Question about Black & Decker BDTF1010B Tower Fan
How do you open up a BDTF101B Tower Fan?
Our tower fan stops oscillating when it hits a certain spot, usually the end of the first cycle. I'm trying to open it up but haven't had any success. Please help!! Thanks
  • kenhiveley Jul 02, 2008
    We tried to clean the fan and most of the edge seam will separate; however, it seems that the casing will not entirely come apart.  Please help!
  • Anonymous Jul 12, 2008
    Mine stopped oscillating soon after I bought it over two years ago, and I've never been able to clean it. It is a POS. I just bought a better fan from costco.
First you have to remove the two plugs on top behind the buttons remove the two screws next you have to remove the base stand and their is one screw you have to remove then you can remove the front cover and you can get to the motor and fan.
Posted on Jul 12, 2008
  • jimrojas Jun 30, 2011
    I took apart a Pelonis blower fan with the same oscillating issue. It also has the TYJ50-8B1 Synchronous Motor. If you pry apart the oscillating motor, you will find a plastic gear with broken teeth. I replaced my plastic gear with a metal one, It has work flawlessly since. The plastic gear isn't designed to handle the stress of moving all that weight back and forth for very long.
How do I clean a Bonaire oscillating tower fan btf4002
The easiest way to to use pressurized air. Buy a can or use compressed air.
May 23, 2014 | Bionaire Slopeflow 40" Tower Fan with...
Comfort zone tower fan won't oscillate
Remove bottom and check if gear is stripped or very dirty so can't turn.
Dec 14, 2013 | Comfort Zone 30 In Oscillating Tower Fan -...
I stupidly tried, in the wee hours half asleep, to force the fan to turn to a certain direction when the oscillation was turned off. Something broke and rattled around, and now the oscillation is...
Unfortunately, no - the manufacturer does not supply replacement parts. It is a throw-away item.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 06, 2010 | Seville Classics MSC10166 Tower Fan
I have lasko fan sudenly it stoped oscillating can u help me with this ? Lasko 48" Xtra Air Tower Fan with Air Ionizer.Model 4820
I have the same issue, i determined the oscillating motor has a bearing failure. I need to find a replacement motor.
Jul 17, 2009 | Lasko 48" Xtra Air Tower Fan with Air...
FTT-R tower fan would oscillate but the fan would not run.
You might have a stripped gear in the tower where it oscillates. Hope this helps!
Jul 14, 2009 | Black & Decker BDTF1010B Tower Fan
My oscillating fan has stopped oscillating how can i fix this
pls check first if the mode was properly set, or if not follow the manual you own from the first you bought the item. or try to unplug the item and open the back panel look if the gears is loose or broken.
Jun 30, 2009 | Black & Decker BDTF1010B Tower Fan
Squeak in aloha breeze tower fan model 05538
If the model is equipped with a fan, and the noise occurs even when not oscillating it must be a fan/blower motor. If it is a squeak. A squeal could be an electical component going bad which is always bad. I would definitely take some bottom drawer tools , ie. screwdrivers and WD-40 and oil that squeaking motor. Being a fan it goes through alot of air pollutants. That tends to build up on the shaft and can work its way into the bearing seal. Good luck.
Jun 28, 2009 | Tower Aloha Breeze Fan
Aloha Breeze Tower Fan Will Not Oscillate
hi,
yes this is the oscillation motor, and they generally arent servicable, and need to be replaced, you can try and oil it, sometimes they have small air vents, and you can do a voltage test with a voltmeter but I believe the motor has failed or is gummed up, you can try and take it apart, they are held together with bent metal compression areas along the circumfrence of the motor, try sewing machine oil, you might have to do some research to find a replacement motor, maybe take it to a local clock shop, those motors are very close to what they used to put in old wall clocks.
good luck
J
Aug 05, 2008 | Tower Aloha Breeze Fan
LASKO fan problem
Check for a loose wire in the wiring harness
Sep 01, 2007 | Lasko 2530 Elite WindTower Fan
Black & Decker BDTF1010B Tower Fan Logo
1,091 people viewed this question
Top Black & Decker Dryers Experts
Are you a Black & Decker Dryer Expert? Answer questions, earn points and help others
