Question about Woods Freezers
I was defrosting my freezer and one of the plastic things that hold down the shelves broke, now the shelf comes up on one side . Can that piece be replaced? and if so where can I get one? Thanks Stephanie Rodgers stephr@cfl.rr.com
  • Woods Master
  • 43,501 Answers
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Posted on Oct 07, 2010
How do I reinforce freezer shelves?
The freezer should not be totally be full otherwise the cooling system will not succeed to reach its design temperature. If the shelve is still bending, get a piece of maple about 1x2" and attach it to the shelve at each end with a piece of nylon rope.
May 01, 2014 | General Electric FUF21SVRWW GE 20.6 Cu....
Frost build up especially on top shelf all other shelves except one gets a 3 inch layer of ice in approx 4 months. The freezer is kept in a mod temp basement room and the freezer door is opened less than...
Things you can do to cut down on frost.
1.make sure all seals fit flush to frame.
2.use a thermometer and set freezer to -18c(beef will keep upto 12months).
3.wrap all food as airtight as poss.
3.do not overfill,leave space for air flow through drawers/shelves.
4.defrost every 2/3 months in humid conditions using clorine bleach to clean interior,and dry thoroughly.(leave door open to dissipate clorine gas.)
Aug 18, 2010 | Woods Upright Freezer V1613RW3
Lower shelves keep falling down out of wall supports
replace gromments and reduce the weight that you put inside the shelf/basket.
Apr 22, 2010 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
The top shelf in my upright freezer ices up badly; but the rest of the freezer is great - no ice! What causes this and is there something I can put on that shelf to keep the ice from building up.
If this is the type of freezer where the shelves are the evaporator coils, the coolant goes through the shelves(tubing) and the formation of frost is normal and has to be manually defrosted.All the shelves should be as cold asd the top one. The fact that just one has any frost may indicate that it is low on freon. If this is the case you should notice that the freezer doesn't get cold enought.
Sep 02, 2009 | Freezers
Upright freeezer only gets to 32 degrees
have you checked the door seals on the freezer. sounds like its getting air into the compartment and causing the problem.
Mar 28, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Upright freezer.Two shelves freeze up. One doesn't. Why and is this a problem
look to see if the shelves are in fact not shelves but evaporator coils . if the shelf is connected to small tubing, then that tubing flows freon that freezes the shelf. if its clearly not connect to any tubing or piping then its just a shelf and gets residual cold from evaporator shelves. if it is connected to tubing like the others and not getting cold then you have whats called a restriction. . particles have plugged the tubing and no freon is feeding the shelf. if that is happening then consider having a pro recover the gas , unplug the tubing , replace the drier and recharge it. if its an older unit and you are getting by then maybe not worth the expense.
Nov 01, 2008 | Kenmore Freezers
Not all the shelves are getting cold
All the shelfs should be getting cold starting at the top and working down. It may have a leak in the system or a restiction not letting the freon flow. It could of had the problem before the defrost. Small enough problem to stay frozen but won't bring back down to temp. Check to see if it's still in a sealed system warranty if so call for service.
Apr 13, 2008 | Frigidaire 14.1 cu. ft. Upright Freezer...
Roper--ice buildup on one freezer shelf
The reason for ice buildup is an air leak. Recheck all around the gasket by taking a dollar bill and closing the door on it and pulling it out. If you don't have resistance, you found your leak. Heat that area with a blow dryer to relax the gasket and close the door to let the magnet and seal set. Also, rub some vasoline on the hinge side gasket to keep it from dragging.
Dec 07, 2007 | Freezers
Freezers Logo
Top Woods Freezers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Woods Freezer Expert? Answer questions, earn points and help others
