Question about Miele CVA4070 Coffee Maker
My machine has started brewing watery coffee - I have tried adjusting the grind settings and done a complete clean of the machine. Any suggestions?
  • 2 more comments
  • gpyfrom Oct 07, 2010
    It is definitely a miele cva 4070. I appreciate your help
    Tim,
    The grounds in the waste dispenser are also watery - i.e. they are not the more solid blocks that they are when the machine is working properly - also much less in quantity - the grounds are basically swimming around in water - so maybe we are onto something......
    Machine is about 3 years old - and not over-used - so would not have expected any issues. Unfortunately, (at least for these purposes) we live on an Island in The Bahamas - so there are no options for service - which is why we have solved most problems ourselves. Also had some of the typical brew unit error messages etc over the years.
    What is your suggestion here? I will take a look at the tamper and see if I can see anything physically wrong......
    Tim - thank you - I will follow your advice. I appreciate your help.
    President:
  • 2,777 Answers
Watery coffee, hmm that is a strange one. Please confirm that this is a Miele CVA4070 unit?
Let me know and I can definitely help!
Thanks
Tim
Posted on Oct 07, 2010
  • 2 more comments
  • Tim Grayson
    Tim Grayson Oct 07, 2010
    That is very strange indeed this is a very high end system. When it kicks out the grounds after brewing, does it look like the regular amount of grounds? Either it's not grinding enough beans or somehow the water is leaking around the brewing process and just going out the dispenser without going through the coffee... that's pretty much the only two possibilities. So when it's done brewing, check how many grounds it dispenses, does it look like the regular amount??
    Thanks
    Tim
  • Tim Grayson
    Ah hah, ok it then sounds like the tamping unit in this device may not be functioning correctly, or something is wrong in the actual dispenser system there that is not allowing the water to flow out rapidly enough. The more that I think about it, I think it has to be the tamper... There is a little plate that should compress down on the grounds to get them compressed and hold them there as it forces the water through the grounds. This is definitely the problem, one of these two possibilities. These units are usually very reliable at least for quite a few years before needing service. How old is this machine?
    Thanks
    Tim
  • Tim Grayson
    Oh wow that definitely complicates things, but how nice that must be to live there! :) Definitely take a look in there and see if it seems stuck... You may want to call Miele directly to see if they have any idea what exact part could be causing this issue as far as if it's a spring, or lever or what it could be, and if you could get the part from there. If anything ask to talk to a supervisor so you can get some higher level help, what they'd call Tier 2 tech support... someone that could walk you through exactly what you are looking at over the phone and help you get the part. (800) 999-1360 if you want to try.
    I am still researching this, have fixed CVA models before but not this exact one, but I am sure the problems lies in the actual tamping process, hopefully you can spot something obvious like grounds in there holding it up...
    Thanks
    Tim
  • Tim Grayson
    My pleasure, keep me updated here... if for some reason they can't help you at that number let me know. Also I always like to have the most recent comment on here... if I don't and wait 2-3 hours it could close me out of the problem, so please post only if you have an update and I will definitely get right back to you.
    Thanks!
    Tim
Why are the used grinding pads on my saeco odeo giro very loose and watery
I can personally confirm this fix from another similar question works: "I throughly cleaned and lubricated the brew group as directed by the manual. Apparently if the brew group doesn't move smoothly enough, it won't grind the correct amount of beans. Try lubricating and then brewing 2-3 cups to have the machine recalibrate the grind amount." My manual didn't have very good info about lubricating the brew group, so I referred to some Youtube videos demonstrating the methods. A sourced a 3rd party food safe lubricant from Amazon which I applied with Q-tips, but in retrospect they also sell Saeco "maintenance kits" which would have been cheaper & easier to apply, plus it includes a new O-ring.
Jun 01, 2014 | Saeco Odea-Giro Espresso Machine
Saeco Incanto Rondo right red light is on and I cannot make coffee. The machine grinds the beans but does not dispense any coffee.
Try to set the machine to grind finer. Common problem with this machine when the grinder grinds too coarse, and the coffee will not fit in the brew unit during the cycle. Grinding finer will allow the brew unit to compress and the machine should complete the cycle.
If this does not work there may be another thing to try, Let me know support@cerinicoffee.com
www.CeriniCoffee.com
Apr 09, 2011 | Saeco Incanto Rondo Fully Automatic Coffee...
Coffe is too watery, and pucks are very loose
Try adjusting the grind finer. You have to do this while the grinder is running, Try 2 numbers towards fine. Then you will have to brew 2 coffees to get a reading on your adjustment.
Mar 02, 2011 | Saeco Incanto Classic Espresso Machine
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
How can I ajust my machine the coffee is coming out weak and watery I don't get that creamy,strong coffee anymore
HI
There are more than a few things that can cause weak coffee.
Grind is too coarse. It should look like coarse sugar.
You cleaned the brew unit and left a part out or put it in incorrectly.
Grind adjustment is set too high. Turn to a lower # while the grinder is operating.
Grinder is been taken apart and not put back together correctly.
Grinder is broken and the grinds are just big chunks.
Oct 23, 2009 | Spidem Trevi Digital Coffee Maker,...
Waret Pucks
Hi There are 2 problems that can cause a watery puck. 1. Like EsWorld said, If the grinds is too coarse it leaves room for more water and you get a watery puck. 2. But if your grind is like a grain of salt, the you don't have enough coffee going into the brew unit, and this leaves room for extra water. To fix this, there is a lever on the top center of the door. The lever will increase the dose if pushed towards the back. DON'T push the lever to the full back position. This could cause an over charge, which could cause the brew unit to dump the ground coffee with out making because it could not compress the charge, or it could break the brew drive. 1 click back from the full plus is fine and will give a great shot.
Jun 03, 2009 | Saeco Royal Professional Espresso Machine
Our Saeco Vienna deluxe had a couple of problems: the grinder wouldn't stop grinding..coffee all over the place...stopped it cleaned it and it's ok. The other problem is that it takes forever for a small...
What does the coffee produced taste like, is it bitter and watery, is there any creama on the espresso shot. Try adjusting the grind and the coffee level, maybe a little coarser.
Mar 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Brewing cycle and upper filter?
Be sure your metal strainer in the coffee puck funnel isn't clogged. Check you grind level adjustments also.
Best Wishes,
Lane
Sep 20, 2008 | Solis Master 5000 Espresso Machine
Miele CVA4070 Coffee Maker Logo
162 people viewed this question
Top Miele Coffee Makers & Espresso Machines Experts
Jerry Greenberg
Jerry Greenberg
Colin Stickland
Colin Stickland
steve morris
steve morris
Are you a Miele Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
