Question about Microsoft Windows XP Home Edition
Sound hi basically the sound device on my computer is not working need help to get that fixed i think its something i need to change but dont know what or how i have a Windows XP T135
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • 359 Answers
Very often, assuming you have checked connections and power, sound issues are related to drivers. There are a lot of drivers out there, and the right one depends on a number of factors including your OS and other equipment and parameters. Since detecting the type of equipment you have, and its numerous technical specifications, can be quite difficult, it may be easiest to use a site that will scan your system and determine any updates needed. You may find this more helpful than trying to search for one individual driver, as that can be nearly impossible. Additionally, I have seen numerous users reporting issues with attempting to find, or using, the drivers located at the Acer site.
Three available sites: www.driveragent.com, www.drivers.com, and www.drivershq.com. Note that these are only three samples, and there are a number of sites that offer this type of service - choose whichever one you may feel most comfortable with. You can also check the Windows Update Catalog (though it is complex and complicated, and you have to know what you need) at http://catalog.update.microsoft.com/v7/site/home.aspx for a driver that may be compatible, if you feel confident doing this.
If none of these things helps, please post back as to the outcome of the above. Otherwise, thanks for rating FixYa!
Posted on May 29, 2008
No sound on acer aspire m1610
Verify the speakers are plugged in and turned on and volume is turned up.Also check the volume control on the computer and make sure it is not muted.Go into Device manager and make sure there are no problems (yellow ! or ? and red x) If there are download and install the audio device driver to fix the issue. If you dont know which device you have you can download SIW or aida64 to help identify your audio device.
AUDIO DEVICE: integrated Realtek ALC888S high-definition audioDRIVER DOWNLOAD: http://support.acer.com/us/en/product/default.aspx?tab=1&modelId=342
Nov 10, 2011 | Acer Aspire Computers & Internet
Well i cant hear nothing thats it. i think i move something while i was trying to make all the speakers on my pc and now i dont know what to do.plzzz. help.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume adjustment you will need to right click on the volume icon depending on your operating system select adjust volume
if his does not fix the problem"
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer hope this helps
Jul 20, 2011 | Logitech X-530 5.1 Speakers
Hi, my toshiba satellite m35xs114 dont have a sound, It shows that the device is working properly and I have done all the basic checking with regards to unmuting the sound. I reloaded the drivers, I had...
Might need a new sound card but first,
Have you done the following....
1. Go to "Control Panel".
2. Click on "Sound".
3. Make sure you are on the "Playback" tab.
4. Click on the device you are trying to fix.
5. Now click the "Configure" button and follow the prompts. (Be sure you also click the "Test" button.)
6. Once that is complete, click the "Properties" button.
7. When you are done with your changes, in "Properties", click "Apply" and then "OK".
8. Then click "OK", again, on the main "Sound window".
Nov 01, 2017 | Toshiba Satellite M35X-S114 Notebook
Why my sound camera dont work now it silent?dell window vista home basic inspiron 1318
hi
check your device manager if there is any unknown device
it means you have to install your sound and camera driver
good with you
Jun 19, 2010 | Dell Inspiron 1318 Laptop Computer PC...
Resource conflict - PCI network controller on motherboard BUs:02, Device:02, Function:00
You can adjust the resources in device manager. right click on my computer (which you will find from either your desktop or from start menu), select manage, then on the left side click on device manager, on the right side, find the problem device, click properties, go to the resources page, you will be able to view and change the resources, adjust them so there is no conflict.
Oct 18, 2009 | Toshiba Computers & Internet
Sound problem
Start by getting a program called SIW from Gabriel Topala's website. Once you install this, under hardware and audio or sound devices, you find all brand and part specific info to give further information.
Also try under audio devices in control panel, check which device is set to default, and tinker with it, if you change it to a new option and you hear a "BING" you have fixed it. NOTE: Write down the original setting so you can put it back if you dont fix it.
If you need further help let me know, I CAN solve this problem.
Jim
Aug 05, 2009 | Computers & Internet
Sound device problems
right click on the program shortcut and change the compatibility to windows xp, it will work then...
Nov 13, 2008 | HP Pavilion dv6000z Notebook
Speakers dont work at all
Did you install the audio card drivers?
Oct 29, 2007 | Logitech R-20 Computer Speakers
Microsoft Windows XP Home Edition Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
