Question about Whirlpool WED5300S Electric Dryer
Dryer tumbles, no heat, thermo fuse has been changed. Can it be the cycling thermostat or the heating element?
  • 259 Answers
If you have changed the thermal fuse you may have a defective thermal cutoff (located at the top of the heater housing in the back). The thermal cutoff will come with the high limit thermostat located at the bottom of the heater and you should change both parts if the thermal cutoff is bad.
You can take both of the parts (the heater and the thermal cutoff) to a parts supplier to have them checked for continuity (they should both read "closed" if they are good).
Good luck to you!
Posted on Oct 07, 2010
No heat from tumble dryer
Hi.
If dryer is electric check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, element and fan.
If dryer is gas check for lint obstructions, check ventilation, test thermal fuse, thermistor, cycling thermostat and high limit, igniter, coils, burner, flame sensor and fan.
Dec 14, 2011 | Washing Machines
Tip
How to Replace A White Knight Tumble Dryer Heating Element Heater and Thermostat
For a full list of appliance Video Repair help see our video section
White knight tumble dryer not heating this video show you how to change and fit a new heating element and thermostats can be used on Ariston, Electrolux, Ignis, Neutral, Tricity Bendix, Whirlpool,
Here is the element in this video
For all you tumble dryer spare parts click here
The easiest way to find you part is put your model number into our search bar at http://www.apart4u.co.uk/ TEL 08455218000
http://www.apart4u.co.uk/news/category/questions-and-answers/diagrams/
on May 10, 2010 | Abbaka White Knight 38AW Electric Dryer
My tumble drier has no heat and the reset button does not seem to be working
could be thermal limiter fuse in the back of the dryer. this can cause it to not heat but still the drum will turn
May 01, 2010 | Abbaka White Knight 44AW Electric Dryer
Dryer wont heat up on a aquarius VTD00, do you think its the element
A tumble dryer that isn't heating up at all needs checking with a continuity test meter. The most common cause is a heating element failure, or t.o.c's going open circuit. . Some tumble dryers have heating elements that are easily accessible by removing the back panel, and can be tested for continuity or checked for obvious breakage. Others though have their heating elements inside, which aren't accessible without stripping the dryer down. Tumble dryer heating elements are always protected by thermal fuses which are usually simple devices with 2 wires connected. They can be tested for continuity with a test meter. Also overloading and blocked filters can lead to thermo cut out, it is best to check your manual and call someone out on this occasion. You may even have a red reset button on the rear of your machine some models do, if yours doesnt then call out engineer :)
Jul 19, 2009 | Hotpoint NWXR473EV Dryer
Whirlpool Dryer Does not dry
Its the thermal fuse. when you jump or, by-pass the cycle thermostat, you are basically by-passing the fuse as well. replacing the thermal fuse will fix thsi issue.
The fuse is usually located on the vent duct, inside the dryer. A blown fuse will show no continuity when measured with a meter. Before replacing the fuse, make sure the blower wheel is not broken or clogged, and there is nothing blocking the venting.
Jun 21, 2009 | Whirlpool LER4634J Electric Dryer
Dryer won't heat--element replaced; tumbles fine
Before you purchase any more parts, you should have use of a multi meter. If the dryer is not heating at all, and of the following parts could be bad.......Operating (cycling) thermostat, high limit thermostat, thermal fuse, timer, or motor centrifugal switch. All but the motor switch can be easily checked with the dryer UNPLUGGED using the ohms feature of the meter.
May 03, 2009 | Dryers
Kenmore dryer doesnt heat
You may also need to change your thermal fuse and the thermostat. On some models the thermal fuse operates the heating element only and others the whole dryer
Mar 19, 2009 | Dryers
Dryer runs but will not heat. Replaced fuse and
your cycling thermostat needs changed too. the thermal fuse is your last safety measure that goes, which means your cycling thermostat is not shutting down the heat element once it detects the right temp hot air in the blower housing so it let the heat element glow until either the high-limit sensor shuts the heat down or the thermal fuse blows. Change the cycling thermostat and good luck
Mar 06, 2009 | Whirlpool LER4634J Electric Dryer
Dryer doesnt work but i hear the timer working
Change your cycling thermostat. When your cycling thermostat fails, then the reponsibility of your heating element to shut down goes to the high-limit thermal shut off (closest to heat element) and the thermal fuse. Your cycling thermostat should shut down heat element when it detects about 140* air in the blower housing. Yours can't detect that anymore so it lets your dryer heat up and up till you blow the thermal. new cycling thermostat and thermal
Jan 18, 2009 | Kenmore 60172 Electric Commercial Dryer
Frigidaire Dryer WOn't Heat
I have a frigidaire frontal dyer that is 3 yrs old. The dryer works properly, it tumbles, but it is only cold air ???? What's the problem ?
Mar 15, 2008 | Frigidaire GLER642A Electric Dryer
Whirlpool WED5300S Electric Dryer Logo
189 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
