Question about Swisher Ride King Zero Turn Mower 23 Hp, 52" Cutting Deck
Need to find parts for a zt2352 swisher mower. I need the center deck pulley's and blade mount.
2 Suggested Answers
  • 146 Answers
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Posted on May 28, 2010
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
Can you show me the correct diagram for the drive belt on a 44in Dixon zero turn mower
Hope this helps. Serpentine Blade Drive Belt
1 Lower the mower deck to its lowest position.
2 Route the serpentine blade drive belt (part number 6109) onto the V-pulleys located on the mower deck. One double pulley is located at the front of the deck near the center. The other two pulleys are located near each side of the deck. Route the belt around the outside -- the side toward the outer edge of the mower deck -- of each pulley. For the double pulley near the front of the deck, route the belt around the lower pulley (part number 6058) only. If pulleys are fitted with belt guards, work the belt in between the pulley and shield.
3 Push the idler pulley toward the center of the deck with your hand. The idler pulley (part number 6059) is the fourth pulley on the deck and is located near the rear of the deck. It is the only movable pulley on the deck. Wrap the belt around the side of the pulley nearest the edge of the deck. Release the idler pulley to place tension on the belt. No adjustment is necessary because the serpentine idler spring (part number 6065), located on the idler pulley, adjusts the belt to the correct tension.
May 10, 2016 | Garden
What is proper procedure for replacing all 3 pulley/ blade drive assemblies. Had trouble getting blade mount plate off of bottom off spindle shaft.
OK I HOPE THIS WORKS I HAVE A T-13560 GUESSING THEY'RE CLOSE, I HAD TO PULL OFF THE TOP COVERS SHAPED LIKE A "V" WITH ONE NUT HOLDING IT ON ,FIRST REMOVE THE CENTER BLADE BOLT UNDERNEATH ...THEN YOU'LL SEE THEIRS 4 1/4-20 HOLDING THE BLADE DRIVE ON BUT FOR ME I ACTUALLY TOOK THE FOUR BOLTS OUT HOLDING THE ENGINE MOUNT OUT IE. THE CENTER OF THE DECK TO EXPOSE THE TOP OF THE CENTER PULLEY (MY BAD ONE) AT WHICH POINT I COULD TAKE AN IMPACT WRENCH TO REMOVE THE PULLEY NUT ...THEN UNDERNEATH REMOVE THE BLADE MOUNT ....MY BOTTOM BEARING FELL APART SO I COULD PUT THE SHAFT IN A VISE , HEAT IT UP AND TURN IT COUNTER CLOCKWISE ...THEN REASSEMBLE GOOD LUCK
Jul 07, 2015 | Swisher T14560 T - 60" Trailmower with 14...
Why does belt keep coming off when blades are engaged on 50" swisher
either the grass is way to tall
the belt is damaged
or a pulley/spindle on the deck is damaged
Sep 09, 2014 | Swisher Garden
Swisher 44" mower starts and runs but engine bogs
The engine in this machine seems to be powerful. If you can remove the belt from the pulley that drives the blade. Try turning the pulley buy hand. If it turns tight or not at all this is your problem. The unit that is the pulley to blade assembly is seized or ready to seize. Sometimes they are designed to be taken apart and repaired, and sometimes they are not. Did you check for a grease fitting within the pulley to blade unit?
I would like to hear how this works out for you. Best of luck.
Jun 13, 2011 | Swisher Atv Trail Mowers Choose Color
May 27, 2010 | Swisher 60" 26 Hp Zero Turn Radius Riding...
Mowing deck pullies, mounting and spring application.
Download the product manual from the Sears website. Murray manufactured these tractors so you can download the manual from the Murray website also. Procedure for replacing the mower deck belt is quite simple. No need to remove the deck. Spring location also on diagrams. Mower deck parts diagram breaks down the whole assembly. Easier way to remove pulleys is using an impact wrench, otherwise hold the blade while removig the nut that holds the pulley in place. Use a heavy glove to hold the blade for safety!
Sep 25, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Cable streched on swisher trailmower
Pull the belt cover off on the side of the engage lever and you will see that it is not a wire cable that engages the idler pulley. It's a rod connected to a long spring. Perhaps the spring came off or is defective as it puts tension on the idler pulley against the drive belt when you engage the blades. Further, there is a return spring to pull the idler pulley away from the drive belt when you disengage the blades. Check all the connections for the springs and see that the engage lever is mounted tightly. Also check the idler pulley itself.
Jun 22, 2009 | Swisher T14560 T - 60" Trailmower with 14...
Swisher Ride King Zero Turn Mower 23 Hp, 52" Cutting Deck Logo
140 people viewed this question
Top Swisher Garden Experts
Tim Whalen
ray gallant
john milligan
Are you a Swisher Garden Expert? Answer questions, earn points and help others
