Question about Home
B&q innocence p shaped shower enclosure with shower tower installation instructions
2 Suggested Answers
  • 80 Answers
SOURCE: We have a light bone shower enclosure that was
I have worked on vikrel tubs for the past 5 years and have yet seen a bone or any other color other than a light gray. Due to the tub making process, the tubs or showers are the color of the plastic use to make them. If you have a bone tub it has probably been refinished (factory? or by some company offering a bone vikrel tub. I would contact Kohler who makes the sterling line of tubs and ask their tech support about colorizing a vikrel tub. Look for a local and reliable tub repair company, they should be able to match the bone color. Ingredients in soaps and shampoo's tend to affect the refinish material.
Hope this helps you out.
Posted on Sep 08, 2009
Had shower installed. shower leaks from under the base of shower. What could cause this?
your shower pan and drain assembly may not be tightened adequately, you may have a drain to 'p' trap leak, or the enclosure itself may not be completely sealed to water leakage.
If you have any means to visually inspect the plumbing, or the surround from the back side, do so while the shower is running, to identify where the water is coming from.
May 03, 2015 | Plumbing
Need to remove silicone from 4 part shower stall to repair & reinstall
I think you should contact to a professional who can remove this shower stall very easily without any risk. You can also have a look at shower enclosures for having such bathroom stuffs in affordable price.
Jul 14, 2012 | Home
Installation instructions for shower enclosure
This is the car repair section ,better still change husband and get one with a tool kit
Apr 13, 2012 | Cars & Trucks
I am a complete novice, can you help me please? I have purchased a 3.5 SATA/IDE back up enclosure to transfer files from old to new desktop. I have removed frame holding old harddrive into tower but cannot...
You want to remove the hard disk from old computer, connect it to the enclosure, and connect it externally to the new computer, right?
Now you have a problem connecting hard disk to the enclosure.
Usually there are no SATA/IDE enclosures. They are either IDE or SATA.
If the data connector in the hard disk (HDD) is rectangular with around 40 pins inside, it is an IDE HDD. Else if it has L shaped horizontal connector, it is a SATA HDD.
I suggest you to take the hard disk to the store and ask for a matching enclosure. If you bought the wrong one, they might replace it with the correct one.
If you feel you want to do it yourself, let us know. However an IDE HDD cannot be connected to a SATA enclosure and vise versa.
I sincerely hope you will get to copy the required files to your new computer. However before copying, it is better to install a reliable virus guard.
Sep 14, 2011 | Computers & Internet
I just installed abrand new single handle delta shower faucet and the water does not get hot enough.
Many single-handle shower mixers have a hot limit, usually limiting the throw of the handle. You could go to the mfg's website (www.deltafaucet.com) & find instructions for adjusting it. Or, if you're handy, you could take off the handle & have a look; it shouldn't be too hard to see what's stopping the handle from turning more towards the hot side. Make changes in small increments & remember where you started.
Mar 01, 2011 | Delta & Single Handle Shower Faucet
Installation Rules?
There are four golden rules for installing a shower enclosure. The first golden rule is to make sure that the shower tray is level. If it is not, then problems will occur throughout the rest of the installation. Use a good quality spirit level and where possible install a tray that has adjustable legs. There are often problems associated with tiling over upstands as some are thick and difficult to set into the wall. The second golden rule is to install a tray that has a slim tiling up stand which is vertical and an integral part of the tray: This will make the installation easier, quicker and ensure it is totally watertight. Before installing the shower enclosure the third golden rule must be followed. A silicone sealer needs to be applied all the way around the join where the tiles meet the tray: This must be sealed first, to ensure there is no chance of water getting behind the wall channels and then into the walls. This is one of the biggest problems associated with shower installations but is easily solved if the silicon sealer is applied before the enclosure is fitted. The final golden rule is to fit the enclosure to the tiled surface and not on to a plastered wall, tiling up to it afterwards. Having installed the enclosure it is essential to use the same high quality silicone sealer around the outside of the enclosure. Sealing on the inside will cause leaking- not prevent it.
Aug 27, 2008 | Dynasty Hardware Pacific Shower Basket or...
Home Logo
347 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
