Question about IBM Wheelwriter 30 Typewriter
Nothing comes out on the paper when typing. Replaced the ribbon but nothing shows up.??
  • IBM Master
  • 3,594 Answers
You need to replace the print solenoid cap. We sell them for 20.00 includes shipping and instructions.
DickyO
Cleveland Business Machines
216-241-0027
Sales@CBMOHIO.COM
Posted on Oct 07, 2010
Why doesn't my new corrector ribbon/ink ribbon work? The wheel advances-nothing shows on paper.
Put in a multi-part form, type if the carbon is OK the problem is with the ribbon. Look at the ribbon if there is an impression on the ribbon but no ink transfer the ribbon is very ols, if there is no impression then the ribbon isn't lifting. THere ix a 2" black gear on the right side of the printer it should move easily if not wiggle it back and forth they get tooth for tooth with the drive gear.
DickyO
Oct 10, 2014 | IBM Wheelwriter 6 Typewriter
Why won't the new ink cartridge/corrector ribbon I bought, work?
there is a rubber bumper on the print solenoid the goes soft it needs replaced see a repair shop
Letters don't show on paper no imprint on ribbon. keys sound like they are typing but nothing shows on paper
Chances are that the print head is not locked forward. This happens when the daisy wheel or either of the ribbons are replaced. Just push it forward until it clicks
Oct 25, 2011 | Brother GX-6750 Typewriter
I have an IBM Personal Wheelwriter. New ribbon and type does show when typing. Any ideas?
IF UNIT SOUNDS LIKE IT IS TYPING BUT NOTHING SHOWS ON PAPER, THEN THE BUMPER PAD ON THE HAMMER SOLENOID HAS FALLEN APART AND NEEDS TO BE REPLACED. MOST TYPEWRITER REPAIR COMPANIES SHOULD HAVE THIS PART IN STOCK AND SHOULD BE ABLE TO REPLACE IT IN ABOUT 30 MINUTES.
Mar 30, 2011 | IBM Office Equipment & Supplies
Nothing shows on the paper when I type.
Remove and observe the ribbon, wind the feedwheel to see if the ribbon if moving at all. Make sure that the correction tape is not in front of the printheel and installed properly. (electronic machines use non-sticky lift-off tapes).. Observe the hammer movement. The ribbon winder in the cartrige could be defective, the ribbon ffeed mechanism in the machine may need repair/replacement. Make sure there is a printwheel in the machine.
Nov 15, 2009 | Brother GX-6750 Typewriter
SX 4000 Brother Electric Typewriter
With power off, remove the ribbon and look down inside the carriage assembly on the right hand side. Look close and you will see a white gear, you rotate that gear, either way about 1/2 a revolution. Power on and try typing, if it works you can put in the ribbon and go, if not, rotate the gear somr more.
Aug 27, 2009 | Brother SX-4000 Typewriter
IBM Wheelwriter 3
You probably have a broken plastic cap on the print solenoid plunger, they are available but a little tricky to install.
DickyO
Oct 07, 2008 | IBM Wheelwriter 30 Typewriter
Wheelwriter 5
You probably need the plastic cap that is on the proint solenoid, they are available but a little tricky to install.
DickyO
Sep 30, 2008 | Lexmark Wheelwriter 3 Typewriter
No Characters Typing
could be the ribbon is not lifting, do you see an image on the ribbon, also may be twisted inside the cartridge the shiny side has to be facing the keyboard.
Jul 09, 2008 | Brother EM-630 Typewriter
Hammer doesn't strike
Try taking the wheel out and aliging it with the piece in the middle with a hole in it so that the pin and the wheel connect when you push the lever forward to connect the wheel to the disk.
Aug 31, 2007 | Brother SX-4000 Typewriter
IBM Wheelwriter 30 Typewriter Logo
42 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
