsubishi WD-73827 73" HDTV DLP TV
DLP Colors Are Off - Picture Is Mostly Blue and Yellow
You are missing either red drive signal to CRT or you have a cold / fractured solder joint on the television. Also with the set unplugged check with a non metalic object like a ruler or a wooden spoon and start tapping around in the front or back of set and see what happens. See if you can narrow which area of the set has a problem... Good luck future technician.. Happy holidays.. Jay
Dec 08, 2008 | Hitachi 43FWX20B 43" Rear Projection...
Mitsubishi rear projection tv color problem
I'm going to guess that this unit is a DLP projection set and that the lamp is not new. Try a new lamp. The heat of the lamp will char over time. If not the lamp, some of the internal filters in the light engine might be getting effected by heat and require replacement.
Keep us posted.
Dan
Sep 12, 2008 | Mitsubishi Televison & Video
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
