Question about NEC MultiSync LCD4010 40 in. Television
I use my monitor (LCD4010) as a television connected to DirecTV. I also have a dvd player attached. Has worked perfectly. Yesterday, while watching tv, I lost the picture. Sound is still ok. It is not a black screen but is snowy... like an old tv with no antenna hooked up. Any idea what happened? What to do?
5 Suggested Answers
silly girl
  • 513 Answers
SOURCE: problem with plasma tv
Something in the path to drive the other half of the screen has failed or is broken. Need some basic troubleshooting information in order to be any more specific, but I've seen this problem before with NEC plasmas. If still under warranty better use it Good luck
Posted on Mar 22, 2006
SOURCE: No display
When you get the red and green leds lit it means the screen doesn't see an input signal and has gone to stand-by. That the red led goes off when you reconnect suggests a signal has been recognised by the screen but be very aware that it may not be a good signal. As you are using a PC input I will assume the signal is RGBHV, maybe you have the H and V swapped around? I would try another computer source into the screen.
You say you are using the digital harness, please explain exactly what this is.
Posted on Jun 14, 2008
satavlad
  • 405 Answers
SOURCE: No signal with NEC plasma PX-50XM4A
You were right when you called it a monitor, it is a monitor, which means no tuner. To be able to use it as a TV you will need cable box or satellite receiver or something that has a tuner in it.
Posted on Dec 02, 2009
  • 191 Answers
SOURCE: NEC widescreen tv sound but No picture model no.
if its always 1min. work b4 the picture offf ,check ur power filter capacitors & if only sound comes when power on change ur inverter
Posted on Jun 15, 2010
Television turns off every 50 seconds watching a DVD via HDMI
If it has an internet connection (wired or wireless) allow it to update it's firmware. If it does not have a connection, I would take it back to the store and have then replace it.
Jan 27, 2013 | Televison & Video
My TV flashes sound and picture with DVD and some channels from DirecTV. Both DVD player and DirecTV are ok with other monitors. Only the 500+ channels are involved? What may be wrong?
Look for any loose contacts in RC jacks/sockets/Cable. Even if one strand of wire is loose and touching the earth connection of the jack, you might get these sort of problems. Check whether the service provider has any problems beyond 500+ channels. Depending on the frequency, some channels are generally weak.
Aug 04, 2012 | Samsung HP-S4253 Television
Have directv what are the connections i need
You should be able to connect direct tv OUT yellow red and white to the IN yellow red and white on your DVD player/VCR combination. Then you connect OUT on your DVD player/VCR combination to the av video input of your television. By yellow red and white I am reffering to composite/RCA cables. There might be a way to connect with component cables though. I would need more information.
Apr 28, 2010 | Televison & Video
Abrupt loss of picture during DIRECTV-source
Ur main video backllight board it dying,must be replaced.
Oct 14, 2009 | Fujitsu Plasmavision PDS-4209 42 in....
I have a Vizio P42HDTV10A with a Bose 321 system and no sound
Check you cables. make sure that the Dish Box is hooked up and if you are run'n your cables from the Dish Box to the DVD player then you will have to keep the player on.
Use to work for DirecTV i got this all the time
Aug 25, 2009 | Vizio GV42L 42 in. LCD Television
I just had directv hooked up, I have a dvr receiver, I was told I did not have enough hook ups on the back of my tv, so therefore, I went and bought a switch or combiner. Now, how do I need to run the...
Newer directv hd receivers must connect to the av input (yellow,red, white) connections on the back/front/side of your tv. If your tv only has one of these av inputs then you will need an RF modulator for your dvd player. You will connect the (yellow,red, white) connections from the dvd player to the rf modulator and then connect the tv out on the rf modulator to the tv rf jack ( the silver threaded barrel on the back of the tv) Tune your tv to channel 3 to watch a dvd and then back to the av input channel for the directv receiver.
Apr 14, 2009 | Directv D11 DTV Receiver
How do you connect a dvd player to the back of the 42''JVC LCD ?
the directv needs hookedup to the tv, also the dvd player needs hooked up to the back of the tv, what type of cabling are you using, red/white/yellow or coax (where it screws in) or does it plug in and say hdmi, etc.
Apr 04, 2009 | JVC LT-42X688 42 in. LCD HDTV
Cannot hear DVD through the DVD receiver port
I had to turn on the TV first then the receiver and DVD player to see the video of the DVD.
Jul 31, 2008 | Onkyo TX-SR803 Receiver
I have a magnavox dvd player and just had directv installed and I cannot get the dvd to recognize the directv channels. I can only record two digit numbers.
your best bet for this problem is to rearrange the way you have your direct tv and dvd hooked up to your television. a lot of the time you can plug the dvd player into the input/antenna in jack on the back of the receiver. that way you can watch all the channels you want AND be able to watch dvds without having to unplug and replug stuff in. more than likely you'll have to push an input or tv/vcr button in order to switch between watching direct tv and dvds, but it's a lot simpler than switching chords around.
Jul 28, 2008 | Televison & Video
Remote controls don't work
I have the exactly same problem. Please help
Jun 29, 2008 | Vizio L37 Television
NEC MultiSync LCD4010 40 in. Television Logo
107 people viewed this question
Top NEC Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a NEC Televison and Video Expert? Answer questions, earn points and help others
