Question about Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator
Drain tube freezing up - Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator
  • Whirlpool Master
  • 43,501 Answers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Oct 07, 2010
True back bar freezing up
Most models have a metal drip collector below the evaporator that has a drain hole in it where the defrosted water goes into before it goes down to the drip trap and then out the drain hose. If the area around the drain hole has cracks, or was punctured during servicing, the drain water can get underneath the tray and run out beside and around the drip tray and never gets into the drain tube and freeze in that location. A careful inspection of this area will reveal any issues.
Aug 15, 2014 | Refrigerators
Defrost drain is freezing
it is a normal problem with all refr. there is a drain tube at the rear of the unit the has a "drain loop" it gets plugged after a few years. try and remove the tube from the clamp, and run water thru it to clear the blockage. you will also need to remove the ice from under the freezer coil after you clear the tube. after that the regular defrost cycle will take over and work properly.
Dec 31, 2013 | GE GDS18LBR Bottom Freezer Refrigerator
My freezer is freezing at the drain hole so all the water is running into the bottom of the fridge
HI, either your drain tube is clogged or it will need a drain tube heater installed to prevent future freeze ups. Thaw out with hot water....
Jul 15, 2011 | Refrigerators
Water draining into bottom of freezer and freezing.
Your freezer has a drain that leads to the exterior drain pan beneath the unit. Occasionally this drain can become clogged resulting in standing water inside your freezer,due to line freeze over. In the freezer, standing water will become ice and may result in defrost problems or inadequate coldness.
You will need to Clear the drain by forcing a solution of water and bleach or water and baking soda into the drain line with a basting syringe. If the solution will not flow through, slide a length of ¼ inch flexible tubing into the drain tube to push the clog through to the drain pan. Remove the tubing after clearing the clog. This will correct the issue.
Jan 08, 2010 | Whirlpool GB2SHKXL Bottom Freezer...
AMANA FRIG MODEL TJ18MW KEEPS FREEZING INSIDE THE EVAPORATOR DRIP TRAY. HAS NEW DEFROST TIMER AND DRAIN TUBE HAS BEEN CLEANED SEVERAL TIMES. POUR WARM WATER DOWN THE DRAIN TUBE AND IT FLOWS
Thats an old problem,Haven't seen one of those in a long time.The Styrofoam block that sits between the refrigerator and freezer has become saturated with moisture which is freezing around the drain tube and causing the drain tube to freeze up.You can either replace the block part number R156842  $80 if it's still available,or you can cut a piece of solid copper wire no insulation,wrap it around the heater(the black rod that runs anlong the bottom)a couple times and then run the other end down into the drain tube to transfer some heat into it to keep it open,it's an old trick but it works perfectly,just don't run the wire all the way through the drain.only through the middle carefull to keep it away from the plastic tube.
Sep 24, 2009 | Refrigerators
Sub Zero model 550 bottom Freezer/ Refrigerator. The freezer section keeps freezing up and the drain off water runs down the inside across the rail frezing the door shut. No matter how many times we...
Clarkk I have seen this many times. Your drain is clogged. If you pull the drawers out and pull the top cover you will see the evap. On the cover you will find a nozzle that goes to the drain. Use some compressed air and blow out the drain. In some cases there will be some silicone that will need replaced. You can get a food grade silcone sealant at a hardware store. Hope this helps.
Aug 09, 2008 | Sub-Zero Refrigerators
Subzero 550 water drain in refrigerator section backs up
The problem is that the water freezes in the drain, either because the door is not sealing good, it's open too often or there is mold in the catching tray and tube. Best solution is to take a turkey baster (pump), disconnect the flexible tube from the tray, by pulling down, take a large cup with very hot water mixed with a spoon or 2 of Clorox, fill the baster with that mixture and pump it on the drain tube. You have to do it several times, water will come out, but do it until you hear a "woosh" sound and the water goes freely on the drain. Also spill some of that mixture in the tray so it kills the mold.
Apr 04, 2008 | Sub-Zero Bottom Freezer Refrigerator
Whirlpool (ET8FTEXSQ) Top Freezer Refrigerator Logo
89 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
