Question about Harman Kardon AVR 310 Receiver
My redceiver gives me a message saying "protect" when i turn the volume up. this started after i hooked up a subwoofer, why is this happening?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 73 Answers
You should consult the manuals for the receiver and the subwoofer to make sure you haven't connected the sub improperly. If the amp was working normally before you connected the sub, I would look at the sub hookup first. If the sub is a passive type, and you have connected it in parallel with your main speakers, the amp may not be able to handle the extra load. You may have to get another amp to drive the passive sub. If you have an active sub, you may not be using the right input/output connections between the amp and the sub inputs. Or, you may have hooked the sub up in a way that causes the amp to become unstable. Check the manuals. If you can't resolve it, come mback here with a lot more detail about your gear.
Posted on Oct 07, 2010
Subwoofer ain't doing anything on peavey triflex
Could be a few issues. If it is powered up when you plug it in, it might have a short circuit protection that shuts it down, or a thermal overload that is over sensitive. It might also be an issue with the cable you are using to connect it, from a broken wire to one that has a plug just slightly too long- there are 5 different tip lengths.
This also assumes the input itself is not being over driven, and that the output is not shorting out either..
Jun 10, 2012 | Music
My stereo sysytem is a mini stereo: serial number 10200055. It currently says "protect", what is this and how do we return our system to normal operations?
When the word PROTECT appears on this display, this means the unit has detected a critical fault which could potentially cause harm to your stereo system.
The most common cause is a short circuit somewhere - something even as simple as loose speaker wiring could cause a short, triggering the Protect message.
You will need to determine if there is a possible short somewhere, so I recommend you start by firstly turning power OFF, disconnecting all speaker wires, then turn unit back ON.
Operate the stereo (without speakers) and turn volume up:
  • If Protect message appears when turning volume up, then stereo unit itself has an internal fault
  • If no Protect message appears, then suspect the speakers may be causing the issue.
  • Reduce volume and turn unit OFF
Re-connect speakers (ensure the connections are secure), turn unit ON:
  • If turning volume up triggers the Protect message again, there is an issue with the speakers or connections
Hope this helps.....
Sep 04, 2011 | Kenwood Audio Players & Recorders
My receiver gives me a PROTECT message when i turn the volume up to high and it shuts itself off what does this mean? this started after i hooked up a subwoofer
There is likely a problem in the power amp section that only becomes apparent when the increased volume demands sufficient current in that stage to push the amp into a potential component failure situation. The protect circuit clicks in and disconnects the speakers from the amp to protect them from damage should the power amp stage experience a catastrophic failure. Unless you are a trained technician, you should have the unit repaired before major damage occurs.
Oct 07, 2010 | Harman Kardon Audio Players & Recorders
I have a 1200 watt G-Max sub amplifier and it just went into protect mode
Turn down the volume or power settings on it since its pulling too much power and shutting off for a few sconds to keep from blowing. Depending on the amp and speakers your using dont bridge the channels. If it won't come out of protect mode then unhook everything and just hook power, ground, and remote and wee what happens. If it comes on again and stays on then amp is blown.
Aug 11, 2010 | Jl Audio Car Audio & Video
When my RCAs are hooked up to my amp, my subs start hitting without any volume turned on
1. Check Grounding system (Player and Power Amp).
2. Ensure your RCA cable is OK
3. You might adjust volume or bass volume on power amp to maximum, just set all to 50% while you are tuning.
Mar 28, 2010 | Kicker CVR12 Car Subwoofer
My amp will go into protection mode when i turn my truck on, it flashes green and beats once,then turnd protection mode on... whats wrong with it??
im not sure what is wrong but i do know if you keep it hooked to subs it will fry them because that happened to my friends jackhammer amp and 2 12" mtx jackhammers
Mar 10, 2010 | Fusion FEW12PK Car Subwoofer
S series sub cuts out
this sounds like an ohm load problem do u have it bridged
Nov 01, 2009 | Alpine SWR-1222D 12" Type-R Series...
Amp goes into protection
make sure the impedance is right for the amp you're using. If you're using a 4ohm amp and a 2ohm sud that may be the problem. It may be overdriving the amplifer which is bad and can cause damage to the amp. Hope this helps.
Jun 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
Raised volume cuts sound and gives me "overload" message
A couple of possibilities: Bad solder on power regulators (attached to main heat sink) or cooling fan may not be turning on when volume is raised.
Jan 16, 2009 | Audio Players & Recorders
Speaker system
This definately means that you have a positve and negative speaker wire touching somewhere. First thing to do would be to check all connections at the speakers and on back of receiver and make sure all wires are seperated. This is a common problem if two wires are touching each other. If you check all connections and they look ok and you still have same problem you need to start unhooking all wires and hook them up one at a time and turn on system. If it works with one speaker then try hooking up a second speaker wire and so on until it gives you protection message again. Basically process of elemenation. Once you says that protection message you need to replace the last wire you hook up all together as you could of damaged it when running speaker wire or it could be a defect in speaker wire.
Nov 09, 2008 | Samsung HT-P38 System
Harman Kardon AVR 310 Receiver Logo
76 people viewed this question
Top Harman Kardon Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Electro Med Services...
Are you a Harman Kardon Audio Player and Recorder Expert? Answer questions, earn points and help others
