Question about Keurig Elite B40 Coffee Maker
Water does not flow through when the Kcup is in. When not in, it flows freely.
BarrettDenCo
  • 1772 Answers
SOURCE: I'm having a flow problem with my keurig brewer.
you will need to give it a vinegar flush..white vinegar..I put about 1/2 cup with a full tank of water..keep running the water until empty..then run thru a full load of clean water..then taste some of the hot water..to see if the taste is gone....
you do not need to use k-cups for this
Posted on Dec 18, 2010
SOURCE: When the indicator says to brew, the water does
yes that is wright no flow of coffee
Posted on Mar 31, 2010
cmccune04
  • 213 Answers
SOURCE: Is it possible to replace the upper needle in a Keurig?
This is actually an ebay store. They have any Keurig part you could possibly need! It's the only steady keurig part business operating right now. Prices are fair products are in great condition. Seller has 100% positive feedback with 100's of satisfied customers who voiced their opinions of them.
They have parts for Keurig B30 mini, B40 Elite, B60 Special Edition, B70 Platinum, and B77
http://www.igotsweetdeals.com or
http://stores.ebay.com/Igotsweetdeals
Just ask for the part and they will get it for you guaranteed same day
Posted on Apr 13, 2010
woobie dog
  • 1273 Answers
SOURCE: water will not flow through k cup but will flow
Check that the lower puncture pin is not clogged. Pass a fine wire through it.
--W/D--
Posted on Jan 18, 2011
heatman101
  • 43501 Answers
SOURCE: the de-scale light turns off aand the water no
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
My keurig does not have water come out into the cup
1. always a dumb question but I have forgotten this more than once so I have to ask, does it have water in the basin?
2. A common issue with keurig's I've owned has been that some finer ground coffees will clog the spray nozzle that pokes into the top of your kcup. It's kind of a pain to clean,but if you are really careful it can be done with a very small jeweler's screwdriver.
UNPLUG THE KEURIG
lift the lid and find the groove that allows water to flow from the nozzle.
VERY GENTLY run the screwdriver across that groove being careful not to damage the nozzle by vigorous scraping. DO NOT ATTEMPT TO PUT THE SCREWDRIVER OR ANYTHING ELSE INTO THE OPENING.
Replace the water in the basin and try with a new kcup.
Jul 22, 2014 | Keurig Platinum B70 Coffee Maker
Keurig Coffee Maker Not Working
Refer to the manual: Usually the problem is a plugged tube (port or line) whereby the debris (Mineral or other) collect inside the flow lines. Using a Paperclip end, push up into the ports (Including the Kcup Basket) and free up the flow tubes. Use Distilled Water, fill container to the Line and not over that line. Purge occasionally and descale to clean out the lines.
Feb 22, 2014 | Keurig Coffee Makers & Espresso Machines
LIKE DRINKING WATER WITH A HINT OF COFFEE
You have 3 selections, thus use #1 or #2 for a stronger brew. Naturally the water levels will differ. Get a Reusable Kcup device and pack your own coffee for better results. Get fine ground coffee or grind your own, and then pack the Kcup reusable with your grinds. A fast hot water flow is excellent.
Feb 11, 2014 | Keurig K75 Platinum Coffee Maker w/78...
Allthe light keep flashing
Flashing is explained on page 16-17 of the manual. Usually if after pressing the cup size and flow; the water fails to go into the Kcup, the handle is not in full position. Open and shut with full engagement and strat over.
Feb 10, 2014 | Keurig Elite B40 Coffee Maker
Filled with water but blue light flashing says add water
Remove the container, take out the Filter, put two cups of water in the container and shake well for a few minutes. Wipe dry, and without the filter, replace and fill to max line. With out Kcup, try a run and see if you get hot water to flow. The Handle must me down and firmly in place to do this procedure. Flush a few times, and now you replace the filter, water, and Kcup. Try that. Use Distilled Water!
Feb 01, 2014 | Keurig B70/K75 Coffee Maker
Water heats up but will not flow through
The problem is the Water Flow from the top port. Clogged. The tube is the one with the needle point that punctures the top of the Kcup. Push a paper clip end up the tube to clear it. Flush often to keep the garbage out of the tube.
Jan 22, 2014 | Keurig B30 Mini Coffee Maker
Water flows through fine without a kcup, but only trickles out to fill a 1/3 cup with kcup. what should i do? thank you.
heatman101
Aug 05, 2011 | Keurig Ultra In Home Single Cup Brewer...
Water will not flow through k cup but will flow into mug without kcup
--W/D--
Jan 18, 2011 | Keurig Elite B40 Coffee Maker
Icemaker clogs with ice. Water flows with icemaker unplugged.
ur solenoid could be allowing water to flow freely its in the back its blue try replacing this solenoid and see if this fixes the problem they r cheap and easy to change
Feb 27, 2010 | Amana ARSE67RBB / ARSE67RBW / ARSE67RBC...
Slow water flow
that would be your water valve
Apr 10, 2009 | GE WJSR2070B Top Load Washer
Keurig Elite B40 Coffee Maker Logo
491 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
