Question about Whirlpool Refrigerators
Refrigerator made high whinning noise and became warm in a 24 hr time period. repair service thought it might have a hole in tubing plugged it worked fine for a day now back to old situation high whine and warm this is a refrigerator only refrigerator is 3+ year old bought thru lowes i have 20 min before i must leave for work
  • 503 Answers
The whining and/or whistling noise is caused by a problem with the MAIN CONTROL BOARD, not, the variable speed fan motor. You can change the fan motor and the related thermistors and the problem will persist. The Main CONTROL BOARD is located on the back of the refrigerator behind a panel with from 3 to 10 quarter inch hex head screws. All of the of the connections to the board are normally easy to remove and re-install on the new board. I have had some new boards with bent pins, so, be careful when trying to put the plugs on the pins. Also, you can not get the plug configuration wrong, since, every plug has a specific number of pin holes. The board itself has 4 white nylon pins holding it to the refrigerator. These pins have a side that you must push in to release the board. I use a tiny screwdriver for the job. As you might be able to tell. Please unplug the refrigerator before performing any the the above actions. The Main Control Board is the source of many other problems, such as, Compressor not running, Ice and Water through the door problems and defrosting of the evaporator coil. Don't let a repairman condemn a compressor before it is proven to be defective.
To know more about troubleshooting please visit the below mentioned link......
http://www.repairclinic.com/Refrigerator-Troubleshooting
Please post your feedback and Vote if the problem resolved as per your satisfaction.
Posted on Oct 07, 2010
2004 Taurus
Clogged gas filter or blocked exhaust converter,will
cause it to barely get to 50mph
The tube sounds like the egr tube ,replace it,you
can't patch a rusted out steel tube
How is it that repair shops by you are incompetant?
Spark plugs get changed every 3 years
Fuel Filter every 3 or 4 years
Clean MAF Sensor with CRC MAF Cleaner,instructions
on the can
Jan 08, 2013 | Cars & Trucks
Water dripping from freezer into refrigerator
Just fixed my refrigerator last week that was doing the same thing. Water was dripping from the back top of the refrigerator and it was the drainage line in the freezer had frozen up and was plugged. Emptied the freezer and removed the bottom panel from the freezer and found large layer of ice. Turned freezer off and let everything melt. Then the hole in the back bottom of the freezer on the metal tray became visable. Contined to thaw until warm water would drain into the tray under the freezer. Was not hard at all and much better not cleaning up the water dripping all the time.
Jun 07, 2010 | Roper RT21AKXKQ Top Freezer Refrigerator
10-year-old 32" RCA PIP TV just blinked off one morning after about 30 minutes. It makes a continuous high pitch sound, and the on/off switch is completely unresponsive. I assume this is a picture tube and...
It's not the picture tube(especially if image was good b4 it went dead). The high pitch noise is the power supply whinning because it's shorted or overloaded. I just fixed one of these sets - replaced the horiz. o/p transistor and flyback estimate around $120.00-$160.00
Oct 24, 2009 | RCA F32650 32" TV
Freezer and fridge not cooling
compressor not on most likely.listen for a low hum inside or low down close to the floor in front of it.If no hum its not on.depending on age you can install a hardstart for it and get more life out of it.
Sep 24, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigator not cooling coils clean and compressor working
check defrost timer control on older located on bottom by the condenser coils look at elect diagram to see if one is hook up
Sep 24, 2009 | GE Refrigerators
My maytag wide by side keeps freezing up. I have
It's determined by how much you are in and out of the unit,the board uses the light switch to count how many times you open and close the door if the switch isn't working properly it won't defrost often.Under normal usage you should get at least 2 defrosts in 24 hours.
Aug 19, 2009 | Maytag Refrigerators
Camper fridge dont cool
I also had the same Model Make. I removed my fridge and placed it upside down, occasionally shaking fridge within a 24 hr period. This seemed to re-mix the ammonia solution and the fridge is working.
This may work for you but look for yellow stains if you see any your fridge is leaking and would require repair.
Jul 06, 2009 | Dometic RM2620 Refrigerator
Jenn-air 46-37333 side by side refrigerator
Goto the back of it, this could be because of power failure check to see that they're plugged in nice a tighty, if they are, check your fuse box, turn everything off and back on again.
Aug 08, 2008 | Jenn-Air JCD2295K Stainless Steel Side by...
Water in the bottom of the refrig
HI thanks for your question. the drain tube is clogged. to repair turn fridge off, for at least 24 hrs. as the frain tube is between the inside and outside wall. so its just not dirt in the drain tube, its frozen . to clear after 24 hrs . purchase a small plastic tube , go to the drain tray at the back shove the small hose up the drain hose and blow air up the tube . it will unclog. thanks the appliance doc. please rate my answer. thanks.
Sep 22, 2007 | Amana ATB2135HR Top Freezer Refrigerator
Refrigerators Logo
71 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
