Question about Kenmore 63942 Dryer
Runs hot air after awhile blow cool air - Kenmore 63942 Dryer
  • 31 Answers
Model # tells me it is a convection oven. You can't dry clothes in a convection oven. they end up smelling like last nights dinner.
Please check the model #. there may be relay that controls the power to the heating element. this relay could be not functioning correctly, or it could be in the timer. maybe the thermostat that monitors the interior temperature is gone. It could be sticking closed. tough to say with the model number.
Posted on Oct 07, 2010
2 Suggested Answers
  • 83 Answers
SOURCE: maytag dryer not blowing hot air (2yrs old)
If the vent is blocked, it will not stop the heat, it will only restrict the air flow.
Generally a couple of things can cause the heat to stop.
Either the thermostat or the element.
I would first suggest the element.
It may be fatigued therefore the internal wire within the element becomes fragile and eventually breaks down. Although it is an electrical item, it is mechanically built and can fail.
In some dryers the element is held in clips.
These clips can cut into the element.
The thermostat maintains temeperature but again, it is mechanically built and can also break down.
If you are not capable of inspecting or troubleshooting the internals of the dryer (i.e remove the cover and look for the failurer), then have it inspected by a repairman. There is not too much that can go wrong with a dryer. The most expensive part wuld be the motor that spins the drum.
Posted on Sep 17, 2008
Temperature Control stays hot
check the control module that controls the coolant flow through the heater core.
Feb 09, 2014 | 2006 Dodge Charger
Audi a4 2.8l no heat
take the top off the filler cap run engine to boil. keep it full off water to the top. you will see air bubbles coming out as the engine gets hotter. squeeze the pipes on the rads to help the air come out. when fan kicks in turn engine off and leave to cool down.while you are doing this make sure the fan for heater is off but is on full heat. can have fan on number one on speed that is fine.
Mar 01, 2013 | 2000 Audi A4
Ac blows cold then hot air
Is the compressor running when it blows hot air ?
Jul 31, 2012 | GMC Sierra 1500 Cars & Trucks
My air conditioner blows hot air and my heater blows cold air. The heater will warm up after the engine has been running for awhile but when I turn the air conditioner on it takes power away from the...
check your blower motor under the passenger side of the dash, round plastic box three screws pull it out something might have fallen though your cowl and chewed up the fan blades. as for the ac your r-12 is probly empty or has a leak bring it to a local garage and have them flush and fill your cooling system. heater would be your thermostat not openig properly, by far your cheapest fix under ten dollar part.
Apr 04, 2012 | 2000 Toyota 4Runner
Laptop shuts off afer 5 minutes
Sounds like your laptop might be overheating. Does it reboot successfully immediately after is shuts down after 5 minutes or does it have to sit awhile before it reboots successfully?
If you can't boot it right back up after it shuts down, then it is definitely running hot and will only boot back up successfully after it sits awhile to cool off.
Things that cause it to run hot:
1) Dust... Dust clogged in the vents, fans and around the cpu and heat sink.
2) A Fan is not working
3) The Thermal Paste around the CPU and Heat Sink has dried up or is too thin to keep the unit cool.
For the best results you'll have to take the laptop apart to remedy the situation especially if you need to get to the Fan, CPU or Heat Sink.
You can try a can of compressed air and blow out the vents and fan area, that might work for a while but you'll be blowing the dust in. It's best to take it apart and blow the dust out.
Apr 02, 2012 | Toshiba Computers & Internet
My Window unit cools real well in the morning. The air flow from the ac is 50 degrees, then by noon the temperature is 80 degrees and then it won't cool again. I am trying to cool an 8 x 35 ft....
When was the last time you cleaned the evaportor coil and condensor coil???? When its cool outside the condensor if its plugged with dirty can mantain the right condensor Head Pressure by useing the cool outside air when it has to run with 80 to 100 degree air it can't get the head pressure with in range to cool the freon. I would clean the condensor coil.......
Jun 19, 2011 | Friedrich ZStar ZQ10A Air Conditioner
Dry run hot for awhile and next time I use it it blows cold air.
Hi, this could be because your fluff filter needs cleaning out or there is a blockage in the air exhast causing the machine to overheat and the thermostat to cut out until everything cools down, if that isn't the problem then perhaps suspect a faulty time switch or bad connections on the heating element.
hope this helps
Feb 13, 2011 | Kenmore Dryers
E4 in an innovair a/c
It sounds like you have a freon leak and may need a charge. When there is a leak, the compressor will run for awhile but without the proper charge, it will heat up and kick on on thermal overload. After the compressor cools, the unit will come back on. Have the unit serviced by a professional.
Jan 09, 2009 | LG LS-L1210CL Mini Split Air Conditioner
Intermittant hot/cold air from heater
Had the same problem with my Mazda6 awhile back. Took it to the dealer and they found the radiator wasn't holding pressure. They replaced the whole radiator under warranty (WHEW!). Not sure how to check for that kind of thing, but it's a start.
Jan 01, 2009 | 2004 Chevrolet Silverado 1500 Crew Cab
Kenmore 63942 Dryer Logo
42 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
