Question about Acer TravelMate 240 Notebook
Keeps restarting does not bootup in safe mode also
  • Acer Master
  • 629 Answers
If safe mode does not work, try OS repair or reinstalled. This can indicate a corrupted OS. If reinstalling does not work either, it may indicate hardware failure. Try to isolate it by removing and reconnecting all components like RAM, hard disk, CD or DVD drive, battery and AC adapter and see how it goes.
Posted on Oct 07, 2010
Latitude d630. Why does it keep turning on and off?
Hi Sanni
Try starting in Safe Mode!
Start your computer in safe mode Windows Help
Or
On an Apple Mac just hold shift key down on BootUp.
Or Option key on Bootup to start up from a clean simple OS (Recovery Mode) which will allow Disk Utility testing
How to Use OS Boot Options to Troubleshoot Your Mac
Sep 13, 2015 | Dell Computers & Internet
Keyboard shortcuts on a HP Black Pavilion 20-b013w All-in-One Desktop ?
Hi Julie--I'm assuming by keyboard shortcuts you mean the way you used to get to safe mode by pressing F8 during bootup. If that's not what you meant, please clarify and I can revise the answer.
The easiest way to get to safe mode in Windows 8 is to move your mouse to the lower right corner of the screen to bring up the charms bar. Click on SETTINGS ---> POWER
The pop-up menu will give you three options, SLEEP, SHUTDOWN and RESTART.
HOLD DOWN THE SHIFT KEY and while continuing to hold it down, click on RESTART and this will immediately restart the computer and boot into ADVANCED STARTUP.
From the menu that appears, select the middle option, ADVANCED
then select SAFE MODE.
Mar 30, 2014 | Computers & Internet
I power up my netbook, i see the start up screen, then start windows normally to check disc and restart.
Start the machine in SAFE MODE by clicking F8, and some machines are F10, during the bootup. Run a virus scan in the safe mode, I use Malwarebytes which is a free program.
Mar 25, 2011 | Acer Aspire One Netbook 8.9" Notebook
Bonjour, I am philips laptop X57 EAA-89. I will : repair your computer. I tap F8. I am Advanced Boot Options. And I am not Repair your computer. I am : Safe mode Safe mode with...
Do F8 on bootup. Boot up in safe mode. Start removing all devices, one at a time. Then boot normal. Keep doing till you find the problem.
Mar 18, 2017 | Computers & Internet
Dell Optiplex GX280 restarts suddenly? all files closed and . the restart could be after 2,3 minutes of power on. I don't know why its behaving like this?
Hi, sounds like a crash, do you get any report messages after reboot? Try starting in safe mode; press Del button during initial bootup, once in safe mode you can reset to a time before the problem started. Hope this helps, if not come back to me?
Jul 10, 2010 | Dell Computer Refurbished SYSTEM BOARD -...
Input signal out of range and the monitor keep going off
Your PC is putting too high of the resolution for the monitor to support. You need to set your PC video resolution to 1280 x 1024 @60Hz (native resolution) for this monitor. Bootup in safe mode (hitting F8 key during bootup) and set the resolution to 640x480 then reboot in normal mode, then reset the resolution to 1280 x 1024 @60 Hz.
Feb 23, 2010 | HP vs17c 17" LCD Monitor
Laptop hard drive
Restart your system in safe mode...(If you dont know how to, it is :- When you power on your system, keep tapping F8 key, then a screen will appear which tells you to choose from it, so select Safe mode Startup from here)..., then after you have bootup in safe mode, open my computer, and right click on your harddisk, then go to properties, then tools, then Under Error Checking, click on Check Now tab, Then select the two options there, which are Automatically Fix File System Errors and Attempt recovery of bad Sectors, then click on Start, it will then prompt you that it wants to reschedule it to next System restart, so accept it and restart your system, when your system restarts allow it to scan your harddisk fully. Incase you have two or more partitions, try and do the same thing for ALL of them.
This method will save your harddisk, depending on how bad it has become.
Hope It Helps.
Jul 10, 2009 | Dell Inspiron 1525 Laptop Jet Black (15.4"...
Unable to get pas message at bootup
I am sorry to say but seems like your system perhaps the Windows system files got corrupted. Boot your computer up to the Windows CD and run a repair. If this does not do it, you will have to reinstall Windows again.
Apr 09, 2009 | Everex StepNote NC1500 Notebook
Toshiba A-215 will not boot after windows update
Hi there.
Boot the machine into safe mode by restarting the PC, as it boots up hit the F8 key until it giver you a sub menu with safe mode at the top and select that.
Hopefully the system will boot into safe mode, if it does you want system restore (if you use Vista a pop up window will appear on the right hand side of the screen, click on system restore, with XP just follow on-screen instructions)
All you have to do is select a date to before you performed the updated and restore from there.
Please keep us posted!!
Good luck and thanks for using FixYa!!
Mar 24, 2009 | Computers & Internet
Acer laptop bootup problems
Please try and bootup your computer in safe mode by pressing the F8 Button just before windows starts to load. a menu appears and you just need to select the safe mode option and see how it goes from there.
Let me know if this helps.
Oct 27, 2008 | Acer Ferrari 4000 Notebook
Acer TravelMate 240 Notebook Logo
49 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
