Question about Brother XL-5340 Mechanical Sewing Machine
My machine is trying to sew backwards! moving the backward switch doesn't change it at all.
    Genius:
  • 1,788 Answers
Try taking off the cover and then use a hair dryer pointed at the reverse mechanism, it may be stuck. Also oil according to your manual. If you cannot find your manual, go to www.brother-usa.com and download a free one.
Posted on Oct 10, 2010
Problem with feeddog on my sewing machine
When the feed dogs have been dropped, some machine feed dogs will not become activated (rise & move backward & forward) until stitching is begun.
Be sure the stitch length is set high enough to actually cause the feed dogs to move forward & backward.
If they still do not move and your machine is mechanical (not computerized), the old oil may have solidified and is preventing them from moving. A good cleaning and oiling may be required. Other than that, it may need service.
Aug 26, 2016 | Sewing Machines
Machine will only sew in reverse
You wrote,
"Machine will only sew in reverse - Sewing Machines" A: I'm just a tinkerer, hobbyist, who did run across this same problem before. I can give a general non-model specific remedy based on my limited experience with mechanical sewing machines that get locked into sewing backwards, that is "they only want to sew in Reverse":
1. Verify what is the normal direction of the fly wheel in forward sewing for your machine. Most sewing machines, including Singers, always sew with the top of the flywheel moving toward the operator, regardless if sewing forward or backwards; but older friction-wheel White Rotary (RF) sewing machines, have the flywheel running in the opposite direction (top of Hand-Wheel turning away from the operator when sewing.
2. If it has Reverse Lever/Switch; check that it is in the correct position; if still only sews in reverse, change positions of the Direction Control lever (or Button, etc.), and see if it changes direction to correct the problem.
3. If this does not help, then jiggle the Reverse Lever and follow the linkage inside the machine and see if there is anything broken, loose or out of adjustment. Some machines have reverse control linkage elbows in the top part of machine, and by poor design are prone to accidentally pop backwards, causing sewing in the opposite direction of the position of the Reverse Lever/Button (Backwards when you want to sew Forward). On occasion, a Kenmore 158.1787180 got locked into the backwards sewing mode (the dog-gone' est thing), but by following and analyzing the linkage, I found where it was going wrong, and popped the indecisive linkage elbow back the way it was supposed to be and fixed it. [ I had more detailed notes, on this fix, but when I read them, without the machine in front of me, made no sense to me today so I can't share that till I revisit the conundrum again.]
4. If all else fails, you may be able to hold or clamp the Reverse Lever/Button in the Reverse position, so it sews Forward (I've done this before too (as a short-term fix) until I figured out how to adjust it back the way it was supposed to be.
5. If this post helped you, don't be afraid to indicate so, so Fixya will know. If it was useless, "ouch", but I'd like to know that too, so I'll be more selective on what I really know more about. I try to help, though this is probably a trade secret that anyone who knows is discrete about who they share the information with.
Sincerely
-- Amender. (2016 FEB 24)
Feb 06, 2016 | Sewing Machines
My machine will not move forward.
Sewing machines have a "free sew" that allows you to move a hoop by your own choice any way you choose. This means the feed dogs are below the plate and will not move the material forward or backwards either. You need to find the button and switch it to feed.
Dec 08, 2014 | Sewing Machines
While stitching the cloth goes backwards instead of moving forwards.the backwards stitching switch is constantly on. What should I do
check to see if your machine is in buttonhole mode, one of the legs of the buttonholer will always be a reverse zigzag.
Sep 19, 2014 | Sewing Machines
My machines stitches backward instead of forward.
There is a forward and reverse switch you are missing. If you have a pedal it is a matter of pushing the pedal the right direction.
Jul 26, 2014 | Singer Inspiration 4205 Mechanical Sewing...
The Feeder Dogs are not moving forward or backwards on my sewing machine.
Are the Feed Dogs dropped? Check your manual for the location of the switch. .... otherwise your mechanism has been compromised. Take it in for repair.
Mar 19, 2013 | Kenmore Sewing Machines
Sewing backwards
try adjusting the top thread tension for the loops
try changing the needle
and see if that help any if not then take the machine back and
tell them what the machine is doing
if the machine was adjusted, then they should have checked the
stitches to make sure that the stitches were normal both forward
and backwards.
Jan 05, 2013 | Janome 1600P-DB Mechanical Sewing Machine
Started sewing backwards now not moving material at all
Sounds like the machine's age is causing the lubrication to get sticky.
Try changing the pattern by moving the pattern selector around.
Take out the bobbin and remove the thread and presser foot, raise the presser lever, set the pattern to zig zag, set the stitch length to maximum and run the machine at full speed. While it's running, repeatedly press the reverse lever all the way down. Run it for at least a few minutes.
Nov 14, 2009 | New Home MX-3123 Computerized Sewing...
I have a Janome 8080 that is out of warranty by a month and days. I went to use it and my handwheel will not let me move it backwards. It is not giving me a code that anything is wrong. I can't reach...
You should always move the handwheel forward. On some machines moving it backwards can throw off the timing. Try reverse and doing a couple of stitches to test.
Apr 12, 2008 | Janome 8080 Computerized Sewing Machine
Brother XL-5340 Mechanical Sewing Machine Logo
241 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
